Off Topic => World News and political stuff => Topic started by: outlawstc on February 24, 2010, 23:06:07 pm
this is a 4hour and some odd minite video of morko explaining vortex energy and his coil design.. very different and new territory..
http://video.google.com/videoplay?docid=-7911972442098545165#
This seems like there's lots of potential.
Its also not out of site to make.
Over at EnergeticForum they got some good Rodin info and Stubbs is doing pretty good stuff.
Guess there's a couple ways to make it but with a iron or ferrite core it seems it has more overall strength.
Might be worth looking into.
Thanks outlawstc
Thats a long video but an interesting subject.
stan says that when you first introduce the pulsing of gaining resistive potentials to the plates they themselves will magnetically polarize north and south... im guessing the positive plate due to it pulling electrons will have opposite electron spin AND orbital oscillating direction then the negative plate. imagine how the opposite spins can help to add energy in the form of velocity to orbital electrons of water..
ok another quick observation. marko rodin when putting a non magnitized drill bit into the center of his coil turned it into a monopole.. it showed a north polarity on one end and the other had no pole at all!! i find this relative to stans idea of unipolar (1 polarity pulsing.. )
so all in all i think you can say that markos geometrical electrical design creates the perfect aperture for pulsing atoms and is a aether pump.
ok you math whizzes i am finding more crazy relations between stans alternator to the rodin design. he explains that nature can be represented by numbers..
the rodn coil has bifilar coils as does the alternator.. there is gaps between bifilars of the rodin coil and they are considered a aetheric path on the coil..
with the the alternator i think may be related to the secondarys involvment in the circuit?
he explains the bifilars are represented with the sequence 124875flowing one way in a bifilar while the other is exact opposite 578421 in the other
pretend these numbers are wires horizontal and rep phase potential
1248751248751248751248751
1578421578421578421578241
6693396693396693396693396
5124875124875124875124875
2157842157842157842157824
9669339669339669339669339
now imagine these numbers as 2 sets of bifilars which are the 124875 an 578421 and the other 9339669 is the aetheric fluxuation around the rodin coil... also see this cube of numbers like a checker board of opposite polarities ex .+1-2+4-8+7-5 and +5-7+8-4+2-1
these numbers represent a doubling circuit i suppose 1 doubled is 2. 2 doubled is 4. 4 doubles is 8... 8 doubled is 16.....1+6= 7 and thats where the number 7 comes from then 7 doubled is 7+7= 14 which is 1+4 and thats the repesentation of 5
the number 9 some how relates to the axis of the atom...
to picture the number nine as a part of a yin yang its the curving line in the middle while the white and black dots are 3 and 6 in relation to the big picture.. im still trying to grasp it all and see how much it relates... all these numbers can be laid out in a clock like pattern
the alternator has 12 loops per phase 1+2= 3
it has 36 cavitys in all 3+6=9
it has bifilars placed parallel to each other around the core each spaced 30 degrees from center 3+0=3
the rotary vic alternator has stacked layers in a reps of bilf, sec, bilf, sec, bilf, sec.
this may have no relation... he explains his toroid to operate under perfect electrical sequence that doesnt deal with resistance due to out of phase relationship with other wires or somthin like that.
I sort of see where you are trying to go but I don't think it will happen the same way as the Rodin coil.
369 on the alternator are used within the coils so there's no aetherteric force unless you find another winding method and relate it to the alternator somehow.
That would be very interesting. Maybe by taking winding 3 out for a start, seems relateable to Rodins coil paired 1&2 bifilars.
You got 36 wells and 6 fingers of each positive and negative on a rotor. 6+6=12 = 3
Its like 6 becomes your ying and yang not 9. So what about a 18 pole 9 north 9 south rotor, does it exist?
If you gave it some more thought maybe a new mathematical rewind.
Because like you say it has some relation to numbers that match, and quit possibly in another way.
