Projects by members => Projects by members => Komtek => Topic started by: komtek on July 15, 2009, 00:37:24 am
Title: M.E.G. Radiant Transformer
Post by: Login to see usernames on July 15, 2009, 00:37:24 am
M.E.G. possible radiant transformer.
This transformer based on some patents Bearden Bedini and others.
Similar to Naudin's M.E.G. but instead will have 4 coil primary's.
Here is a great start for this experiment, will wind bobbins soon.
This is a small setup MetGlas Amorphous Alloy taped PowerLite Core AMCC-80 and 6 modified bobbins.
From edge to edge of bobbin length is 5" and its 2.75" high and 2.5" deep.
When wound and pulsed the coils will switch flux paths.
Permanent magnet material will go in the middle of the core in direction of flux path.
M.E.G. theory suggests that its pretty easy to attain COP 3, I'm hoping.
What I see from the theory is that the pulsed coil flux path is enhanced with the permanent magnet flux.
The coils are switched, several possibilities here.
Hopefully a positive result will become of this.
Further thoughts are if its workable, how it can relate to a Meyers setup.
Meyer speaks of radiant energy. Energy locked in the vacuum.
It is a negative and cold energy is what I have read and been told.
Also to make or enhance the energy sometimes you have to think backwards or reversed.
This is my first attempt at producing this useful energy.
Title: Re: M.E.G. Radiant Transformer
Post by: Login to see usernames on July 15, 2009, 00:46:52 am
awesome
Post by: Login to see usernames on July 15, 2009, 00:51:13 am
Hey Komtek,
Looking great so far.
I also started to build mine today.
I see real potential in this.
Post by: Login to see usernames on July 15, 2009, 00:52:42 am
Got my attention! For some reason I have always been addicted to coils.
Post by: Login to see usernames on July 15, 2009, 09:45:51 am
Looks great man.
Nice core as well. How did you get that one? Build it your own?
Post by: Login to see usernames on July 15, 2009, 10:43:20 am
Here is food for thought.
You all read this Tom Bearden website. Much info on scalarwaves, Dankie.
http://www.bibliotecapleyades.net/bearden/ferdelance/index.htm#menu (http://www.bibliotecapleyades.net/bearden/ferdelance/index.htm#menu)
Post by: Login to see usernames on July 15, 2009, 16:28:25 pm
that litterature is a bit crude for me . :P
Post by: Login to see usernames on July 15, 2009, 17:43:49 pm
This core is a MetGlas PowerLite Amorphous Alloy taped core.
AMCC-80 and 6 modified Metglas bobbins made for the size 80 core.
It may be just the minimal size to provide an experiment, anything smaller gets hard to work with area and bobbins.
The core is vey important for this type of transformer.
From what I understand your standard laminate core will most likely not produce a decent result.
Its very important to tune to the cores resonant point.
Naudin has excellent M.E.G. pages: http://jnaudin.free.fr/meg/megv21.htm (http://jnaudin.free.fr/meg/megv21.htm)
This is a great place to start to understand this technology.
M.E.G. Motionless Electromagnetic Generator. Also known as Flux Switched Transformer.
Picture of core shaving fell off while winding outer core bobbin. Ultra thin material 23um.
Post by: Login to see usernames on July 16, 2009, 03:23:19 am
Bobbins wired!
Now need to determine magnetic north for the magnets.
Also have to make the mounting plate or stand.
I continually always do this, put 10lb's in a 1 lb package, for years!
Will I learn he ask's.
Hope I get a good result.
Post by: Login to see usernames on July 16, 2009, 04:27:25 am
beautiful komtek!
Post by: Login to see usernames on July 16, 2009, 09:25:30 am
Very very nice!
Post by: Login to see usernames on July 16, 2009, 12:34:55 pm
Good luck, hope you get encouraging results
Post by: Login to see usernames on July 18, 2009, 02:04:39 am
Yes thank you gentleman for words of encouragement.
