General => General Discussion => Topic started by: AncientMist on April 21, 2011, 22:05:55 pm
Title: Design for Variable Capacitor
Post by: Login to see usernames on April 21, 2011, 22:05:55 pm
Update!!! Version_2 is more detailed! So go ahead and see for yourself.
Hey fellows!
I am working on the design for a variable plate capacitor. So if anyone would like to build one then, there will be a drawing for it. Attached is what I have already design.
The pdf is the Mechanical Design!  I would like to finish it so it can be spread amongst everyone.
Thanks.
Title: Re: Design for Variable Capacitor
Post by: Login to see usernames on April 22, 2011, 01:59:23 am
Stan's Dimensioned drawing is what is trying to be replicated.
Post by: Login to see usernames on May 04, 2011, 11:22:02 am
Can you give some more detail of your work? are you working on parallel plate capacitor?
Post by: Login to see usernames on May 10, 2011, 22:40:25 pm
 This is an ongoing process to give individuals a detail parts list to make the Variable Plate cell. The design is a small version of his cell. The reason is if you look in the patent he talks about the excitors only being 3 to 4 in small. This is a good setup since it is compact and also a good way to test his process. I believe the Demonstration Cell height is too much and is not needed for the height.
Also the newest update is ready at the top. The only thing required is to pick out the piping for the cell. Let me know if you see anything wrong with the design.
Thanks :D :D