Makes me wonder about taking out winding 3 and whether that empty space can have aetherteric forces eminate from it?
yea taking out 3 may allow for some sort of aetheric flow maybe..
what im seeing is the rodin coil has a figure 8 wind with a flow like this >8< which is like the photo on bubs thread.. energy aperture of the atom.. all the coils around the stator are flowing like that in a sense ... i think the rotor is pumping the field and the coil contributes once energized?
my rotor has 6 north and 6 south.. 6+6=12 which is another 3 so there is the number 6 involves in the rotor and 3 .... 9 in the stator of 36 cavities.. 3 wires in each phase is 9 wires total having 18 ends which is 9.
now this is just coincidence but i wound my coils 30 loops each which is 3 and since theres loops of 30 and there is 12 i have 360 winds per wire which is 9.. a total of 3240 for all winds which is 9.. if there are any harmonics in relation to wind count i may of lucked it..
i finished installing the wire on my stator yesterday and it sure looks perty.
coral castles code to the universe is
7129
6105195
7+1+2+9= 19 so 1+9=10 and 1+0 is 1
6+1+0+5+1+9+5= 27 and 2+7=9
1/9 ???
somebody else who has found revelence in this code broke it down into sections like this
7 129
6 105 195
this will show
7 3
6 6 6
now thats freaky
7+3= 1
6+6+6= 18 which is 9 and you end up with 1/9 again.
Funny thing about the 30 winds per loop.
That 27 winds per loop = 324 turns = 9
2+7=9
9+9=18=9
So 27 also is a good number.
All combinations of winds with the number 3 seem to add up to 9.
Here's something else that may have consideration thats been on my mind for a little while.
What is you wound coils for each phase as done with bifilars no change there but......
Okay you got 30 winds on coil one, 27 or so on coil 2, 24 or so on coil 3. A system like that.
The voltage has created a step, sort of a forced step.
Sounds interesting to me. Thats another off-shoot.
i wanted to share this visualization i drew up yesterday.. ever since i stumbled across rodins work i have been in search of a deeper understanding... rodin says that 369 pattern is spirits (aether) paths while electric travels in 124875 pattern in opposite direction..
he explains that 9 is center and represents the dividing line in the yin yang.. he says 3 and 6 are the good and evil dots in the yin yang.. 3 would be the white dot and 6 would be the black dot.. this to me means that 9 is a mirror.. 3 is opposite of 6
(http://www.vitamincity.com/pix%20rodin/Symbol_Of_Enlightenment_Aet.gif)
here is a perfect example of how 9 has somthing to do with center.. if you were to observe the multiples of 9 up to 10 you can see it holds some significance to number centers and a balance..
09,18,27,36,45,54,63,72,81,90
in this example center is between 45 and 54.. 09,18,27,36,45(center)54,63,72,81,90
the center is a mirror 09 is a mirror of 90, 18 is of 81, 27 is 72, 36 is 63 and 45 is 54.
so i decided to see what it looks like to 100
1 2 3 4 5 6 7 8 9 10
1-10 [09 18 27 36 45 {} 54 63 72 81 90]
11-20 {99} [108 117 126 135 {144} 153 162 171 180]
21-30 [189 {} 198] [207 216 225 234 {} 243 252 261 270]
31-40 [279 {288} 297] [306 315 324 {333} 342 351 360]
41-50 [369 378 {} 387 396] [405 414 423 {} 432 441 450]
51-60 [459 468 {477} 486 495] [504 513 {522} 531 540]
61-70 [549 558 567 {} 576 585 594] [603 612 {} 621 630]
71-80 [639 648 657 {666} 675 684 693] [ 702 {711} 720]
81-90 [729 738 747 756 {} 765 774 783 792] [801 {} 810]
91-100 [819 828 837 846 {855} 864 873 882 891] [900]
what i did in the above numbers is symbolized the groups of mirroring numbers.. the outside of these sets are symbolized by the [ and ] while the center of each set is represented by { and }
what i beleive this number chart symbolizes is the yin yang in numbers.. it a perfect square of numbering being 10x 10.. now your probably wounder why i relate this to yin and yang in numbers..
if you look at the groups of mirrored numbers they make a perfect diagonal cut in the numbers fro 09 to 900 dividing the 100 squares into 2 triangles. the diagonal cut is like the center dividing line of the yin yang.. now if you look even closer you will notice that one triangle center number is 666 while the other side is 333...
i find it neat that these numbers show it and im also curious to what other clues it may hold to the sequencing current and electric... since stan does claim to pulse water in a sequential mode..
What should it suppose to do, this coil?