Well here's my MEG1 mounted and ready to test.
Will use the ElectroJolt PWM first tests and see if it can switch the magnetic flux.
Hopefully the magnets strong enough I believe its a N50 .75"x.75" cylinder.
Will give it a run this weekend but there are still some preliminary items to take care of.
Post by: Login to see usernames on July 18, 2009, 03:10:19 am
its a;ways sp clean when you work Komtek .
I love your organized style .
Post by: Login to see usernames on July 19, 2009, 06:45:01 am
First tests show possibilities.
Connected those 4 primarys every way I could figure.
Need to find more small loads to connect to it.
Right now 2 small #44 indicator lamps are lightly glowing and 2 pairs of 12" long tubes are producing a very small amount of steady tiny bubbles.
I'm using 225ma 14v input = 3.15 watts.
I think if I play with more small loads it may work better.
When I put the second tube set on the incoming load current did not appear to rise.
Post by: Login to see usernames on July 19, 2009, 10:46:13 am
Hi Komtek,
No Cop 50000 yet? ;)
Can you keep us informed on the input and output power?
I have for you some interesting pages to read, if you like.
http://www.tpub.com/neets/book8/32o.htm (http://www.tpub.com/neets/book8/32o.htm)
In theory it does like 500mW in and 500Watt out....hmmmmmmmmm
I hope you see some results!
Post by: Login to see usernames on July 19, 2009, 13:30:45 pm
p23
Post by: Login to see usernames on July 19, 2009, 16:14:12 pm
Nice Doc Alan,
Thanks
Post by: Login to see usernames on July 19, 2009, 18:41:20 pm
Nice pdf doc Alan, good reading and pic drawings.
Something about this is telling me I have to figure the right loads.
The last test had 1.5-1.6v AC output.
To run the tubes I had to use diodes, and it would not work with added chokes.
Before I redo another testing set I'm looking for 1.5v loads.
The indicator lights I used are 12v old automobile indicators.
The coils and core are like a musical tone instrument. Several tones can be heard at one time while tuning.
On my PWM are 100k precision pots and they can tune! The MEG actually produces several notes like a lick in pefect pitch.
Although there are some ugly tones I get several notes in succession that are perfect arpeggio's.
It likes to tune to its resonance.
When I used a autotransformer and bridge for the coils it makes a hissing tone sound, it does not like this second source.
Maybe that the PWM does not like the other negative wire of the autotransformer?
I couldn't get the autotransformer over 15v setting anyway.
15 volt primary seems that this MEG likes that.
I need to think of 1.5v load sources (cheap), any ideas?
Post by: Login to see usernames on July 19, 2009, 19:06:46 pm
put more and more loads .
call that guy of yours .
Never give up .
Post by: Login to see usernames on July 28, 2009, 00:43:38 am
Thought I would write a small update on my MEG1.
It seems I am having primary voltage power issues that need some modifications.
Electrojolt sent me a power supply mod I will have to incorporate it.
Other tests have shown positive results looking for over COP1 but not there yet.
Some of these tests have shown me that I can load the secondary's up and see the current on the secondary's rise and no current change on the primary.
But..... as I load the secondary (with resistance) the voltage on the secondary also drops.
I have not found any good loads other than lamps.
So 2 things I have in mind, power supply mod (for more voltage) and or rewire my secondary coils.
I believe I need more turns here.
I'll have to leave this sit for a little while as I am working on some other old unfinished tube project.
Post by: Login to see usernames on August 15, 2009, 21:54:56 pm
Would it be possible to make this work by powering the control coils with common AC, the coil would have it's magnetic poles flop back and forth at the AC frequency, though not as sharp as a squarewave, I am wondering if this would still be enough to flop the permanent magnet flux from side to side through the pick up coils.
If that would work it would be a lot simpler to set up, just put 60 Hz in and get 60 Hz out at an increased wattage, thoughts?
Otherwise, how are you doing with this thing? It looks awesome :)
