Projects by members => Projects by members => CrazyEwok => Topic started by: CrazyEwok on February 01, 2011, 06:58:49 am
Title: Everything works!!! in theory
Post by: Login to see usernames on February 01, 2011, 06:58:49 am
Just to put this down for you all.
I have had some small success. My setup is simple but workable.
Power supply -> 555 Timer (fully adjustable) -> MOSFET -> Transformer -> small test cell.
Using the Inductance from the secondary and the capacitance of my small test cell i can hit resonance for about 2 seconds, where i see a good production, unfortunately as per my calculations as the gas is generated my capacitance decreases increasing the required frequency, my MOSFET is burning up (burnt out too) at the frequency i am using. The solution is i need a larger cell. This step is in line with my HV tests, as i found i got good production for the ampere hitting the cell except there was a lot of arcing, destroying my cell/gas production and anything near it. this is solved with this theory.
Once complete i will attempt to get the video camera off my daughter to film this and post it for you.
Title: Re: Everything works!!! in theory
Post by: Login to see usernames on February 01, 2011, 15:41:55 pm
nice,
you could simplely design your inductors so you can hit resonance in the band width you need.
How much voltage are you getting across your cell?
Post by: Login to see usernames on February 01, 2011, 16:16:55 pm
Sounds great CE!
Cannot wait to see the pics or video on it.
Can you share in detail your components?
Best regards
Post by: Login to see usernames on February 01, 2011, 17:03:32 pm
Hello Crazyewok,
You than need the pll circuit. You could use the one i proposed, you just need to make the adjustments for your frequency range. I can tell you that is very simple to use and to build.
Please tel us more about what is going on there, if you can please show us a video.
Br
Post by: Login to see usernames on February 02, 2011, 06:24:56 am
hi Steve,
555 circuit is a standard 555, both resistors are 5k pots. The second one has a diode in parallel to give me full control over pulse width. For the capacitor i have 3 trimmers in parallel so that i can adjust the frequency. I suggest anyone copying to do a spreadsheet to calculate your frequency ranges first.
The output from the 555 goes to a MOSFET i pulled out of an old electric drill i had. this switches the primary on my transformer (dismantled 120v>6v 1500ma max wall socket one). This is connected to my test cell, 2x 5cm long SS316 (i believe they are 316) tubes. Gap is about 1/2mm. My new DMM measures inductance and capacitance (along with others too!!!). According to the calculations for resonance i can just hit the 1/2 mark of my test cell with my setup. by half mark i measured capacitance with the cell in air and it in my water, lowest mark is air highest is water. I get reasonable production about equal to or just under brute force, as the cell produces more and more gas the capacitance changes and i can manually adjust the frequency to "ride" the wave to the point where my 555 (or MOSFET) can't do it any more. At this point the process dies, lasts less than 2-3 seconds of production and is fiddly. If with the increase in Capacitance i can "ride" it for longer before bottoming out i have the idea of using a water pump to force the water through the cell/s. i think this will stabilize the capacitance and decrease the amount of adjusting required on the frequency.
Seb,
I don't see the need for the PLL at the moment, i think that is a circuit that was designed to stabilize the process in the larger cell inviroment, I'm not overly interested in creating a magnificent test cell. Once concept is complete i intend to use the process to create an injector, also utilize the HV created to increase the potency of the gas created. This will mean a more precise amount of gas can be made in a shorter amount of time.
I also have an idea to greatly increase the efficiency on the primary firing side by using a cap->transformer->cap setup. Matching the bounce frequency and using the timer to "Kick" the small amount converted into heat to decrease my bottom line required energy. But that is a project for down the line :)
Till i have more,
Post by: Login to see usernames on February 02, 2011, 07:00:02 am
You are not using any diode or choke?
Ps Good idea to force the water thru the tube. But i think that if you have a very huge production the frequency will vary anyway... You could add capacitors in parallel to try stabilize.