Hi I have all of rondins stuff not had time to look at it much, lots of math
I tried to post but it went over the charter ammount so if any one is interested let me kno, steve I could put it all in a file and email it to you if you want.
aussepom
hi for those who beleive
I stunmbled on this I will see itf it will fit.
God code
GREGG BRADEN'S
"GOD CODE"
An English Alphabet Code Analysis
By Gary Val Tenuta
©2005, Gary Val Tenuta
Brief Introduction:
Gregg Braden claims to have found a message encoded into the human DNA. The message reads "God eternal within the body" or, alternatively, "God within the body" (For a detailed account of his methodology see his book, The God Code). Suffice to say, for this brief abstract, his methodology included the use of gematria as related to the Hebrew alphabet/language. Now, using what may be thought of as English gematria, or what I call CryptoNumerology, we find support for Gregg's claim. The system used here is the simple English Alphabet Code (EAC) of A=1 through Z=26 (For a detailed explanation of what CryptoNumerology is and how/why it works see CryptoNumerology: How and Why It Works). Using this system, words and phrases are converted into numbers by calculating the sum of the letter values. For reasons too complex to explain here, the value of the number 9 has a long history of significance in sacred texts, sacred geometry, Pythagorian mathematics, and mythological lore. The single digit value of 9 is often "hidden" within larger numbers. For example, the well known "666" from the book of Revelation in the Bible reduces to 9 by the method known as "cross-adding". This simply means calculating the sum of the individual intigers in the number until only a single digit remains: 6+6+6=18, then 1+8=9.
Notice all the number values in the work shown below reduce to the single digit value of 9. This is important, especially in the case of this "God Code" analysis, because:
NINE IS THE KEY= 144 = THE SECRET KEY
DOUBLE HELIX CODE = 144 = JEHOVAH ETERNAL
The number 144 is itself an important sacred number. Esoterically, it is thought to be associated with the concept of "light". This is interesting as it is generally accepted that the Great Pyramid was originally covered with 144,000 sheets of highly polished limestone, thus causing the pyramid to gleam like a "light" in the bright sun and could be seen for many miles. The number 144,000 is also significant in the book of Revelations, not to mention it appears as one of the significant numbers in the ancient Mayan system of calendar reckoning. These are just a few examples to demonstrate the importance of the number 144,000 and the harmonic 144.
Lastly, to answer the objection that there are many words and phrases which can generate these same numbers and that many of those words and phrases will have nothing in common with each other, conceptually, I should introduce the notion of what I call "Case Relatedness". Simply this means that when using CryptoNumerology to explore any given subject, I focus only on words and phrases which are, in some recognizable way, associated with each other in terms of concept and/or meaning. These are case-related words and phrases. This reduces the probability of chance in terms of matching alphanumeric values. This idea is not without precedence as it was also used in the gematria of Hebrew and Greek tradition.
With that brief introduction, the following work demonstrates how Braden's claim of a message ("God eternal within the body"), encoded in the DNA, is supported by the English Alphabet Code of CryptoNumerology.
We begin with a stunning corroboration of Braden's discovery as we find the scientific name for DNA (Deoxybribose Nucleic Acid) associated with three key "case related" phrases which include the original Hebrew spelling of the name of God, YHVH (transliterated, Yahweh) and a number value that reduces to 9. This is followed immediately by another alphanumeric equation in which the phrase "Christ Consciousness" is included. (Note: The appearance of the word "Christ" in this context may not necessarily be a direct reference to the religious figure known as Jesus. The exact phrase is "Christ Consciousness", indicating a level or dimension of consciousness rather than a specific person.)
_____________________________________________
YHVH WITHIN THE BODY = 225 = DEOXYRIBOSE NUCLEIC ACID =
NINE IS AN ORGANIC NUMBER = YHVH CODE WITHIN THE DNA
DEOXYRIBOSE NUCLEIC ACID CODE = 252 = CHRIST CONSCIOUSNESS
Again, note that each of these alphanumeric values reduces to 9.
JEHOVAH ETERNAL WITHIN THE BODY = 306 = 9
Note: Jehovah, of course, is yet another variation on the name Yahweh from the Hebrew root YHVH. The letters YHVH, by the way, have an English Alphabet Code value of 63 which also reduces to 9. Furthermore, we find the value of the word GENETIC is 63 and the value of the phrase GENETIC CODE is 90.
