Stanley Meyer => Stanley Meyer => Stanleys Alternator => Topic started by: Donaldwfc on September 26, 2009, 17:42:51 pm
Title: Rotary Pulse Voltage Frequency Generator Assembly
Post by: Login to see usernames on September 26, 2009, 17:42:51 pm
-moved to my projects section-
Title: Re: Rotary Pulse Voltage Frequency Generator Assembly
Post by: Login to see usernames on September 26, 2009, 20:49:43 pm
Have fun with that design Donald , I was sent all of those pics a while ago , orion has all that stuff ...
Havent heard anything positive from my contacts about the buggy stuff , probably a lure of somekind ...
All those components there are probably not just components , what they dont show is all the calculations involved .
Post by: Login to see usernames on September 26, 2009, 23:05:28 pm
It's actually quite simple...we are looking at 3phase half wave rectification here.
The insight about the inductors over heating is correct....IF it were not for the pulsing circuit on the primary winding. (usually it's straight DC)
The result would be smooth rectified waves...that then have an off time...the practical result is square wave in nature.
Notice the inputwave form...then notice what the inductor/diode does to the waveform (doubles it).
(http://i175.photobucket.com/albums/w152/Jdub6d9/Untitled-11.jpg)
With the overlapping waves of rectified 3phase...the ripples in the xformer would be insignificant (and would heat the primary winding quickly), much like straight DC across the primary...not until you shut down the power and the inductor collapses would the xformer create power in the secondary.
Transformer action can be viewed in physical terms using the eqn. of power. This eqn is...
The change in work (changing magnetic fields...as they must perform work to establish) / The change in time (this being time on and time off of a pulse)
It should then be obvious why sharp on/off times produce huge voltages....
Lets say we put in a set amount of energy to perform work and make a field in opposition to Earth's field/Aether....lets say it's 5 "units"...well then lets say the change in time is say...1 second.....5/1=5....Ok, lets say we can drop the change in time into say...1 millisecond....5/.001=5000.....every time the change in time gets closer and closer to 0 the power rate reaches closer and closer to infinity. Try graphing 1/x on a graphing calculator and see what happens...it's says error in the data table at 0, yet the graph is correct...the asymptotes  reach infinity at 0
Anyway, hope that makes sense about the overlapping waves being essentially straight DC, and the need for a gating/pulsing circuit in the primary
Post by: Login to see usernames on September 27, 2009, 07:53:35 am
For the "crossover voltage burst sync-pulse",  how would the CTs be connected to the water bath? Because, the outer tube is the electro-positive and the inner tube is the electro-negative...and the water itself inbetween the tubes is the 0v ground.
(http://img.photobucket.com/albums/v81/bigbuba/Picture10.png)
Post by: Login to see usernames on September 27, 2009, 14:59:37 pm
