Projects by members => Projects by members => Sebosfato => Topic started by: sebosfato on February 19, 2017, 13:42:19 pm
Hello all
In my vacation i had lot of time to reset my thoughts and now thinking perfectly clearly i concluded that the theory i was working on is plenty correct..
its based on applying full wave bridge rectified ac to the water thru a set of chokes but having also a pulse forming high voltage discharge occurring thru water.
The dc and chokes allow the water to align and the high voltage pulse breaks the covalent bond
the high voltage pulse must be tuned along with the chokes and the dc could be from a very low frequency low voltage actively switching a relay set...
the chokes allow the high voltage capacitive discharge to go straight to water
the best way i found to make this capacitive discharge is to incorporate the capacitance within the design of the cell.. and it must handle the voltage involved...
its not really necessary to be physically incorporated;;
but the connections between the capacitors need to handle extremely high currents..
The wave form we see from Meyer is just a low frequency pulse mixed with this high voltage pulse so it gives that appearance of full wave bridge rectification...
So basically the frequency may be important to tune... but first we got to tune the components to achieve the goals..
good week to all
I think you are on the right track with these thoughts, Fabio....
Well done!
Thanks for supporting the ideas my friend, for me is important to know how you feel about it!
basically is just about mixing pulsed dc and high voltage discharge, the first align the molecules and the second is so fast that can only electronically depolarize the molecules... switching off the covalent bound when the induced oscillation amplitude is enough
i was thinking there is a second way of doing it basically using teslas arrange
basically having a dc choke from a high voltage dc line to charge two capacitors that are in series with the load (load between the two capacitors.
than a spark gap of even better a trigatron close the capacitors when the are charged making them to step up a violent oscillation on water..
there are spark gaps that can conduct 50 amps;;
the choke in this case works as a impedance that does not allow the spark gap to short the source when it fires and to limit the current input when there is maximum reverse voltage at the capacitors at the second part of the cycle...
When you also add some kind of magnetic forces to repel the ions from the electrodes, then you are trying what Kevin and me are trying with the HA replication....
Or the Horvath patents.
All the same.
Cheers!
i would not say its magnetic, i planned a plain simple reversed pulse of very high intensity tuned to a certain frequency to shake the covalent electron the reaction will occur near both electrodes but not actually at the electrodes...by near i mean nano or pico meters of distance... is the distance of the double layer which i dont remember now...
i believe meyer used the double layer capacitance of water instead which is pretty much high and therefore there is a lot of importance in analysis than the only physical capacitance
it takes a very small voltage to start leaking just about 1,24v so this is kind of the first limit of charge ability for accumulate...
when there is such voltage applied there is a region formed where there is a drop of 0,5v that forms an electric field of the intensity of 5000kv if i remember well because the drop occur in a very small length... any book for hydrogen fuel cell tech should have the right numbers
i wonder if this electric fields manipulation is all we have to do it would prove to be simple and stupid
THis is some images representing what i talk about
Ha! The famous tesla schematics!
I am happy that you think about those. I also wonderd for years if that would applicable for Meyer type of waterfuelcells....
Yeah bro i´m interested as i noticed that the schematics above could be modified to work with dc pulse...
in richie site he uses a dc circuit to charge the caps thru a resonant charging choke
in this two schematics i posted the capacitor will discharge thru the gap into the primary coil
if the charging circuit has a same frequency of the resonant frequency it will achieve maximum power because we can force the spark gap to fire every or every certain n cycles...
other wise will still work but with bursts
from this perspective the spark gap is not even needed..
(http://www.ionizationx.com/index.php?action=dlattach;topic=3175.0;attach=15050)
on the left side you see the molecule has its electrons attracted to the positive side the bonding electrons are represented paired together
on the right side after the molecules already aligned they receives a very sharp high voltage reverse pulse than the electrons of oxygen must re-arrange so changing the time share rate of the electron forcing them to be more likely into the hydrogen side basically depolarizing the molecule.... or neutralizing the dipole attraction force
on the drawings the red is positive and blue negative
Nice!
What is the source of this info?
this is the theory i´m working on, this is the conclusion i came up with for the better case possible i see to oscillate the molecule and break it apart
What hold the water molecule is the attraction of oxygen protons to the hydrogen electrons but it only is possible because the ability of electrons to pair with another with oposite spin because its like the electrons cant repel each other as much in this situation....
if we consider the force that holds the water molecule stable to be the attraction 8 proton to hydrogen electrons + the atraction of the hydrogen proton to the 8 electrons - the repelling force between the hydrogens proton and oxygens protons- the repelling force between all electrons.. the protons are farther away than the electrons a bit ..
the oposite spin of the electrons makes the repelling force to be smaller because the magnetic moment cancel each other
the repeling force of the hydrogens protons also exist and is what cause the compact format of water
the result is a molecule with
http://www.sciencedirect.com/science/article/pii/S030438861630002X