GOD IS WITHIN THE BODY = 216
THE CODE WITHIN DNA = 162 = WITHIN THE BODY
YHVH CODE = 90 = DIVINE CODE
YHVH CODE WITHIN THE BODY = 252 = DIVINE CODE WITHIN THE BODY = CHRIST CONSCIOUSNESS = DEOXYRIBOSE NUCLEIC ACID CODE
YHVH WITHIN THE DNA = 198 = THE GOLDEN MEAN SPIRAL =
THE FEMALE NUMBER = THE RESURRECTION = THE NINE SACRED TONES =
THREE SIX NINE CYCLE
Note: The equations above introduce the concept of "tone" into the mix. Tones or sounds suggests "frequency" and "vibration". More of this follows.
THE THREE SIX NINE CYCLE IS THE KEY = 333 = THE SOURCE OF CREATIVE INTELLIGENCE = THE VIBRATIONAL FREQUENCY OF NINE
Also, from http://members.aol.com/MetPhys/100electronscale.html
we find the following information:
<< The E flat note at 639 Hz is close to the frequency of the kung note in the Chinese system of music. According to David Tame, "this foundation note was considered to be the earthly manifestation of divine will, and a sacred, eternal principle, upon which was based the proportional system (the weight, size and tone of all things) of the entire state." (69) If the kung was wrong, civilization would decline. Unfortunately, the ruler of each dynasty changed the value for the kung because they reasoned that if the previous dynasty had been right, it wouldn't have ended. The last Chinese dynasty put the kung at 601.5 Hz, a D. They were wrong.
The central role of the E flat note was pointed out by Barbara Hero in her collection of musings and sketches on the mystical aspects of music, Eyes + Ears = Ideas. She found that it was at the beginning, end, or other key locations in 18 different musical, mathematical or metaphysical patterns. She wrote, "It's the place at which we find the beginning of life, and the fastest musical pulse of the thirty second note... It becomes the boundary of the end of the time where space begins... it is at the limit of the macrocosmos."
To fully explain the significance of what Barbara Hero wrote above is beyond the scope of this newsletter. If you are intrigued, I would recommend that you get the book. It is available to read on-line but unfortunately the illustrations are illegible. Suffice it to say that the E flat note at 639 Hz corresponds to the kung note and to "Aum," the cosmic tone of Brahma, the creator. I am not saying that 639 Hz is the actual frequency of the tone of creation. It is the octave of that tone which the human voice can recite comfortably. >>
Note: Some researchers have suggested that sound can be used as a healing tool. With this in mind we find familiar numbers associated with these case-related phrases:
THE HEALING TONES = 162 = THE THREE TONES = HARMONIC SOURCE = GOD IS THOUGHT
ONE SIX TWO = 144
THE DNA HEALING CODE = 135
CIRCLE OF TONES = 144 = THE HUMAN TONE = SIX NUMBERS
SIXTH NUMBER = 153 = FLESH BLOOD AND BONE = TETRAGRAMATON = HARMONIC WORLD =
THE GOLDEN RATIO = THE KINGDOM OF GOD
YHVH = 63 = DIVINE
The following are phrases from John 1: 1-14 in the King James Bible:
"The Word was with God"
"The Word was God"
The Word was made Flesh"
We know, from previous work, that VOICE = 54 = TONE. The verse from the book of John suggests that God "spoke". This implies "voice" which suggests sound or tone. We also know, from previous work, that VOICE OF JEHOVAH = 144. These self referencing number/concept matches suggest a good reason to substitute "tone" for "word" in the Bible verse. When we do that, we find the alphanumeric value of this entire section of verse comes to 594 (an important number in its own right for reasons too extensive to go into here) and we also see the familiar code number, 216, within the structure:
THE TONE WAS WITH GOD = 216
THE TONE WAS GOD = 175
THE TONE WAS MADE FLESH = 203
216 + 175 + 203 = 594
FIVE NINE FOUR = 144 = SIX NUMBERS
What can the phrase, "SIX NUMBERS" possibly refer to? The following may provide an answer.