How much gas come out in this 2 seconds? Could you make a video?
Thanks
Post by: Login to see usernames on February 02, 2011, 16:11:03 pm
Instant explosion of water using HV of a tesla coil:
http://www.youtube.com/watch?v=-EBZ81N2kX8# (http://www.youtube.com/watch?v=-EBZ81N2kX8#)
Post by: Login to see usernames on February 02, 2011, 23:01:48 pm
cool
Post by: Login to see usernames on February 04, 2011, 10:10:37 am
I have found the diode actually hinders the process, if you have a diode you actually stop the circuit from resonating (at least at this stage, there maybe some need in the future to try the diode) as the circuit works by bouncing the charge through the inductor to make the field collapse increasing the voltage potential on the plate. As for the chokes the secondary on the transformer acts as my choke in this system, with the further developments there may be the need for a dedicated choke.
 A video showing the start of resonance is not very interesting to watch. I use distilled water so that straight DC is actually quite slow (we are talking little to no production) thus when i used the circuit and got some production i was impressed enough to push on with the theory and go further.
Thanks for the Vid Alan, i have done that, blown the end out on SS tubes, done HV power supplies and lost a section of roof from my shed going down the Tesla idea. What happens is that the voltage potential is keep at max and arcs inside the HHO mix due to its low dielectric properties. HHO + Spark in a confined space is not good. This theory runs on the idea of once the voltage starts to break apart the water the voltage drops inline with production vs amps introduced to the system, also as your not forcing more amps onto the plate but letting the charge circulate through the circuit there is not the variables there to promote arcing.
Post by: Login to see usernames on February 04, 2011, 16:49:24 pm
Hi CE,
You say that you see resonance without using the diode and that you have nice production, till the FET was blown?
Post by: Login to see usernames on February 04, 2011, 19:43:56 pm
Looks like you have one side of the coin (so to speak)...nice work! (can you show a picture/ circuit)
Check http://www.ionizationx.com/index.php/topic,1305.msg18827.html#msg18827 (http://www.ionizationx.com/index.php/topic,1305.msg18827.html#msg18827)
As I can explain it what you have:
You used the secondary coil as a choke on resonance with a capacitance wfc cell?
What I think is that one part is correct (the secondary coil resonance) but chokes are needed.
This diode (aka Blocking diode) is needed to make a double pulse and creates positive and negative IMPULSES from the chokes to charge the capacitance wfc cell. The chokes limits the current and increases the voltage of the wfc cell.
The whole RLC network (VIC) are the coils (PRIM, SEC, PICKUP, CHOKE1, CHOKE2, WFC) all have inductance and capacitance seen as a RLC network on resonance.  But diode is blocking resonance into the choke... so resonance (self resonance Cp/Rs/L) is in the SEC coil. As a whole RLC network connected to the SEC it influences the SEC resonance, frequency is shifting...
The capacitance and resistance in the wfc cell are changing due the HHO production between the plates so a PLL is needed to hold it on resonance. When water is pumped through wfc cell plates HHO production is increased.
One SM cavity contains multiple wfc cells, all VIC (RLC networks) with PLLs due differences in H2O/HHO between the plates.
I think your FET is burning up, because the voltage exceeded the max. threshold voltage it could handle, due to resonance. SM said that the voltage could go as high as possible what the components can handle.
Here comes the GATE frequency, to limit/regulate the voltage and current on the SEC and also the wfc cell CHARGE.
br,
webmug
Post by: Login to see usernames on February 07, 2011, 05:44:35 am
Thanks for your reply web, just some small things to bring to light,
Firstly, the pulse doubler, I believe, is how his transformer is connected, by having the 3 secondaries, you get your first pulse from the magnetic coupling of the transformer, then as the first secondary's magnetic field collapses this causes the other secondaries to hold their magnetic fields, as the current is still flowing. Once the field has collapsed there is nothing else forcing current flow, so your other fields collapse (second pulse).
