General => General Discussion => Topic started by: outlawstc on July 10, 2010, 19:38:49 pm
Title: The Master Plan
Post by: Login to see usernames on July 10, 2010, 19:38:49 pm
hello all, i have been doing much thinking..  from what i can see from where i stand now is there isnt any reason to replicate stans circuits. at least the ones used to attain the patents.. i think we should interface the optocouplers that drive the output to the usb..  this will give us a way more versatile platform for a wide range experiments..
i think if we can figure out how to control the optos and also how to send a feedback into the usb then maybe one day we could apply a resonant scanning software...
also i would like to be able to apply the ancient tones in high power switching..
UT – 396 Hz – Liberating Guilt and Fear
    RE – 417 Hz – Undoing Situations and Facilitating Change
    MI – 528 Hz – Transformation and Miracles (DNA Repair)
    FA – 639 Hz – Connecting/Relationships
    SOL – 741 Hz – Awakening Intuition
    LA – 852 Hz – Returning to Spiritual Order
when stan says pulsed in sequential mode it makes me think of this.. lets say you are applying 8 volts and you had your frequency pulsed in a sequence such as this set above. lets say its a 50 percent duty for all frequencys.. the first one is 396 this frequency will have a longer on time and off time then all the others it is the lowest freq..  852 will have the shortest on and off time then all them.. both being repiticious they have a difference of 456 pulses.. the question is what are the characteristics of a coil current that is having such a sequence applied??
here is a cool site i found that has a bunch of usb circuits for sale..    http://www.j-works.com/index.php
Title: Re: The Master Plan
Post by: Login to see usernames on July 10, 2010, 20:58:36 pm
http://www.j-works.com/csb1622.php
Post by: Login to see usernames on July 12, 2010, 05:53:53 am
So VVTF are you waiting for ?
You take 6 cd4047 with tuned freq , you take a multiplexer , you take a mosfet driver , you take a MOSFETS . If your really smart you can do this with logic gates , that wouldnt be a shortcut however . An idea just popped in my head but I am too lazy to think it throught , this requires too much mental effort you see ...
I let you figure out the rest , nobody will figure this out for you trust me , read up ,  google up .
Forget the forums, you are invisible to them and will be treated like a incompetent monkey  unless you ask a very specific question .
Post by: Login to see usernames on July 13, 2010, 02:26:29 am
lol dankie and the 2 cents.. maybe im writing this for my self maybe these are some of my side notes...
24                                         Programmable Digital I/O Pins from your                                         USB Port
(http://www.hobbyengineering.com/pics/i3387-200x104.jpg)
http://www.elexol.com/IO_Modules/USB_IO_24.php
http://www.hobbyengineering.com/H3387.html
Post by: Login to see usernames on July 13, 2010, 03:41:55 am
So what u waitin for , do it ...
Post by: Login to see usernames on July 13, 2010, 07:12:59 am
keep reporting regardless of results outlaw... Think of it as the Edison Method "I learned 10,000 ways, how NOT to make a light bulb" you do 5 someone else does 5 etc etc till someone reads them all and comes up with the 10,001 method that we were all trying to do :)
As for Dankie... As displeasing as it is too see his "forum entertainer" badge gone it still rings true... I look forward to your results on the matter.
Post by: Login to see usernames on July 13, 2010, 14:24:42 pm
i agree ewok... im gonna look into this situation some  more and maybe get one of these to play with in the near future.
dankie, i think you have painted your potrait well this year.  dankie do you know what the number one demotivating thing is to ones progression? anothers negative visions.. well at least for most who dont understand power.. me i see you as kinda childish now... i see you wearing the jesters funny hat but you are not funny.. you where the hat because you feel like you are funny with your insights   you choose negative collaborations to resonante you aka impower.. you say things like you gonna have to do it on ur own cause no one is gonna help you... i dont beleive that one.. that is a normal situation for somone who is a A hole to others, which is not me..
"its a univeral melody possessing you and me universal magnetic never ending reaction proppelling actions reaching for satisfaton"
Post by: Login to see usernames on July 13, 2010, 15:19:29 pm
A digital or computer controlled oscillator or pll circuit is not going to make you find the OU frequency generators are so simple and even the pll that stan provided...
my proposed circuitry can be build with much easy the only thing it miss is a mean to control the output current but this can be done easily adding an inductor in series with the primary or resistance...
Just to remember
you will have resonance whenever you have a circuit where you can accumulate energy, (except batteries) springs, magnetic spring , pendulums, inductors (positive reactance _XL) + capacitors (negative reactance_ -XC)
Post by: Login to see usernames on July 14, 2010, 05:59:26 am
Why ask for help instead of learning the ropes ?
If you get demotivated by others opinions than you aint stopped bein demotivated .
