Electronics > High Voltage
NEW RESONANCE CIRCUIT
Steve:
After doing more mind breaking thinking.........
I added a resistor , so the time is longer for the discharge. So less amps are blown at once, and the discharge duration is longer.
This can be needed if you see and experience a deadshort on yr tubes or plates.
The last schematic is showing a new place for the wfc. In that case, you can do the switching on 1 place.
Hopes this helps.
Fiditti:
Stevie,
What program are you using for your circit diagram pic? I save the pics to my computer, and then I can't pull them up later. Thanks.
Steve:
--- Quote from: Fiditti on September 01, 2008, 14:15:48 pm ---Stevie,
--- End quote ---
My last adjustment are done in MS paint...........
Normally i draw with MS Visio.
steve
Fiditti:
Thanks very much.
Steve:
Capacitors:
A capacitor's storage potential, or capacitance, is measured in units called farads. A 1-farad capacitor can store one coulomb (coo-lomb) of charge at 1 volt.
A coulomb is 6.25e18 (6.25 * 10^18, or 6.25 billion billion) electrons. One amp represents a rate of electron flow of 1 coulomb of electrons per second, so a 1-farad
capacitor can hold 1 amp-second of electrons at 1 volt.
A 1-farad capacitor would typically be pretty big. It might be as big as a can of tuna or a 1-liter soda bottle, depending on the voltage it can handle. For this reason,
capacitors are typically measured in microfarads (millionths of a farad).
steve
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