As for your theories on the diode, I am sure that there is not a lot that a diode can do except block the flow of current. Therefore i would say that it is used to hold charge on the positive plate. FYI, it has been known to happen that when i diode fails it can result as a resistor on the line rather than a diode. This would allow the current to flow in both directions but with a non determined resistance.
Some more things to understand about this method is that the amount of resistance in your cell has no bearing on your resonant frequency and thus is not part of my initial equation, the fluctuation in the capacitance of the test cell is more my main concern. I am hoping that as the circuit moves in and out of resonance that the magnetic field strength will fluctuate in strength. This will mean that i could use the strength of the magnetic field to "tune" the circuit as it produces gas.
As i said above the resistance of the cell does not effect the resonant frequency, what it does effect is the amp consumption of the circuit. This is where your efficiency calculations can come into it.
Anyone know the resistance of water? We know that the more electrolyte there is the lower its resistance, this also means the lower the voltage that the circuit will ascertain before reaction. So if the resistance of your cell is really high due to the lack of "impurities" (electrolyte) you will need a lot of "watts" to penetrate, that is why brute force electrolysis is so in-efficient. An RC circuit at resonance works like a reciprocating "tank circuit". This means that minus your loses through overcome resistance, each cycle doubles your voltage potential with no diminishing returns on your amps (minus the "consumed" amps through the resistance of your circuit). Now resistance is calculated as R=V/A (R is Resistance, V is Voltage and I is Ampere), so as you increase voltage the required amps is reduced. This works 2 fold, the resistance of your components losses are reduced as there is more volts in the circuit therefore less amps required (by required i am referring to what is commonly called "consumed"), Now back to the water, as you increase voltage your resistance drops, so the resistance in water drops. This drop in resistance continues in each cycle until all of the amps that have been accumulated by the circuit are used. This is your gas production.
Now gas production at 12v 1500ma is not a lot, but gas production at Xv @ 1500ma is quite considerable. Now why did i use "X" in the above? X represents the voltage requirement for 99% of the amps to pass through the water in the cycle time of the circuit. the remaining 1% (and arbitrary number) is to maintain the voltage level in the process. If all of the amps are allowed to pass through the cell the voltage level will drop and you will need to bring it up again.
Now if this is what Stan was doing, his disclosed work is over 10 steps ahead of me in increasing its efficiency. But I, like everyone else, don't know and understand his work to the point of replication successfully. So i have taken a different line. I have looked and read his patents, gone through all of his work i could find and isolated what i think is the "core" method used. Now i am testing my idea. All my notes and "theories" on this i am posting here for reference and to log it in for everyone to see.
Post by: Login to see usernames on February 11, 2011, 18:08:38 pm
the goal is to restrict amps
there are many ways to do this, thus different methods, and different systems
ex
... custom resistor
... pulsing under leakage threshold (voltage control)
... disconnecting power supply upon amp surge
... using magnetic field (inductive reactance)
all of the above are common principles in electrical circuits, which is why he says it in the patents, and mentions them in videos, but does not patent them specifically!
go to the common electrical principles and this stuff makes more sense, Stan was learning over the years, so we have to learn too, and he wasn't learning about wfc secrets, he was learning about electronics and electrical systems, and then he put these into practice
he says variations will be evident to those that are skilled in the art, what does he mean? other wfc inventors? or other people skilled in the art of electrical engineering and physics?
when you get into the art, his diagrams and stuff look exactly like the diagrams in the text books
maybe you need new physics to explain the process, but you don't need new electronics to build it
the only difference between Stan's education and a common engineer/scientist is that he went and learned exactly what he needed to, and didn't care about the "full degree program" and graduating with an expensive piece of paper
for example, the 3-23 VIC is KISS, just the required coils on the core with the desired design properties (not saying it's 'easy', but if you understood the design principles then it would be 'simple')
the 6-1 VIC is an advanced design, not-so-KISS, but if you break down the principles, then it's still as KISS as it possibly can be, but you have to learn the desired principles before you go engineering your own advanced systems
Post by: Login to see usernames on February 14, 2011, 05:41:52 am
Hi Donald, Good pick up but in my understanding, this has multiple meanings and by itself has multiple meanings. In his patents, there is one on the method itself, there is a chart relating to the quality of the water and the ampflow that we required/pulled.
