General > General Discussion
Modified Meyer Type Hydrogen Cell Revisited
<< < (2/2)
russrHHO:
Those epoxy filled black microwave OVEN diodes max out at point 2 ( .2) A  at max 20kv usage. They are also low frequency type. (not fast recovery) There is also a burst mode rating but only for very short duty cycle time. The 15kv units are rated .75amp, at low frequency. The machine imprint from China factory leaves out the dot, to make more sales profit.  I have also seen 3 china rectifier diodes with band at wrong end. Meyer inductors used resistance type magnet wire, not copper.   The Meyer cell circuit may use a low freq diode on high freq , and use over voltage to blow through for reverse flow electrons, like zener type. The very large stud/ semiconductor does not heat up with ma current. Heat is what damages diodes. What do you think. See stud data sheet VS-70HFR160. Anode stud /cathode stud.  Final  AC for heated water heat source with diode, + coupled inductors, +diode control for HHO, by USAGE of  separate inductors  - separate cores.  Heat or gases output.. Forward transformer dots and flyback transformer dots, with either positive output or negative output.  Then later on,  electron extraction from oxygen ions .
russrHHO:
The Meyer Hydrogen system is the 2nd best invention since bench top Cold Nuclear Fusion Heat. HHO is really H+ H+ O-- as charged ions. The gases have more energy total. The Patented Meyer term is Thermo explosive Energy. There were 3 systems. proof of design, concentric tubes water cell, and multi use injectors with electrons extraction, lasers and pulsed high voltage,- at pulse modulation. There are more gases evolved during off time as the on time. See Stan Meyer company manuals as,- Birth of new technology and Water Fuel Cell dealership Manual. Many Patents. The resultant true Meyer cell has thick, tiny, tiny, FOAM rising upwards in cell. All the rest is H2 with water vapor/ and or electrified water vapor large bubbles. Voltrolysis as >1500volts DC in plain distilled water.Deionized water was better. Two inductors resonated with cell and power source. Input secondary pulse through inductor to water capacitor as lowered volts to PREALIGN polarity water molecules. Then high volts DURING OFF TIME with vibration separates with no current, voltage pressure. Diodes make hydrogen, AC makes heated/ water. Very low wattage input. Overunity as huge efficiency. Power for engines and factory blast furnaces.
Navigation
[0] Message Index
[*] Previous page
Go to full version
