Projects by members => Projects by members => Dave => Topic started by: Dave on June 09, 2012, 22:56:31 pm
Title: Hydrogen gas gun project
Post by: Login to see usernames on June 09, 2012, 22:56:31 pm
From here on out I will post my progress on the gas gun in this section.
Title: Re: Hydrogen gas gun project
Post by: Login to see usernames on June 09, 2012, 23:00:21 pm
here is my first video update about the gas gun
http://www.youtube.com/watch?v=5eoyoZwwsLQ&feature=g-all-lik
Post by: Login to see usernames on June 10, 2012, 11:15:11 am
Hi Dave,
Looks great!
Cannot wait to hear your results.
I still have some ideas for you, after you are done with your own planned tests.
Just let me know when yr done.
Post by: Login to see usernames on June 10, 2012, 18:27:14 pm
Hi Dave,
Here a nice link:
http://www.bgk.com/ir_thefacts.pdf
 8)
Post by: Login to see usernames on June 10, 2012, 21:51:02 pm
Sound good Steve  :)
And thanks for the link!
Post by: Login to see usernames on June 13, 2012, 00:00:38 am
Steve, that link was very informative thank you  :)
Post by: Login to see usernames on June 14, 2012, 05:53:32 am
here is a pic of the electrodes, I'm not happy with them. They are held in place by plastic. I would like to replace them with either glas or ceramic for hv insulation. I chose to go with a threaded rod for the positive electrode because of the sharp edges and large size. I want to make ions but still be able to extract electrons efficiently. we will see
Post by: Login to see usernames on July 06, 2012, 04:01:30 am
Ok, so I haven't posted on this lately. I have some small details I need to iron out before testing. Right now my biggest concern is how the electrodes are held in place. As of now plastic disks I machined are holding them apart. I'm not happy with that because any high potential will pull electrons from the plastic. so I want to replace them with either ceramic or glass.
The other thing I want to tell you about is the electron extraction. I got my idea from some water spark plug designs. Basically using two power sources. One of high impedance and one of low dc resistance isolated by diodes. If anyone knows a good free circuit draw up program I would be happy to share the details.
Another thing I have been thinking about is removing the outer ground tube and replacing it with tin foil rapped around the outside of the quartz tube. This way I won't have a chance of an arc but of course that comes at a cost of potential. I will test with both ways.
I have designed my set up so that the gasses from the gas fun will be burned right after they pass through the gas gun. Hopefully flash backs will be prevented by the amount of air moving through the system. I will be forcing it through with a compressor for a few tests after I have dons the tests already explained.
Post by: Login to see usernames on July 06, 2012, 14:26:00 pm
You becarefull....
Dont blow yr self up.
I trully hope you see some different colors in the flame during the test.
Post by: Login to see usernames on September 25, 2012, 05:48:41 am
Thanks Steve. i will be careful.
Sorry for not posting in so long. Being in school sort of makes an unstable environment for me. I'm happy to report i'm finally gaining valuable skills in my physics and chem classes. At the moment I am starting the process of applying to grad school so free time to work on projects will be limited. i'll always be back to catch up and post so don't think i've given up.  I stopped posting on this topic because I am not happy with my electrodes. I'm still thinking about the best design.
Ok, now for the really deal, I have been talking to my chem professor about the injector concepts and he thinks it would be possible to break down h20 if we removed enough electrons. Not just into h2 and O2 but a complete breakdown. I will post more info of our further conversations.
Post by: Login to see usernames on October 18, 2012, 07:33:49 am
chrome://newtabhttp//www.youtube.com/watch?v=Tis4CBKOJ8s&list=UUDk1TaaIv-N3IKaNZh5T1GQ&index=2&feature=plcp
This is a video of my latest test. Nothing special to report put fun all the same.
My way to test for positive ions in simple. (Please watch the video before reading more). The energy i provide from the photon energy and the electric fields should change the arc in a significant way if i actually make positive ions. The energy input should be somewhat relative to the output
Post by: Login to see usernames on October 18, 2012, 10:16:25 am
Great test, Dave!
So you tried to use just ambient air thru a sparkgap?
Great video, btw.
(thats the real link... :) )
Post by: Login to see usernames on October 19, 2012, 02:01:51 am
Thanks Steve!
yeah, just air.
And thanks for posting the correct link! haha
On a forum, maybe this one, someone posted that as you apply an electric field to a substance, the absorption spectrum changes and the molecules can absorb a higher less powerful wavelength. Do you think this is true?
Post by: Login to see usernames on December 27, 2012, 06:43:49 am
I have come to a few conclusions since I last posted. Looking at Stans gas gun design, it seems as if its a pour attempt at an ionizer. We know that air ionizer need sharp points and uses one static polarity to ionize the air. In the gas gun situation, the classic air ionizer will not work well. This is because they produce ions by accelerating electrons and ions which are already in the air. These free electrons collide with gas atoms to produce ions.  In a closed container, we will be limited in the effect that can be produced because of the small amount of free electrons relative to the gas we are trying to ionize.
Because of the situation, I believe it is necessary to have two plates. When a high potential is applied, the orbitals are elongated which means a much lower photon energy is necessary for ejecting electrons. This would explain Stans choice of leds. ( see tunnel ionization)
Post by: Login to see usernames on December 29, 2012, 06:04:44 am
I bought this high voltage supply for testing off ebay
www.ebay.com/itm/100kV-high-voltage-adjustable-power-supply-tesla-coil-resonant-/310550049025?pt=LH_DefaultDomain_0&hash=item484e39b101
The unit was described as dc output and could be adjusted from 0 to 100kv. It included the schematics when it arrived. One quick look was all it took to make me skeptical of the dc output. The line current was rectified and had a few other things going on but then was fed into a transformer which produces the high voltage. No rectification was present after the transformer. I hooked it up and check with my high voltage dc probe. Nothing!. It produces a nice arc but I'm pretty sure its just putting out ac which i will need to rectify.
It real cold here but hopefully i can perform some ionization tests this week  :)