ex
... custom resistor
These above all have different side effects; custom resistor - defeats the Kiss principal and would be difficult to get correct; Pulsing under leakage voltage -  this would rule out his "voltrolysis" theory, also as you increase voltage you decrease ampere resistance; Disconnecting the power supply - i assume you are referring to some sort of self healing fuse; using a magnetic field - You might want to read up on this, Inductive resistance doesn't "restrict" amp flow it actually "restricts" change in amp flow.
This i agree with to some degree, he hasn't discovered a new process, he has simply found a new use for something already known but not implemented. You are assuming that this is something that comes under electrical systems broad area of knowledge, wasn't Mr Meyers a Radio communications engineer for the army?
Variations will be once someone understands the process there will be multiple ways to accomplish it. "there is more than one way to skin a cat"
This i will argue, did you know there is different laws of physics for each sub-division, and the "laws of physics" are blanket policies. More a revert to answer then a definite. No new laws needed just more sharing of information.
Its a common thought that he went to university to talk to A.P. not to study anything.
Can't comment on this as I believe that there is more here then we understand (well duh moment). But as said before i have a theory, which is well explained above.
As this last weekend saw zero improvement to my project as my partner decided we needed some new additions to our walls from IKEA I will update once this gets underway, will try for some photo's too.
Post by: Login to see usernames on February 14, 2011, 16:46:24 pm
Yes Stan worked in the military on some radar type things, and that is exactly the kind of concepts he was using for the VIC, just like Webmug posted the other day, a link to a book about Pulse forming Networks, used in radar and microwave power supplies, all the electronic theory is there about resonant charging chokes and blocking diodes and pulse frequency doubling and everything, the thing is he used these principles in a power system designed to power the wfc as a resonant cavity, instead of a microwave power system that operates a magnetron which is a resonant cavity of a different design at a different frequency.
Inductive Reactance is only one thing in the equation, when you hit resonance the impedance becomes infinity, because you add the inductor and capacitor reactance in parallel which gives you 1/0 = infinity, (look up the equation, it's the same for resistors in parallel), but this is for the 3-23 VIC which I am not working on right now.
Right now my focus is school, but next on the list is the previously listed method, as described here:
This is excited by a high power pulse generator which, together with the cell capacitance and a rectifier diode, forms a charge pump circuit. High frequency pulses build a rising staircase DC potential across the electrodes of the cell until a point is reached where the water breaks down and a momentary high current flows. A current measuring circuit in the supply detects this breakdown and removes the pulse drive for a few cycles allowing the water to "recover".
Read more here: http://www.ionizationx.com/index.php?topic=1268.msg13450#msg13450 (http://www.ionizationx.com/index.php?topic=1268.msg13450#msg13450)
Post by: Login to see usernames on February 15, 2011, 05:32:08 am
to Donald,
Radar type things, also you are saying that "this is exactly what he was doing", if i had a dollar every time someone said that... You may think that is what he was doing but until you replicate it you won't know. Also you assume a lot from other peoples posts. School is a good place to concentrate, you may learn to skip the B & C steps there, I need the B & C steps.
I am not copying other members ideas or projects. I put down the method that i am testing with the principals, also a brief description of what is happening. If you feel what you are saying is how the system works then  that is a discussion for you own thread. All I am putting down is the proof of concept before further development. Now if the concept of OU production through circuit resonance is how it works then i should see it here. Maybe not 1700x over unity but if i can get to 130% or higher that would be enough to further look into improving it. While i understand that you have strong feelings about your method I encourage you to go down that path. My understanding is that every process or reaction runs on a principal, adjusting and slightly modifying a principal to promote the ideal environment for what your trying to achieve will always be better than just proof of concept.
