General => General Discussion => Topic started by: Dankie on May 15, 2009, 15:21:55 pm
Title: Important information
Post by: Login to see usernames on May 15, 2009, 15:21:55 pm
During the crash , I talked to a very trusted source , a very intelligent person with great vision .  This confirms our doubts .
My question to this person : , everything I said will be presented exactly how I sent the message , with images included
Heres an idea of mine , its kinda like the EEC schematic with the VIC ,but the pulse from the EEC circuit is much higher voltage , I dont know if it will be necessary but maybe for ripping out those electrons even more ?
So we know the cancelling bifilar connection of the all-in-1 VIC never creates a HV gradient across the water gap since its cancelling itself , one is +X voltage other is -X voltage , heres an example , little arros is the direction .
----(+100volts)---->>water gap<<----(-100 volts)----
Do you agree with this ?
So lets say I can possibly also brg the EEC part of the circuit in resonance also , perhaps the phase or "timing" of our pulse will matter , maybe the molecule is weak @ a certain time due to this canceliing force , perhaps "out of time" or some quantum thing ...
Maybe when we get our maximum efficiency our lightbulb is the brightest , perhaps another indicator of resonance apart from the feedback coil ?
All this is good to ponder upon ...
Title: Re: Important information
Post by: Login to see usernames on May 15, 2009, 15:24:38 pm
Answer of this person :
No I do not agree....the chokes cancel flux...but, trust me there will
be high voltage. Meyer's notes up to 20Kv...as for the EEC, it doesn't
supply any voltage of it's own. It actually bleeds off the voltage of
the VIC across the water gap.
If you look into the literature (Meyer's patents) the EEC is just a
path to +...so the HV - potential from the Water gap is re-routed
through a load, temporarily shifting electrons
Post by: Login to see usernames on May 15, 2009, 15:26:10 pm
My question again to this person:
By flux , do you mean this kind of flux ?
http://en.wikipedia.org/wiki/File:Electromagnetism.svg
Lets be very specific here , this stuff can get really really confusing .
So lets say I replaced by cell with an amp-meter , would I get absolute zero if the bifilars were perfect ? This is my understanding ...
Plz explain to me carefully what you mean by "bleeds off" , open switch to ground is it ? , I was under the impression that there was a pulse coming from there , a + force and that -electrons were attracted by this + force .
Post by: Login to see usernames on May 15, 2009, 15:27:23 pm
Answer of this person:
Yes Dankie that is the flux in which I speak.
Ideally you would read zero...but I doubt that it could be that
perfect. Let me clarify something...the amperage is not being consumed
at all. The fluxes are traveling in opposite directions, with opposite
spins. See, any time current (amperage) flows on a wire it creates
these "Eddy" currents we call flux. The current flow is directly
related to the flux intensity. If you lower the amperage the flux will
also fall in a linear fashion....So, inversely...if we stop the flux
flow we also stop the current flow....the current is essentially
"choked" out...hence the name choke coil ;)
As for the "Bleeding Off"....this is key you get this.
+ and - are equal and opposite....If we get a true capacitor action in
the WFC...when we charge it up we will have + and - standing voltage
even after the power is turned off. In ALL capacitors...the insulator
is charged as well as the plates!
So in a water capacitor....the water itself will take on a charge and
elongate accordingly.
The only thing holding water together are 2 shared electrons between
the H and O...so it should be obvious that we are interested in
manipulating the -electrons.
The EEC works like this...
Voltage is applied and the water capacitor is charged to maximum. The
input circuit (being isolated) is disconnected, then a separate path
is opened up. In Meyer's pics you can clearly see it's a + electrode
supplied in the water...NOT PART OF THE TUBES/CAPACITOR ;)
So, the on pulses charge the capacitor up...the charge circuit is
disconnected....The WFC should hold a HV charge.....A separate path is
opened ACROSS THE CAPACITOR to bleed off the voltage (like shorting it
out)...in this path is an "Electron consuming device"...or light
bulb....or LEDs.
