Added abbreviations
These are all standard plumbing parts
See the video "It runs on water" for views of the top plumbing assembly
PLUMBING Parts Gas Nozzle Assembly GNA Gas Control Valve GCV Gas Exit Port GEP Gas Shut-off Valve GSV Gas Flow Valve GFV Gas Flow Gauge GFG Gas Pressure Gauge GPG Water Inlet Plug WIP Conical Gas Fitting CGF Gas Assembly Nipple GAN
GFV Gas Flow Valve-----------
GNA Gas Nozzle Assembly ------
GSV Gas Shut off Valve---------
WIP Water inlet plug ----------- stainless in ITOW video, specs attached
GCV Gas control valve
GFG gas flow gauge------------
GPG Gas Pressure Gauge-------- 15 psi in orginal see ITOW video
GAN Pipe tees and nipples ------ Standard Plumbing parts, black iron pipe used
| 68115K41 Each In stock for $4.40 FALSE | | | Shape
| Tee
| Tee Type Pipe to Pipe
| Standard Tee
| Pipe to Pipe Connection
| NPT x NPT
| System of Measurement
| Inch
| Pipe Size
| 1/2"
| Finish
| Black
| Iron
| Cast Iron
| Maximum Pressure @ 72° F
| 125 psi
| Maximum Pressure Note
| For steam, maximum pressure is 125 psi @ 353° F.
| For Use With
| Schedule 40 steel nipples and pipe
| Specifications Met
| American National Standards Institute (ANSI), American Society of Mechanical Engineers (ASME), American Society for Testing and Materials (ASTM), Factory Mutual (FM), Underwriters Laboratories (UL)
| ANSI Specification
| ANSI B1.20.1
| ASME Specification
| ASME B1.20.1, ASME B16.4
| ASTM Specification
| ASTM A126 Class A
| CGF Conical Gas Fitting
teflon tape for gas sealing ---- -----gas sealing type preferred\
1/2" | 4591K12 | 1.74 | 1.56 | | | | | | | | MSDS (http://www.ionizationx.com/#)|Catalog Page (http://www.ionizationx.com/#)|Bookmark (http://www.ionizationx.com/#)Bookmarked| |