In the AlphaNumber Table that I devised a few years ago I converted the numbers 0 through 9 into what I call "AlphaNumbers". That is to say, I converted the numbers into words (i.e., ZERO through NINE) and calculated the alphanumeric values of each. I found that these AlphaNumbers could be divided into sets according to how many letters were in each AlphaNumber. The 3-letter set is ONE-TWO-SIX. The 4-letter set is FOUR-FIVE-NINE (Of course ZERO also has 4 letters but it is a special case and not included in the 4-letter set). Without going into detail regarding the entire AlphaNumber Table suffice to say, for the sake of this discussion, that the alphanumeric value of each of these two sets of AlphaNumbers (ONE-TWO-SIX and FOUR-FIVE-NINE) is 144. These are the only sets of AlphaNumbers with that value. Since 144 is a significant sacred number it suggests there may be something special about these two sets. Notice these two sets are comprised of three AlphaNumbers each, thus giving us "SIX NUMBERS".
Maybe the six mystery numbers are 1 2 6 4 5 9 in some sequence.
ONE TWO SIX FOUR FIVE NINE = 288 = 144x2
Now, admittedly the next phrase is not quite grammatically correct and yet could be construed as having a particular meaning in its apparent ungrammatical form. In any case, the value of the phrase is striking, given the current discussion:
ONE TWO SIX FOUR FIVE NINE ARE THE KEY NUMBER = 459
With the use of the word "are", one would expect to see the plural, "numbers". However, given the alphanumeric value that the phrase produces, perhaps the message is that these are to be considered as a single number rather than as separate numbers. The single number, comprised of six digits, would be 126459 or some sequence of those digits. I don't know. It's only a suggestion at this point. However, this is interesting:
1+2+6+4+5+9 = 27 = CODE
Let us continue now to see more of these case-related phrases and how they fall into line with Braden's apparent discovery of a message encoded in our DNA:
SIX IS THE CREATION TONE = 252 = CHRIST CONSCIOUSNESS = DEOXYRIBOSE NUCLEIC ACID CODE
FOUR FIVE NINE ARE THE HOLOGRAPHIC NUMBERS = 405
FOUR IS THE HOLOGRAPHIC NUMBER = 306 = JEHOVAH ETERNAL WITHIN THE BODY
FIVE IS THE HOLOGRAPHIC NUMBER = 288
NINE IS THE HOLOGRAPHIC NUMBER = 288
306 + 288 + 288 = 882 (reverse of 288)
And likewise:
ONE TWO SIX ARE THE HOLOGRAPHIC NUMBERS = 405
ONE IS THE HOLOGRAPHIC NUMBER = 280
TWO IS THE HOLOGRAPHIC NUMBER = 304
SIX IS THE HOLOGRAPHIC NUMBER = 298
280 + 304 + 298 = 882 (reverse of 288)
What does the notion of "holographic" have to do with DNA? In Michael Talbot's remarkable book, The Holographic Universe, he presents several arguments by reknown quantum physicists and neurobiologists postulating that the human brain operates on holographic principles. If this is true then surely the DNA by which the brain structure and function is determined must also contain the principles upon which a hologram works. We know that a hologram is an information storing system. Interestingly, our CryptoNumerology by way of the English Alphabet Code supports this notion:
DNA IS AN INFORMATION SYSTEM CREATED BY INTELLIGENCE = 495
FOUR NINE FIVE = 144
DNA IS A HOLOGRAPHIC SYSTEM = 261
TWO SIX ONE = 144
HOLOGRAPHIC UNIVERSE = 225 = DEOXYRIBOSE NUCLEIC ACID CODE = DOUBLE HELIX GEOMETRY
GEOMETRY OF THE DOUBLE HELIX = 279
GEOMETRY CODE OF THE DOUBLE HELIX = 306 =
THE SPIRAL CODE = 135 = THE DNA HEALING CODE
THE DNA HEALING CODE GEOMETRY = 243
THE SPIRAL = 108 = GEOMETRY
CODE TONE = 81
THE CODE TONE = 114 = FREQUENCY
THE THREE TONES = 162 = THE CODE WITHIN DNA
THE THREE TONES OF THE CODE = 243 = THE DNA HEALING CODE GEOMETRY
THE SIX NUMBERS OF THE THREE TONES = 360 (Suggesting complete circle? Cycle? Also suggesting the 6 frequency numbers of the ancient Solfeggio scale?)