Look here....Bearden gave it to us...w/o telling it was the WFC
          http://spiritofmaat.com/archive/feb2/feb2_bearden.htm
Furthermore, any ferrous(iron based) core is what they call a "flux
path"....this means that all of the flux is concentrated into the
iron. An air core has an even distribution of flux all around it...a
"flux envelope" if you will.
Let us imagine the flow through the "choke"...
Since the B-flow flows in one direction...when it interacts in the
choke, it flowing in one direction on the + side...and in the opposite
direction on the - side. The B-Flow is quite simplified in that
drawing, it actually corkscrews around the wire while spinning. These
two spinning corkscrews of flux meet in the bifilar coil on the iron
core...this concentrates both fluxes into the core and essentially
cancels the B-Flow...which then resists the flow of amperage.
The voltage potentials are still there pulling on them.
I need to find u a document on the flow...I will email it when I find it
Post by: Login to see usernames on May 15, 2009, 15:29:29 pm
My question to this person:
Lol I think I get tnow , that thyristor is getting pulsed @ the right time . In my confused mind I was like "opposites" attract duuuuuuhhh oink oink ,I tought this meant a battery + voltage , now that I look @ the EEC its clear that you are right .
So this is like an "virtual charge" , we didnt actually put electrons in the "capacitor" yet we can discharge it ?
So a coating is necessary you say ??? Coating on what electrode again ?
Post by: Login to see usernames on May 15, 2009, 15:30:07 pm
es exactly...we only have to pay to put the charge onto the plates
not to cram in electrons to disrupt the water molecule structure
(electrolysis).
It is in essence a reversed electrolysis...electrons leaving the water
instead of cramming in creating the heat and wasted energy (why
electrolysis is inefficient).
I believe a coating is needed to keep the charge from bleeding off the
plates. This is because through experiments of mine I haven't been
able to get too high a charge, this changed when I added a carbon
coating...carbon conducts but not as well. So it was a "poor"
insulator. None the less I saw more voltage across the water gap.
I believe the coating should be on the + plate. That will allow the
water to touch the - plate and then become - charged. As the water
flows out, it still has that charge. It passes the EEC electrode that
turns on a path to +....the -charge conducts and presto...ionic gas is
released.
Title: Re:Important information
Post by: Login to see usernames on May 15, 2009, 15:34:37 pm
----------------------------------------------- conversation over -------------------------------------------------------
So now its clear that the crux_wfc connection is WRONG .
There should be no more debate on this , ever
Now I know some people didnt mean to be so stubborn . Its not a question about being right or wrong , its a question of truth .
Only truth matters .
Post by: Login to see usernames on May 15, 2009, 17:50:43 pm
this clearly says the windings are OPPOSED....
"Let us imagine the flow through the "choke"...
The voltage potentials are still there pulling on them."
exactly as demartin has said and exactly as i have seen.
you can't even comprehend the things you read.
put your self on a list of total confusion......oh yeah and i forgot how dynodon, 2curiouswfc, gotoluc, and gmeast were on a list......ALL PEOPLE WHO ARE ACTUALLY DOING SOMETHING.
Post by: Login to see usernames on May 15, 2009, 19:23:28 pm
two spinning corkscrews of flux..
let me add something: the flux between the wires of a cylindrical coil cancels out and the magnetic field left looks like this, no corkscrews anymore:
http://de.wikipedia.org/w/index.php?title=Datei:Solenoid.svg&filetimestamp=20061113180033
if i use the url tag my post will delete itself by the way stevie :(
Post by: Login to see usernames on May 15, 2009, 20:36:43 pm
The crux_wfc connection is wrong , this one shown in this picture here is wrong .
Let this be clear , I wasnt the one saying it was hooked up like this if I remember correctly , you were defending this like a fukin inquisitor .
Now you know ...
On this site there will be no dogma , any egos will get crushed .
Post by: Login to see usernames on May 15, 2009, 22:26:05 pm
This info is good ... mmmm , delicious perfect lasagna .... mmmmm
Post by: Login to see usernames on May 16, 2009, 00:49:40 am
@All
The connection is of little importance...no matter what, you wind it the same way. Two wires at the same time...just have it terminate at some posts (like the VIC pic)...after that, you can test which way we want to go in (either opposite sides...or same side) simple testing will show u. So calm down!
