Author Topic: Brand New Finding, Tube Cells  (Read 20846 times)
Re: Brand New Finding, Tube Cells
« Reply #8 on: July 18, 2008, 20:57:01 pm »
they act as neutrals...but the stranhe thing is that i see clearly the oxygen from 1 tube and hydrogen from the other .........
« Reply #9 on: July 18, 2008, 23:06:22 pm »
The alternator Driver motor will pull anywhere from 12 amps to 25 amps depending upon the load on the alternator, so at idel the driver motor consumes 1320 Watts of power just sitting there running with no load.
It takes 1 HP from the Driver motor for every 25 amps the alternator outputs, this is what i was preaching about when i said i cut the amps in half. So a 3 HP driver motor can deliver 75 Amps, and a 1 HP driver motor can deliver 25 amps. , i can guess an alternator putting out 25 amps would consume atleast 1650 Watts from the wall outlet, and makes racket.
What i have found is the Variac can consume 10 amps at 110 volts, 1100 watts, with this i can hook my cell up to make it FLOAT as stevie calles it, with this i get the same gas output!
Im not gonna settle for 1100 watts now, more like 3300!
I have included a photo of the variac which can consume 3300 whats if it wants to, so this means all thats needed is a 3000 watt power inverter if you want to place this device into a car! It makes no racket and i find it to be just is good if not better than the alternator, the problem will be finding a full bridge rectifier that can handle atleast 50 amps for long periods of time.
A 3300 watt  variac will give you about 30 amps to put to your cell, which i'm only using now 15, so i will be running my fuel cell from about 1650 watts from the wall outlet, about the same as the alternator, but no racket or moving parts!
Now it is very easy to get large amounts of current into a car "(Hassle Free)"
Here is a schematic of my Diagram.
« Reply #10 on: July 18, 2008, 23:10:59 pm »
im also proud to say i just ordered that variac in the photo!
    • dudleys basement
« Reply #11 on: July 19, 2008, 16:52:34 pm »
i have the same variac it good the only problem is the fuse holder sucks the fuses are just a hair smaller than the standard fuse once you blow it  their a problem to find
« Reply #12 on: July 19, 2008, 21:44:09 pm »
Here is an example of this setup running my 8 tubes, i am also changing my configureation later on where each cell will = 3 tubes like spike
Fiditti
« Reply #13 on: July 19, 2008, 22:17:44 pm »
Thanks for the video.  That is some spectacular gas production.  You've got me pumped up now.  I've got to get more tubes into my experiment along with chokes and your circuit.  I have a variac and the full bridge rectifier.  I also have a standard Lawton circuit, which I probably should modify to your specs asap.  Thanks for sharing with us.
« Reply #14 on: July 20, 2008, 04:52:40 am »
Good work hydro.  You using the alternator's bridge on that?
« Reply #15 on: July 20, 2008, 05:17:42 am »
lol, howed you know? and where have you been hiding?