1. UT ¬ 396 Hz ¬ Liberating Guilt and Fear
2. RE ¬ 417 Hz ¬ Undoing Situations and Facilitating Change
3. MI ¬ 528 Hz ¬ Transformation and Miracles (DNA Repair)
4. FA ¬ 639 Hz ¬ Connecting/Relationships
5. SOL ¬ 741 Hz ¬ Awakening Intuition
LA ¬ 852 Hz ¬ Returning to Spiritual Order
What are the Solfeggio frequencies?
According to one source (http://hometown.aol.com/codeufo/%3cblockquote%3e%0a%20%20%3cfont%20size%3d+1%3ehttp://www.lightwithin.com/SomaEnergetics/4Certification_Workshops_Schedule.htm%3C/FONT%3E%3C/BLOCKQUOTE%3E%0A):
"These original sound frequencies were apparently used in Ancient Gregorian Chants, such as the great hymn to St. John the Baptist, along with others that church authorities say were lost centuries ago. The chants and their special tones were believed to impart tremendous spiritual blessings when sung in harmony during religious masses. My thanks to Dr. Joseph Puleo for rediscovering these frequencies and returning them to humanity."
Having heard Dr. Leonard Horowitz speak about Dr. Puleo's work with these frequencies I knew that Puleo had recognized what seemed to be a significant element regarding the frequency numbers. That is, the numbers reduce, in sequence, to the single digit values of 9-3-6-9-3-6. I had found this same situation to be the case for the word, FREQUENCY, as shown here:
FREQUENCY = 114
114 x 1 = 114 = 6
114 x 2 = 228 = 3
114 x 3 = 342 = 9
114 x 4 = 456 = 6
114 x 5 = 570 = 3
114 x 6 = 684 = 9
114 x 7 = 798 = 6
114 x 8 = 912 = 3
114 x 9 =1026 = 9
The order of the single digit values is different (6-3-9 as opposed to 9-3-6) but perhaps the order of sequence is not as important as the triads themselves regardless of the sequence. In fact, when I realized they were triads I discovered the sequence yet again:
SIXTH TRIAD = 132 = 6
THIRD TRIAD = 111 = 3
NINTH TRIAD = 117 = 9
Now I didn't know what this might mean but I did notice that the 3rd, 6th, and 9th numbers in the list that resulted from the word FREQUENCY are the ones that reduce to 9. When we calculate the sum of those numbers (342+684+1026) we get 2052. That number was not familiar to me as it did not refer to anything else in my notes that I've archived over the years. Curiously, however, when that number, 2052, is divided by 3 the result is 684, the same as 114 x 6, the last number in the second triad in the list and/or the 6th number from the top of the list. So once again we find the idea of the "SIXTH NUMBER" showing up in this analysis. Futhermore, the sum of 132+111+117 is 360. This number suggests a complete circle in conventional arc degrees. It is also, curiously enough, the alphanumeric value of the following phrase:
THE TREE OF THE KNOWLEDGE OF GOOD AND EVIL = 360
Note, also, the number 117 (the value of the phrase, NINTH TRIAD) relates to Braden's "God Code" in the DNA especially if the purpose of the "God Code" is to communicate information:
DOUBLE HELIX = 117 = COMMUNICATE
Regarding the 6-3-9 sequence, we see how this repeats, 6-3-9 / 6-3-9 / 6-3-9.
This suggests a cycle which brings us back to some significant phrases introduced a few pages back:
And one more flag went up with this:
SIX THREE NINE = 150
150 x 1 = 150 = 6
150 x 2 = 300 = 3
150 x 3 = 450 = 9
150 x 4 = 600 = 6
150 x 5 = 750 = 3
150 x 6 = 900 = 9
150 x 7 = 1050 = 6
150 x 8 = 1200 = 3
150 x 9 = 1350 = 9
_________________________________________________ _________
As an aside, although still relevant, I've been told that in the King James Bible the center chapter is Psalm 117. Recall DOUBLE HELIX = 117 = COMMUNICATE. If the information is correct there are 594 chapters before Psalm 117 and 594 chapters after Psalm 117. I seem to recall that 1188 is a gematria number from the Hebrew system. I can't recall what meaning is attributed to it but it's the sum of 594 + 594. Another interesting thing is the reversal that takes place with the sum of 117 and 594:
594 + 117 = 711
Since the number 144 is considered such a significant sacred number, and has appeared many times in this analysis, it seemed like a good idea to include a list of the interrelated phrases that I've found so far which have an alphanumeric value of 144.