"I know one thing....that I know nothing at all"
@Haithar
That is the resultant flow of the wires in "series"...it's only 2D...In real life it looks like a double sided vortex.
Post by: Login to see usernames on May 16, 2009, 05:10:58 am
http://g-line.chess.cornell.edu/G-lineStatus/G-lineManuals/StepperMotors/compumotor.pdf (http://g-line.chess.cornell.edu/G-lineStatus/G-lineManuals/StepperMotors/compumotor.pdf)
Post by: Login to see usernames on May 16, 2009, 07:27:31 am
"Some bifilars have adjacent coils in which the convolutions are arranged so that the potential difference is magnified (i.e., the current flows in same parallel direction). The magnetic field created by one winding is multiplied with that created by the other, resulting in a greater net magnetic field. Others are wound so that the current flows in opposite directions. The magnetic field created by one winding is therefore equal and opposite to that created by the other, resulting in a net magnetic field of zero (i.e., neutralizing any negative effects in the coil). In electrical terms, this means that the self-inductance of the coil is zero."
"An early example of the bifilar coil can be seen in Nikola Tesla's United States patent 512,340 of 1894. Tesla explains that in some applications (which he does not specify) the self-inductance of a conventional coil is undesired and has to be neutralised by adding external capacitors. The bifilar coil in this configuration has increased self-capacitance, thereby saving the cost of the capacitors. It is notable that this is not the kind of bifilar winding used in non-inductive wirewound resistors where the windings are wired anti-series to null out self-inductance."
Post by: Login to see usernames on May 16, 2009, 11:11:09 am
bulb....or LEDs.
I think this theory on charging the wfc with an insulated + tube/plate is a nice one.
Has anybody made a proof of concept , yet, as far as you know?
That JN is not a proof of concept to me, btw. I had some contact with him and he didnt convince me at all.
Post by: Login to see usernames on May 16, 2009, 13:09:34 pm
@All
@Haithar
You tried to coat the electrodes with silicon sand, right? What were your findings?
Post by: Login to see usernames on May 16, 2009, 14:41:48 pm
To me it was a proof of concept of low amps electrolysis . And radiant's videos are proof of capacitor charging with cancelled flux . I am satisfied with the proof .
JLN certainly didnt update his wfc stuff . His point of view must be much more complex than what he has let us see ...
His coating was mega-Ohm range , so the circuit must have been very very low amps .
To me this is proof that regular electrolysis wasnt performed  ,and that 2+2=4
If we can charge something with a "virtual charge" and use this charge for real , its getting good .
Post by: Login to see usernames on May 16, 2009, 18:02:59 pm
The truth is now out there , I am satisfied with this theory and feel its 95% close to what was physically  . The rest is all about fine-tuning this process . But we have now identified the process after alot of speculation , alot of debate .
This counter rotating flux be happen in our cell as well , opposing direction and counter-rotating flux .
This somehow "unwinds the time energy" , and we "let time snap back" ... Or something like that ...  Took that from Bearden ;)
This is it folks , we will get OU by the end of this summer .
Yall get busy now with thyristors and EEC circuits , things are gonna get alot easier now that we know what to look for :)
Post by: Login to see usernames on May 16, 2009, 18:47:03 pm
for every action one trade takes place on the quantum level of view.. its all pressures and vacuums that make us and our reality,,  to give 1 pressure is to also take one vacuum. somthing thats hard for people to see is what happens when there balances are not of equal opposition.. meaning like +500 and -500,  +1000 and -1000 and so on.. when there off (lets say +500 and -200) you have turbulence.. either the pressure or vacuum state (in this case +500 is vacuum) its working with more force there for it is still trading on a 1/1 ratio but the turbulence is a roll in direction along with the trade.. these are what god calls paths..  that turbulent roll is really creating more trades of one state either vacuum or pressure, even though its a 1/1 trade the roll represents more trades of one state... we are building up real state differences in the chokes.. those real differences need to balance so there will be action in the cell.. but it also takes a vibration to alow saturation.. thats what the frequency does.. it is resonance not of electric but of waters natural ability to take on the charge.. i agree with all your truths you have found dankie. but at the same moment i am curious of your unclear thoughts.. so i search.. my search creates gains.. the gains are more knowlege to base truth off of.... these are gains that god like to see.. people that know that they really cant know everything because to know everything is infinity truth, are the ones of wisdom.. it is impossible to know everything in the time we have here.. but we can know the simple concept of working toward the path of infinity truth.. some people choose to turbulate towards infinity lies.. they are the ones on the path to hell..