Update to my project, I need to purchase some more bits for my Dremmel to finish the edges off<to note on this even in testing situations you will need to clean up anywhere you have made cuts into S/Steel, the cuts splinter and can create small spikes, a simple sanding stone can clean these up for you. I like to bevel the edges to a blunt point to ensure that it can't interfere with your calculations>. Once complete i will remeasure combined Capacitance and set it up with my setup to see if i can hit a nice point of resonance to show everyone.
Post by: Login to see usernames on February 21, 2011, 05:40:29 am
Update, I am having construction issues that maybe someone here can help with. As this is only a test cell I am looking for proving a concept not trying to win any cell building awards.
With a single cell i had exposed wire wrapped around the external tube and a split pin spread out with a wire connected to make the connection to the inner tube. This worked fine for a single cell. Now i need to connect all of them in parallel. This will also need to be encased in the water container. NOw here lies the issue, all exposed connections must be "contained" within their alloted fields (in other words no direct lines between opposing charges, as this causes leakage and an unreliable connection. if the connecting wires are too long the measurable capacitance is not stable.
I am trouble shooting some ideas but i keep running into too much leakage or the capacitance isn't stable enough to work with. Any ideas here would be nice, at this stage i am considering a water tight base and running the connections through there. this will require more construction time then i would of hopped for.
Post by: Login to see usernames on March 11, 2011, 05:25:48 am
Understanding your process prior to implementing it is a big thing i am pushing here. I would like anyone following my work to look at and read the "how" of the following 2 electronic circuits,
1. LC resonance (or LCR) - this is interesting and where I am building now.
2. Buck-Boost Circuit - Inductor - DIODE - Cap - back to inductor.
Now in these examples it talks about inductors as a separate entity, the secondary in a transformer can be used as an inductor, except its magnetic field can be "created" by the primary charging.
No. 2 above has started the explanation to the use of the diode in Stans patent. My only question is to the why??? as No.1 is more efficient in obtaining what he is talking about. Also with number 2 the "resonant" frequency is more a math based on the inductance of your secondary over the application of the circuit.
Number 1 cannot resonant with a diode in the mix as it requires the circuit to oscillate.
Update to my previous post,
I am making a new frequency controller over a new cell. i hope that this will fix my problem.
Post by: Login to see usernames on March 11, 2011, 07:51:33 am
Well the VIC will resonate with the blocking diode in the circuit, check my thread.
Br,
Webmug
Post by: Login to see usernames on March 11, 2011, 07:56:02 am
Web,
The VIC is different to the 2 advised circuits.
Also you may find that there is frequencies that work better with the Buck boost as they work in harmony with the permeability of the inductance core. If that is what is happening with your VIC resonance you will find that you can adjust the duty cycle and your resonant frequency will change.
Post by: Login to see usernames on April 14, 2011, 06:50:39 am
Well an update to how things are progressing,
Understanding the whole process of resonating a circuit is more than knowing the frequency! Stans pick-up coil I now understand a possible purpose and system of use! but his location (well as per these forums understanding) is a little less accurate then i would use... the pick up coil is to measure timing of when the resonant pulse "should" fire. I am trying to figure out a circuit that will work the way i want.
Simple method would be a set of pick ups from the primary and a set from the pick up. The idea would be if the Primary is + before the pickup is, you need to slow the frequency if the pick up is + before the primary you need to speed it up. So a small circuit will need to be designed to adjust the resistance of the 2 resistors on the 555 Square wave.
Thats all very well and good, we know we need a pick up. Well i thought i would let you all in on this as you will need to place the pick up coil near your secondary/ies as you want it to pick up the resonant cycle time as soon as it hits your secondary.
I hope this helps people out if they are looking at circuit resonance.
