This is not a combustion process! Stoichiometric combustion of H and O (H2 -->O) creates a white/orange flame. What we are seeing here is Stan's "ION flame". Where hydrogen is solely responsible for the color emission we see.
This is Atomic Hydrogen....and it is what Stan ultimately did with his gasses from "Stage 1"
I will now prove it is Atomic Hydrogen...and that it is the SAME process Stan was using to run a car on it.
Pg 20 (of the pdf reader)....lines 6-40 on the left side of the page....
(http://i175.photobucket.com/albums/w152/Jdub6d9/StansIons.jpg)
AKA...Atomic Hydrogen.....
Congratz Aussepom...NO LONGER THEORY!!!! (never was theory...ppl are just blind)
I have attempted to get people to look at this MOST CRUCIAL point...to no avail, I believe now seeing the awesome nature of Atomic Hydrogen they will begin to see it. (The "forest through the trees" that is ;) )
Stan is genius...he used the electron defficient O3 molecule to act as his "bump down" energy sink to get Atomic hydrogen to form back down to Molecular hydrogen...it's INGENIOUS!!!!!!!!
The beautiful part is that the O3 is made at the same time through H.V. ionization :)
Now, to get your system up to par with Stan...you need to look into his chokes that limit electron flow from power circuit through the "dead short" arc in your steam there.
"I'm not saying he built the same exact thing..
"you would see how similar they are".
"...it's EXACTLY THE SAME".
I'm not saying he BUILT the same exact thing
it OPERATES on the same PRINCIPLES
arcing through it to create atomic hydrogen ions and O3 (ozone) ions....it's EXACTLY THE SAME
HMMM...what's the name of this site again? ??? IONIZATIONx.com? ???
YET NONE OF YOU SEEM TO UNDERSTAND IONS....and, yet you claim I have no scientific objectivity....IGNORANT assumption. I have used MANY fields to UNIFY Meyer's system and explain it completely....u sir...need not address me because I have NO INTEREST IN ANYTHING YOU SAY....I will not state the obvious in this circumstance...if anyone finds any shred of ANYTHING in what you say...they deserve to believe u.
Original reply deleted in the spirit of Steve's last post.
Gentleman,
Please keep focus here.
Stop arguing on who is right and who is retarded.
At the end, we all want the same, is it.
Aussepom build a nice device. Lets learn from that. Not important if he was inspired by Stan or not. Fact is that he build a working device that works in a specific way with specific results.
Please try to make similair devices.
Maybe it really creates enough power to push a piston down, in stead of burning the piston into pieces.... ;)
Aussepom: Great work. We hope to hear soon more from you with more details.
Br
all re-create the events in an arc....but, with out the dead short condition that creates max amp inflow.So the conditions for an arc must be estabilished, but it may not arc over, how do you think this is accomplished?
Hi warp
yes I have seen all Stans work, I find that 'all is not shown' that is why I said it can not work in the configuration as shown in the patent.
If you heat up water in an enclosed pipe to over 374deg C then exhaust it to a low pressure area
via a 'suitable nozzle' that could be an expansion valve. you see to do this you have to maintain the pressure in the pipe so the the 'restrictor', nozel, or expansion valve, call it what you like, you have to keep the pressure of the water coming in at the same pressure with out letting in any 'air'
this is done in some submarines it is a closed system, the nuclear reactor heat the water in an enclose space up to 400deg, C, the pipes that go though the reactor are also a closed system, it is the water in the later pipes that heat up the water to make steam, then that drives the turbines, and that is also a closed system. it is 'expanded' into steam directly into the turbine, the low presure steam is condenced back to water to be reheated. all this is done in the same way a refirgerator works.
gee you got me going.
The piont being this 'Oz Injector' can work 'under water' and so could replace the nuclear reactor.
there are many other uses.
well I have to stop.
aussepom
@Alanionization by field only, isn't ths called a corona discharge?
I believe that the choke coils play the biggest part here. The two windings create a magnetic lag between each other...the magnetism fills up around the coil/core, and since amperage has a definite charge, it is affected by the fields.
So, even though the conditions to arc over are reached...the choke coils hold back the majority of amps...so amps don't flow, yet the gas is ionized.
Stan does not use O3.(http://img.photobucket.com/albums/v81/bigbuba/HFP.jpg)Ozone also got a dipole moment
If you can explain how "The oxygen atom having less than four covalent electrons" is able to form O3 then I'll graciously retract my correction of your error. If you can.
Radiant, I don't know what to say, you are reading the exact description I am referring too [plus the videos] and some how you manage pull O3 out of that. So I'm going to give up and leave this topic to it's rightful discussion of the Oz Injector.
I also think it's odd how you go head over heals to proclaim Atomic Hydrogen, or single Hydrogen atoms, yet you completely miss the point that it is also Atomic Oxygen, or single Oxygen atoms. These Oxygen atoms can not form Molecular O3 for the exact same reason why they can not form H2O when they react with the Hydrogen, they are missing their covalent electrons and are too positively charged to bond to other Atoms and can not stabilize, first they must destroy several Hydrogen Atoms before they have regained enough electrons to stabilize in a molecular structure.
Sorry Aussepom for getting off track in your topic.