Post by: Login to see usernames on May 16, 2009, 19:03:34 pm
i agree with all your truths you have found dankie. but at the same moment i am curious of your unclear thoughts.. so i search.. my search creates gains.. the gains are more knowlege to base truth off of.... these are gains that * like to see.. people that know that they really cant know everything because to know everything is infinity truth, are the ones of wisdom.. it is impossible to know everything in the time we have here.. but we can know the simple concept of working toward the path of infinity truth.. some people choose to turbulate towards infinity lies.. they are the ones on the path to hell..
I agree ,it has been a long road , it took a long time , our path is still a bit "clouded" , but its a light mist , we can still see the path , we will continure on this path towards infinity .
Some people are there to throw you off your well intentionned path , they are "the fog" , "the fog" plays tricks with your senses and leads you to the "forest of the lost" where you starve to dead and get eaten by wolves .
But some people do not use their eyes to navigate , they do not get influenced by "the fog" . Some people even know how to "defeat the fog" so that everybody can see the path .
Post by: Login to see usernames on May 16, 2009, 19:26:38 pm
exactomundo.. and at this moment in time the illuminate (rich personal gain elites) are the frogs you speak of.. they are of my up most interest other then quantum technologys.. .. they are of a high vacuum state... they are known as the illuminate because they illuminate like the frog and there lumination is natzi.
Post by: Login to see usernames on May 16, 2009, 20:23:08 pm
@All
@Haithar
@Alan
Yes I did, it was about the same as the carbon. It made a distinct layering that gave me the ability to hold more charge.
Also, the layers acted like diodes....it would carry tiny current one direction. Reverse it and it would carry a bunch....but, it would also remove your layer.
Post by: Login to see usernames on May 16, 2009, 20:34:50 pm
@Outlawstc
"it is resonance not of electric but of waters natural ability to take on the charge"
This may be true...but, water's relaxation time is rather slow. Being so slow, it holds a charge rather well when done right.
For instance study Lord Kelvin's Water Drop Generator. The water is charged as it leaves the water container.
"Even though water has no overall electric charge, it is full of movable electric charges (called ions). Half of the water's charges are positive and half are negative. It is not hard to separate these charges; simply hold an electrified object near the water. The electrified object will attract the "unlike" charges to the water's surface. It will also repel the "alike" charges away deeper into the water.
In the above diagram, the positive object attracts the water's negative ions and repels the positive ions. This draws an excess of negative ions into the tip of the water dripper, while repelling an equal amount of positive ions off to the other end of the dripper. When the water drop detaches from the tip of the dripper, an overall negative electric charge is still trapped in the droplet. The falling water droplet carries away negative charge, leaving the dripper slightly positive. If we catch the falling droplets in a container, the container will become negatively charged. "
So my point is...I TRULY believe it is super simple. I think resonance is for the gains in voltage potential only, but, I could be wrong ;)
Take this as evidence of my stance....
"Microwave heating is sometimes explained as a resonance of water molecules, but this is incorrect: such resonance only occurs in water vapor at much higher frequencies, at about 20 GHz."
I cannot get that high of a frequency....can you? :D
Post by: Login to see usernames on May 16, 2009, 22:25:17 pm
@Outlawstc
So you were pulsing that little choke thing with a neon transformer , @ around 5kv .
Yet that capacitor in your video held what ? 50 volts or sumthin ? Resonance was indicated by the speed @ wich it charged , shows how simple it is.... so you just picked a random transformer and random choke and a random capacitor and charged that thing up ? No cuper calculations involved ?
@ what lvl can you usually charge an uncoated water capacitor/cell ?
@ what lvl can you usually charge a coated water capacitor/cell ?