JEHOVAH ETERNAL
GOD IS SELF AWARE
THE GOD OF ISRAEL
VOICE OF JEHOVAH
I AM ALPHA AND I AM OMEGA
I AM THAT I AM NOT
SERPENT OF GOD
BODY OF CHRIST (Note: SPIRIT OF CHRIST=189. 189+144=333)
NOTHINGNESS
MULTIVERSE
MARK OF THE BEAST
THE DIVINE CYCLE
REVERSE SIX
CIRCLE OF SOUND
CIRCLE OF STONE
CIRCLE OF TONES
CIRCLE OF NOTES
THE PHI SCALE NODE
THE NINE CIRCLES
SPIN THE WHEEL
ONE TWO SIX
FOUR FIVE NINE
THE ALPHANUMBER
THE ILLUSION
THE COMPUTER
SQUARE OF FIVE
SQUARE OF NINE
DIVINE SQUARE
GEOMETRIC SHAPE
SIGN OF THE CROSS
NINE IS THE KEY
THE SECRET KEY
THE PHASE SHIFT
EARTH TEMPLATE
CROP TEMPLATE
Conclusion:
Some of these phrases remain a mystery to me as far as what they might actually mean. For example the phrase, SIX IS THE CREATION TONE, seems to not make sense on its face; yet, on an intuitive level it has the "feel" of something that might make sense if only we knew the precise context in which to place it. The same might be said of some of the numbers. Still, given the preponderance of these numbers (such as 144, 162, 459, 117, etc.) and all their respective permutations resulting from this matrix of case-related phrases, and their close (and often dead on) correspondences with Braden's "God Code", one certainly is tempted to believe a message is trying hard to come through the noise.
its a mistry to me
aussepom
ok in this pic i brought out another observation.. notice all the different color square angles.. what i find interesting is that if you look at each square one end of the square is the mirror of the other side of the same square.. then the corner number is a mirror in itself!! eample would be 747 mirrors itself..
i put a orange circle around the yin and yangs of the square.. and as you can also see there also is the dividing red line diagonaly across the center..
on rodins coil he claims that he has developed the perfect geometrical design for a coil that interacts with its surounding space magnetically and is able to create more magnetic energy then with a standard iron core transfomer..
rodins coil is pretty simple he winds it with bi filar winds and leaves a gap between bifilars to allow the flow and interation with aether channels of energy..
i think stans circuit has some resemblence to this .. i think instead of the aether flow being present in lets say the alternator its actualy occuring in the cell gap.?? im just trying to draw a broader pic of posibilities of resembling the 2 free energy devices..
What I have noticed it that where the wires cross in the coil at an angle there's a non-inductive point or cancellation. I would not be surprised if a 5 pointed star winding had a similar or more profound effect. I haven't tried it yet. It's a lot like a moebius coil winding. I've brought this up in other places; if energy is neither created nor destroyed, if waves cancel what happens? It has to be a transformation.
Andy
well the way i see it from markos perspective that the rodin coil is wound so profoundly that there are no effects within the coil of resistance due to contradicting fields which exists within all common coils today.. its one of the main reasons they get hot... he also says that there is no ELECTRON SPIN DEGRATION i find this to be the reason of signal distortion.
its interesting that we can consider rodins coil a bifilar design since it does have two equal length wires just under different geometrics when it comes to the wind style... his design doesnt require a steel core since his magnetic fields are not within the coil rather all around and outside.. his magnetic field is said to be much stronger then a standard core design coil.
this leaves me seeing rodins coil as one that can resonante at a higher variety of frequency without signal degration and loss of power in the form of heat
i would like to make one of these soon and experiment with it using the electrical polarization setup... i would like to see whhat this coil will do set up as a VIC.. i would also like to see it place with the tube cell in the coils hole.. imagine if the rodin coil is a atom pulser the magnetic fields being generated in that coil with a high ring (vic) may show interesting results.. who knows
well if energy is is neither created or destroyed that must mean energy is considered a object correct? shall we say density (photons are elementry particles).. can this density be consumed? when i say consumed i do not mean destroyed i mean taking on by the atoms and stored as potential energy of some sorts within or around the atom during ionization.. i would say it would show its effect of taken on energy (object) as expanding gasses right? and even if thats not the case.. we can consider its still a object.. is it being stored or just being used to accelerate under a resistive circuit?
