Author Topic: JNL replications  (Read 25697 times)
JNL replications
« on: June 26, 2008, 21:14:50 pm »
This is the place for your replications of JNL!
Steve ;)
Re: JNL replications
« Reply #1 on: June 27, 2008, 00:40:54 am »
got anymore of that crack left? HAHA, j/k buddie
« Reply #2 on: June 27, 2008, 01:38:10 am »
wooo ha!!!
« Reply #3 on: June 27, 2008, 09:29:33 am »
Hydrotractor,
I expect from YOU the first setup.... 8) 8) 8) 8) 8) 8)
sincerely yours
« Reply #4 on: June 27, 2008, 16:14:16 pm »
I am starting to make a replication of the JNL setup.
I have the trafo, timer chips, and YES, i made a fully insulated innertube cell.
I had contact with JNL about this insulation and he mailed me that indead the innertube is FULLY insulated. Inside and outside!
Nothing touches water. (no leaks!)
I ran a capacitance test and my LCR meter showd me 1nF  with tapwater.
(Didnt had destilled in my lab/garage...but soon that problem will be solved as well)
I will publishe pics soon!
  • Yes I got Jolted,
« Reply #5 on: June 27, 2008, 16:49:39 pm »
I insulated my inner tube using a finger from a latex glove. didn't work too well.
Day one it measure 3.2nf
Day 2 measured 24.3nf,
I was only able to bring the Voltage up to 560Volts, then the latex started to leak, I could see tini sparks from the rubber to the water and a little stream of bubbles forming there.
I'm now insulating it with polyurethane.
« Reply #6 on: June 27, 2008, 16:56:51 pm »
I tried latex too for insulation of the inertube. Had same results as you watercellguy. The high voltage buildup ripped tiny holes in the latex.
What type of plastic is JNL using for insulation?
« Reply #7 on: June 27, 2008, 19:16:56 pm »
thin plastic adhesive tape.