Post by: Login to see usernames on May 16, 2009, 23:09:28 pm
@Dankie
Yes, I was pulsing a low power neon sign transformer that is rated 5kv when driven at 120VAC....I was driving it at 12VDC. So the power spikes were much lower...but definitely HV...at least around 300-500V impulses. (Too hard to tell on my scope...off the charts)
So, yes a random xformer, a random choke, and a random capacitor.
What you have to realize is there was NO AMPLIFIER STAGE in those videos....I was pulsing it straight from the 555 (sharpest signal u can get really, adding amplifier stages degrades the square wave)....So, the power is EXTREMELY LOW!!! Max output from a 555 before it blows up is around 12v @ 190ma....that's around 2 watts...mine were running cool at around 80ma or about 1watt....but, it's a square wave (on half the time)...so the out put is divided by two, so it's really less then 1/2 a watt.
As you can see in this video, the voltage is very high indeed. It is high enough voltage to travel over my dry skin (which is a very large resistance)...this phenomena is very interesting!
http://www.youtube.com/watch?v=_EVnyw7oEj8
You have to understand...ANY setup will have a natural resonance. As long as it include SOME R=resistance L=inductance C=capacitance. So, you could make a random WFC, a random choke coil...and a random transformer.   No matter what the values are...that system will resonate at some frequency. You can sweep through the frequencies with a probe on the WFC and see resonance when the voltage spikes up.
P.S. If anyone has a copy of a video I made a while back where I pulsed an ignition coil with a 555 and captured charge on one wire and discharged a xenon bulb....I have lost it and would like it again.
It is another example of resonance....and in fact i made a companion video showing the standing wave all my house and in my oscope w/o a connection made!!
Post by: Login to see usernames on May 17, 2009, 11:12:16 am
Here's a good read to understand the various flows on a wire
http://creatorguy.com/files/Ortho1.pdf
Post by: Login to see usernames on May 17, 2009, 14:33:07 pm
excelent find radiant_1 .. i find this pic helpful for one of my questions..  notice the wire is making a-fields next to the core.. the a-fields create on big b-field. the b field is really the same as a field.. its just the product as a whole, meaning all winds working together.. now my question to all is about the primary winding.. stan meyers was a smart fella.. when he wrote the tech sure there was some miss spellings and what nots.. but when it comes to describing how to wind a wire i think stan would be very direct and clear.. so clear it can seem unclear lol.  he says "Primary Coil (26) (typically .030 Ga.) film coated magnet wire is longitudinal wrapped in
space relationship on top of and layered bidirectional (507a xxx 507n) across spiral-wrap coils
(501a xxx 50 In) to complete bobbin cavity (504)."
look at a globe and you will notice longitudinal is north to south.. which means from one end of the core to the other.. not wound around it..  layered bidirectional.. imagine if you were winding the primay on a 2-d object such a ace of spades card.. the back of the card would have one direction while the front of the card is 180 out so when u are winding each time you fold the wire to the other side it is change direction by 180.. now think if that card were to be wound and sat on a table for observation.. would the wind not be layerd? now take that playing card and cuff it around the vic bobbin where its wound north to south. think of one pulse going through the cuffed primary.. it will start at one side and pulse around the core to get to the other end of primary.. all in all it would be using the primary wind to imitate the b field.. it would be fueling the power in a vice versa manner then todays ways? i like vice versa idea's.. winding it that way would also put primarys current out 90 degrees like stan mentions in a video.
Post by: Login to see usernames on May 17, 2009, 16:27:49 pm
Post by: Login to see usernames on May 17, 2009, 17:07:34 pm
Post by: Login to see usernames on May 17, 2009, 17:35:04 pm
that bi-directionnal word is probably nothing special , Radiant's xformer was just a regular neon transformer .
Radiant_1 , whats your take on this , this workd "bi-directionnal" ?
Post by: Login to see usernames on May 17, 2009, 17:51:05 pm
define space relationship.. what space is he relating the wind to?.. to me the most defined relation there is on  a 3 dimentional object would be the poles..  and to be longitudinal wrapped would be from north to south in linear direction.. to consider it the way it is now.. wound end to end back and forth.. would be worded somthin like.. wound in a longitudinal direction...
