Projects by members => Projects by members => Timeshell => Topic started by: timeshell on February 25, 2015, 06:43:49 am
Title: Water Quality
Post by: Login to see usernames on February 25, 2015, 06:43:49 am
Do NOT use chlorinated water on your tubes.  Chlorine is highly reactive and will create an oxide on your pipes even thou stainless steel.  This will royally mess up your cell capacitance as the oxides will cause a higher capacitance than what you may be factoring for.
Title: Re: Water Quality
Post by: Login to see usernames on February 25, 2015, 22:26:33 pm
thnks for the tip.
I always remove the water after a test....
Helps too
Post by: Login to see usernames on March 01, 2015, 00:53:07 am
"No conventional dielectric material could prevent charge carrier breakthrough. In a double-layer capacitor the chemical stability of the solvent's molecular bonds prevents breakthrough"
Post by: Login to see usernames on March 01, 2015, 00:54:58 am
https://www.quantamagazine.org/20140122-a-new-physics-theory-of-life/
