Stanley Meyer > Stan meyers resonance
Stanley Meyers Resonate Circuit A Must See
tester:
Is resistant wire a must? i am not 100% sure, i have alot of explaining to do. This will relate also to why kevin used a resistor. Now i see where the resistance is coming from. More soon.
you want the choke to restrict amps on charge, and series up on discharge, there's only one way to make this happen, its how you wrap the choke. Kevin doesn't have it wrapped properly. This is why he had to use a resistor. More on this soon. Its possible you don't have to have resistant wire, "not sure yet."
tester:
--- Quote from: haithar on October 12, 2008, 11:25:49 am ---Well, you have completely left out the diode in meyer's diagrams, which is the thing that destroys every theory about a free resonance and ac.
Furthermore: Why should it be resistant wire? LC-circuits work with copper wires too.
--- End quote ---
I never said it was free resonance, Why should it be resistant wire? OK, well i am now finding out that the resistance of the wire may not matter, "i haven't ruled that out yet." But what i have found is the way you wrap the choke, it can be wrapped in such a way to restrict amperage in "due to the core charge effect." On discharge this same wrap will form a ""series of coils"", to increase voltage potential. It is most important to wrap this coil properly, Not like in kevins photo where he used a bobbin.
This circuit i am working on now Clearly resonates. Its like taking the cap from a AC unit fan motor, the fan simply will not work! it to resonates. You take the condenser from the auto spark system and it will not spark the plug, there is no resonance. I am talking about alot of power here from a resonate circuit, not some small amount of power.
THIS IS WHY I CLEARLY POINTED OUT TO YOU TO GO AND READ AND UNDERSTAND THE AUTO IGNITION, ITS A GOOD EXAMPLE. When you understand that you will start to see what the cap does. You will also see where to apply the pulses. Please do not overlook this as it is the MOST IMPORTANT EXAMPLE YOU WILL FIND.
There is resonance going on, and power that is normally NOT USED is getting used now. We in our days are use to WASTING, these circuits clearly does not wast !
tester:
Someone should invite Kevin over.
lapperl:
I speak with Kevin regularly as do many people. He is a very open person and speaks freely about his experiments.
Kevin isn't into forums much. He does his own thing. He told me that he was here last year when he heard that you guys were rewiring the alternator stator. He said he was not greeted nicely and frankly did not have anything nice to say about this forum.
If you go to his site and review what he is doing, you will notice that he has been using distilled water in his experiments and has been successful. I too have replicated his circuit with minimal success. I have not been able to achieve that volume of gas production that he appears to have done. He has not posted any production volumes as of yet but the fact that his circuit is able to break down distilled water is an incredible milestone in my opinion.
LapperL
tester:
Tell Kevin that i am sorry if he was not greeted nicely. Also tell Kevin i do admit that my attitude may have been out of control in the past, i am very sorry for that. I have since Bettered myself into respecting others unlike before. Very sorry Kevin was not welcomed to this forum the way it should of been. At the time the forum went public we did piss many public people off, and for that i am sorry. I do try my best to correct the mistakes i have made in the past. One way of correcting them is just not post much. It upsets me that we had problems in the past. Please pass these words to him. Please send my apology.
Hello Danky. I have just taken some photos for you guy's showing a Coil that was wired to dedicate itself to a resonance circuit. This coil was created just to be inserted into a resonant circuit.
This coil is from an auto ignition coil, just like you will find on a dune buggy or any other old model car.
Here you see the primary, notice how it is wrapped Very Neatly from right to left, then it stops.
When you wrap the coil then stop, you then allow paper spacer, very important if not using a spool. After you add a paper spacer you then re start the wrap in the opposite direction very neatly, THIS IS ZIG ZAGG WRAP and it is VERY IMPORTANT.
As it RESTRICTS amp flow into the coil, Each Wrapp of the coil is in series upon Discharge, so you win both ways, You restrict amp flow in the coil, And you increase voltage on discharge. ONLY THIS WRAP TECHNIQUE MAKES THAT POSSIBLE, its very important FOR THE RESONATE CIRCUIT.
I have also included a secondary HV Photo, Here you see the distance between the LOOPS, this is important to reduce internal arcing. Both of these coils are submurged in oil where the paper soaks the oil up.
Again, i will STRONGLY point out, Please learn how the auto ignition system works to understand how resonance works. Its by far the best example on the Entire Internet, Please put all your time in the auto ignition circuit if you would like to scale this circuit up for hotter sparks, or to understand how a water fuel cell can be placed within this same circuit.
The Last schematic is exactly how you would connect a fuel cell to this circuit. Just replace the condenser with the fuel cell and the points control the frequency. "at the right freq water will rip apart" You can compare this to kevins setup and see the difference between the 2.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