Post by: Login to see usernames on July 14, 2010, 06:52:59 am
Dankie... as a member that jumps from idea to idea claimin importance before testing, also as someone who shares nothing of relative importance other than "i have the answer but it is patent pending so i'm not showing anyone"... Your very opinionated on what is worth someones time... With your opinion you might want to check what the boards are about before attempting to demotivate someone.
IMO i find your opinions vapid and conceeded. Your "discoveries" as mainly self propelled hype and your proposed experiments broad and always inconclusive, if they are every finished.
As a quote from a very mediocre movie "i can't go straight from A to D... i need the B and C" applies to pretty much everyone here on these boards you seem to be the only one who doesn't get it, or thinks it doesn't apply to them. As this isn't the fight board i'm going to leave it there...
Outlaw,
I am interested in your frequency results regardless of what the Jester is doing!
Post by: Login to see usernames on July 14, 2010, 07:35:50 am
You know what my projects are , I dont know VVTF you are talking about .
Nobody can tell me anything about not sharing enough or not doing enough for the public forums .
Post by: Login to see usernames on July 14, 2010, 14:48:05 pm
dankie we know that nobody can tell you anything because you are in your own conceded world.. i would like to put in a request that you do not participate on my threads anymore.. i am not interested in the peanut gallery on my threads.. I'm honestly sick of your non pro remarks that do not resonante motivation in the proper direction for most.. you do not effect my motivation dankie i can not be manipulated by your jargon. just aggravated
Post by: Login to see usernames on July 14, 2010, 14:51:33 pm
Post by: Login to see usernames on July 16, 2010, 07:33:59 am
must be the nth time i have seen that video linked!!! sometimes i wish i lived in the states to go to some of the stuff there but its a little more expensive to fly from down under
Post by: Login to see usernames on July 16, 2010, 08:42:38 am
These frequencies this guy is talking about in the video where not discovered by him...Henry Puharich talks about these types of frequencies in his unpublished book.  As Puharich discovered that an 8Hz Magnetic B-wave will tell the body to repair its DNA and he also discovered that this same 8Hz frequency was present in his water splitter device.  He says it is one of the main components aiding in splitting the water molecule. Puharich also noted that when splitting water, this 8Hz B-wave would create tiny organisms in pure water. The 8Hz frequencies in the water splitter where sidebands created by the main AM frequencies. He gives the resonant frequency of his system as 600Hz. The 600Hz is the center frequency, or Wr, and the +Delta W is 360Hz and the -Delta W is 720Hz...these two frequencies cross paths around 512Hz which creates the 8Hz B-wave frequency. Ok had to add my 2 cents  ;D
Post by: Login to see usernames on July 16, 2010, 09:51:57 am
I worked with the 8hz frequentie in the past on another project.
This is like the schumann earth frequency 7.8hz till 8hz, depending where you life on earth.
This frequency is for repairing / regeneration of cells of all living creatures on earth.
Not sure if it is helpfull in destroying molecules of water.
It should do the opposite in my opinion...
Post by: Login to see usernames on July 17, 2010, 04:00:16 am
The 8Hz B-wave puts a charge on the water molecule and causes the molecule to hold this charge for long periods of time enabling it to build up to high voltages.
Post by: Login to see usernames on July 17, 2010, 07:04:16 am
Word of Encouragement
Hi Guys and Gals . My name is Peter B . Im from "Down Under . The Best country for at least 10 000 km . Australia ( of course) lol  ( NZ is an Island , so it doesnt count )  ;D
Ive been reading some of your posts for the last few days and I just wanted to say , " More power to you "  You guys are doing a fantastic thing . Co-operating together for a common goal .  This planet is going to have a better , cleaner  future because of people like you .
If there is anyway I can help let me know , especially if your in Australia . My job now  as a caretaker , allows me a lot of time to do research  and I have a deal with telstra so phone calls are cheap . Money is tight but time is plentiful . I have a carpentry \ builders background . I would love to help if I can . Big or small things  . I dont think Im up to building what you guys are doing . But I would like to play a part .
Keep up the great work folks . My Great Grand children are going to have a bright future because of your  efforts .   Thank you
Post by: Login to see usernames on July 17, 2010, 10:17:11 am
Welcome to IonizationX, H2G!
And thank you for your kind words :)
Lets make it a green and clean world together.
We like builders here. If you need any info, just ask.
Best regards
btw
Not sure if the kiwi's agree with you... ;)
Post by: Login to see usernames on July 17, 2010, 20:39:19 pm
welcome h2g
happy to have you aboard.. feel free to share your ideas and questions we are all students and teachers on this journey called life, at least under the laws of nature.. hot and cold, day and night, teacher and student......
