Author Topic: John Keely - late 1800's Made Efficient Hydrogen Gas From Water!  (Read 1890 times)
"Keely And His Discoveries" - book, among many others, shows progression of 114 devices built from 1865-1899.  His bench top array of tuning forks transmitted vibrations of resonance and harmonic ratios of frequencies through series connected differing metals wires. We nowadays call them thermocouples and thermopiles of silver, gold, and platinum. The ratio of thirds harmonics easily caused dissociation of water molecules in test chamber vibrated. A new, cheap fuel was not needed in the 1800's. His Patent application was on the self powered rotational free energy hydraulic motor that had 4 way rotary SHOCK valve. It had inherently built in WATER HAMMER pressure as 50lbs. The output flywheel with eccentric crank was sawing wood for demonstrations.A similar design was duplicated years back in an Africa workshop. He was also the first scientist to come up with the notion of minute particles in physics as QUARKS. The subdivision of matter in thirds , - 3,6,9, was his first,------not Tesla. Tesla didn't like Keely, as Keely received way more investment monies than he did.
 Research DATES for yourself with Keely reference books. Costs on these are going up. See also S.V.P.-  Mr. Pond sells reprints.
Re: John Keely - late 1800's Made Efficient Hydrogen Gas From Water!
« Reply #1 on: September 03, 2024, 00:41:33 am »
40 new laws of Vibrational Physics written up in late 1800's by John W. Keely,- researcher and Inventor. Vibrations applied to masses in frequency resonance and in certain ratios inharmonics , can control the forces of nature. Has anyone studied this recently? Lots of literature available. The summery of his 3 final books was called the Snell Manuscript. Other data in books such as Dashed Against The Rock, Keely and his discoveries, Free energy pioneer, back issues Scientific American Magazine, and many others. Tuning forks matrix and chladni plate sand wave form patterns were noticed.There are picture books of his machines made in his 2 floor work shop in Philadelphia Pa. Five million dollar business , The Keely Motor Company, 1865-1899. See lectures of Mr. Pond of S.V.P. He also distributes literature for sale. I was originally interested way back in time , when I found out Keely could make Hydrogen gas from water , easily with his vibrations only applied . He had also used thermocouples and thermopiles  wires of silver, gold and platinum to carry the frequencies exact as needed. Signed documents were made when visitors and engineers present had seen a 2 ton steel sphere tank lifted up in air, and placed on strong stand by using tuning forks matrix, and the thin wires and initial tapping of tank with dual tuning forks bar. Keely had reported selling one of his inventions to a western company. They wanted an easier way than pic axe to be able to get into wall of cave tunnels to search for gold. The small machine was attached to wall and then began to crack and crumble down. Keely's Patent on file was for a dual use flywheel. His upstairs rotating spoked wheel machine was called The Great Keely Motor. He incorporated the flywheel in his model. His vertical pulse resonance water flap pump, could lift water to extremely high levels, better than contemporary water pumps. I was amazed to read about the bench test of sealed brass hollow  globe with ambient air. The certain vibrations applied would cause the mounted  gauge to reduce down from zero, and go into vacuum state. (condensing of molecules)  The 1800's Gauge was an open mercury bath Manometer with U shape tube.. Seems to me this technique could improve the modern  Cold Fusion experiments of Platinum and deuterium heavy water for creating extreme HEAT!.
« Last Edit: September 03, 2024, 00:57:14 am by russrHHO »