came up with somthing interesting thought i would share... in the tesla tech video i posted with marko rodins partner jamie.. he says they are winding them coils in another manner then showed on previous videos.. i took a old bike wheel and cut out the spokes. it had 36 spokes giving 10 degrees spacing.. i then looked up the angles of a 5 pointed star and plotted them on my rim.. i am curious of the 5 pointed star due to the facts that they have related it to satanic ritual.. i think that relation is for fearmonger to keep minds from think about the 5 pointed star in a good way.. so i looked up the angles and got,
there are two 5 pointed stars here represented in green and yellow..
now go ahead and apply some rodin math to these degrees and tell me what you get..
im not sure if this is his new method but it is sure interesting how all the angle add up to 9
(http://www.greatdreams.com/radio/oz/dblstar.gif)
now do it to the inner angles and tell me what you get.
(http://dudeman.net/siriusly/ac/geom/5star.gif)
Math is a nice thing. Whole of nature is full of it.
The question if energy is consumed or is tranformed in another material or energy form is one many asked.
One thing is for sure.....Everything we are or see is energy and all is connected on way or the other way....
Maybe the following question is a nice one for you Outlaw:
What does make that, as soon as you turn off power on a coil, the magnetic field turn into current?
Do the electrons a trick? What is pushing the magnetic particles into current in an inductor?
well if i understand this question correctly,
i would say its a mix of volts and field..
volts are providing a electric pressure and also a emiitted field (the condensing of a net charge pos or neg emits a field) .. commonly known as emf.
now as for rodins work the question is..
is there a better geometry of interaction for the potential (volts) and its traveling emf that doesnt degrade the syncronousity of the electron spin and by doing so takes away uneeded disipation from within the coil it self.. which is where all the heat comes from and loss known in todays electric components... not only that but the coils geometry being based off nature it self taps into the dynamics of the electrons flowing in space itself.. all in all as rodin says can create a mini black hole..
i wound a rodin coil a lil while and took a neo sphere 1 inch magnet.. i cut open a little 1.25 inch plastic ball and placed the magnet within the balstic ball then used my soder iron weld the plastic shut.. then i drilled a hole in the plastic ball and injected the plastic ball with ferro fluid.. so all in all i have a rodin coil with a permanent magnet sphere submered in ferrofluid..
my rodin coil has 2 inductors wound in a cetain geometrical arrangment.. i used 18 gauge.. and 7 rounds around the torus.. about 32 feet per inductor..
i have been placing the coil on a tv i never use and oberving the way 2 channels change the magnetic field.. and also mono.. its pretty physcidelic looking.. will be filming a video in the near future to show some visual characteristics..
i have another one with 36awg and 27 rounds that i will being seeing how the 2 couple each other
in the tree pics you see some experimenting with the rodin coil i explained above.. there is a 1 inch neo sphere magnet in the center with ferro fluid incapsuled in a plastic ball.. as i scan though frequencys i seem to find phase locks at multiple frequencys that are close to the multiple of 60 hz.... as i scann you see blurry wave sets (tc screen showing magnatism.. traveling down the screen then they slow down and clearify at a certain frequency when it reachest the most clearest point the waves are no longer traveling down the screen but are locked in a position ever so slightly moving and you see the inner colors changing colors back and forth almost like they are breathing (slowly)... if i were to contune to scan past that point then you would see the waves travel up the screen rather then down.. they will speed up as i scan and slow down again just to do the same thing all over again at a higher frequency... in the pics i have the ampitude turn down low if i were to crank it up it would give me locked sharp rise times.. im gonna make some videos tomorrow and try to get them on you tube..
(http://i82.photobucket.com/albums/j243/outlawstc/101_1023.jpg)(http://i82.photobucket.com/albums/j243/outlawstc/101_1022.jpg)(http://i82.photobucket.com/albums/j243/outlawstc/101_1024.jpg)
