Projects by members => Projects by members => Sebosfato => Topic started by: sebosfato on February 12, 2014, 09:35:59 am
Title: the roto multiplier
Post by: Login to see usernames on February 12, 2014, 09:35:59 am
i'm thinking about another way to mechanically study the situation...
Imagine this...
two wheels having electromagnets north pointing out on one wheel and south on the other.
the rotate making the electromagnets face each other...
Now from my understand i got this...
A north pole electromagnet approaching a south pole electromagnet is going to induce a north pole to the south electromagnet (according to lenz to oppose the movement) and a positive at this south lead. (dot)
The south pole electromagnet in turn approaching the north pole electromagnet also induces a south pole thereto another positive into the dot .
so basically the two electromagnets given a choke transformer is connected between them should behave as field coils and as output coils since the dc current can flow thru the coils continuously.
In my analysis the north pole approaching the south pole even are accelerated against each other because of the attraction force
when they get away i get that the voltage on both leads reverses...
Title: Re: the roto multiplier
Post by: Login to see usernames on February 12, 2014, 09:42:24 am
make a drawing please? ;D
Post by: Login to see usernames on February 12, 2014, 12:27:03 pm
check this
(http://www.ionizationx.com/index.php?action=dlattach;topic=2845.0;attach=13269;image)
when its approximating (attraction)
The north induce a positive at the dot of south electromagnet
The south induce a positive at the dot of north electromagnet
when its getting far from each other (again attraction)
The north induce a negative at the dot of south reinforcing the south
The south induce a negative at the dot north reinforcing the north
Is it a correct assumption?
Post by: Login to see usernames on February 12, 2014, 18:11:58 pm
this is the pulsed idea i'm working on... the rotating gen is different since the south and north induces on one another..
(http://www.ionizationx.com/index.php?action=dlattach;topic=2845.0;attach=13271;image)
Basically i think that up to the point where the current to the load is greater to the magnetic field current theres no opposition to the movement of the magnet relative to the other instead there should be attraction...
Title: Better geometry
Post by: Login to see usernames on February 13, 2014, 15:50:53 pm
I came up with this better geometry to test the idea...
This can be set to test in attraction or repelling mode... fair simple the drawings speaks for itself
(http://www.ionizationx.com/index.php?action=dlattach;topic=2845.0;attach=13275;image)