Post by: Login to see usernames on May 17, 2009, 20:21:35 pm
im on a roll of finding good vids today
Post by: Login to see usernames on May 18, 2009, 07:49:04 am
I have come across it, and, I cannot say for sure.
Maybe he was referring to the bi-directional flow of flux?...But, I am also pretty sure he is speaking of the wire wrap....I will have to read it again and get back to you on this one.
Keeping up with all the patents is crazy :D
I have like 20 or so patents from Meyer...lol
Title: Ionization energies of the elements (data page)
Post by: Login to see usernames on May 21, 2009, 06:40:44 am
http://en.wikipedia.org/wiki/Ionization_energies_of_the_elements_(data_page)#WEL
Post by: Login to see usernames on May 21, 2009, 08:17:35 am
This is very interresting indeed . Plz tell us more . You saw a wave on your scope with both negative and positive " same voltage " the same moment in time . Kinda like figure 10-5 of the tech brief  ???
So I`m trying to imagine the tube cell was wires . So the B flux lines must be opposite spins in teh cell  , And their ``direction`` must also be opposite  ??? Perhaps the middle point is the ``zeropoint`` where the fluxes meet and this cause ``interference patterns`` in that zero point zone where the water is  ???
Could the B fluxes be opposing spin polarity BUT be going in the same direction  I mean they are mutually going towards a point in space with the opposing B flux  , maybe the injector works like this ??? Somehow I cant imagine this with a bifilar tho... Th B spin is dependant on direction right  ???
Post by: Login to see usernames on May 21, 2009, 19:32:09 pm
i beleave this is true if you are apply two negative fields and gating one..  2 of the same fields repel each other so therefore if they are of equal negative force they will cancel out in the middle of the cell.  that is the zero point.. now gate one choke to ground and ground will send a positive increase of charge to that cell plate.. it makes sense.. a electric field is the force direction to a proton..  you got to realize that a negative charge plate is creating a force on the proton.. that force is a pulling force.. so if you hit double negative the pulling force on the proton is in both directions with equal force so they stay unified or are trying to divide?  and the water will be neutral in motion.. the electrons will want to condense to center of the gap.. then on gate on time the electrons in the cell are collapsing toward grounded plate. that collapse is really a up in potential since your allowing your sub field to ground?   like your using a sub field state to produce your pulse  with grounds higher charge.
Post by: Login to see usernames on May 21, 2009, 20:32:05 pm
Or similar to this @ 1:17, positive and negative type voltage (energy?) pulses?
http://www.youtube.com/watch?v=NhS4TxP29mM
Post by: Login to see usernames on May 21, 2009, 20:33:47 pm
The wave looked almost exactly like this...
(http://i175.photobucket.com/albums/w152/Jdub6d9/Puriarchwave.jpg)
It's called a "ring"....the wave oscillates back and fourth but eventually dies down...then the pules hits again.
Post by: Login to see usernames on May 22, 2009, 15:06:34 pm
well i have come across some interesting results with voltage wave .. i have been messing around with a 9kv neon transformer  at the moment i have it hooked to about a 2kv cap but only to the negative lead.. i have taken both capacitor post and connected them to 2 seperate pieces of stainless wire of decent gauge and made them like old tv antennas. i took the positve wire coming out of the 9 kv transformer and hooked a test probe on it from my multi meter.. its werid holding the test probe it vibrates.. so both stainless antennas being contted to the cap which is only connected to negative lead of the neon output.. the antenna does not want to react with istelf at all but when i bring the probe to one side i can get over inch long arks.. but it gets more intersting.. when i put the probe between both of them it jumps side to side and  tend to go to which ones closes.. but!! after a while of of trying to hold the probe center and watching it jumb back and forth between the gap i loud pop happend and a briight solid ark occur dominating any ark it can produce.. now first off.. whats going on in the cap to allow oppoing fields to set next to each other.. even though with my logic a cap is made to where it has opposite charges on each end.. i have some more observation but my point made is i am putting  the opposite field between 2 fields that are alike.. and every once in a while it will give of remarkable voltage.. also i have introduced the antenna to a ground and it gets a ark, but not as big as the secondarys positve.. and also this ark produces exsess heat unlike secondaries.
