Stanley Meyer => Stanley Meyer => Topic started by: Dankie on May 01, 2009, 02:48:48 am
Here are my ideas . Would it be possible to have resonance with both circuit ?
I have heard from many different people that the opposing bifilar connection does have a resonance frequency and the voltage will rise up @ a certain freq , but its shadow wave will also have the same amplitude and block it .
But what if the pink coil can also resonant with the wfc/coil , perhaps this pink coil could be fed by HV transformer ? What if also we can add a lightbulb after the diode coming from the pink coil , seems like it can be an EEC as well ... ??
Seems like it could be pretty flexible setup and an ez add-on to the jolt circuit , some photo-transistor or w/e ... if we have a solid diode , a good 20$ diode .
We have to think how to "move" the water molecule ... We need to evolve our thinking .
Alsso , can somebody answer me this , how will these magnetic fluxes be ing when they are coming from 2 choke wires to cell , from this angle . I am not sure of this .
bump
Thane Heines is quite the engineer .
I should get that current translator to scope thing , really neat toy to see the current appearing as voltage on a scope .
bump
haha, Better be glad I like you! For now, anyways
use a common 1Ohm resistor. and measure the voltage between. it's the same as current.
