Cancer home therapy not working. < russwr > 2024-09-08 11:24
The Dr. Hulda Clark home therapy of 3 herbs has not succeeded. The prostate PSA number has gone up from 8.5 to 12. Only some cancers are caused by micro organisms. The current science research says people have to be on very low carbohydrates/ sugar/glucose, and must do fasting, electrical grounding, and reducing Glutamine by fasting. (Not genetic anymore, it's a metabolic disorder. ) Search data on Earthing/grounding, videos, Build up of electromagnetic volts on body over time period reduces effectiveness of immune system. The immune system knows what to do, but is being HINDERED by these volts on body over time. Your modern synthetic shoes are insulators from our negative ground. Negative electrons flow up wire to wrist strap or to floor plate may help body. Copper pipe tapped into ground outside window and wire brought into house, reduces time having to be outside on open grass with bare feet. I have .032" strip brass bracket on shoe hooked to leg strap. Heel on floor touches copper film and wire, as I type these notes. (Don't use the million ohm resistor in purchased blue wrist strap. The wire end has to be soldered direct to the metal snap. Breathing slightly increases, burning arthritis pain stops, circulation increases because of negative charges from ground, on circulation repels, as same polarity. Multimeter on AC 20 volts range shows volts going to zero after 4 seconds. The body continuously accepts electrons negative flow from ground. Hold red lead in hand, black lead on ground, then touch ground with body to see this yourself.The more time grounded, the better. I also have 2 copper pipe handles to hold while watching the news. Also sleeping with 2nd wrist strap and second wire out window, to second pipe ground. The medical term is now called:-- Nature deficit Disorder.
