Author Topic: I NEED YOUR HELP….  (Read 2812 times)
I NEED YOUR HELP….
« on: February 17, 2024, 09:35:03 am »
Currently I’m stuck from making any further progress due to financial constraints. I’ve spent myself into the debt trying get the parts I need. Maybe I should’ve started off asking questions like this I’d be further along without the extra bills. Does anyone have fluid pressure detection device that shut off at 60psi and cuts on at about 45-50psi. I’m also in need some t2” tubing to make the cell I thought worked best. I used plexiglaS and it warped when temps rose a smalll amount causing leakes. Is there a cheap plastic tha will hold shape somebody has or maybe 3/8” thick quartz glass tube. Tubes would be 1in “ dia and 18” long ideally. But I can adjust for any length if some one has some.
Thank you for reading
FI3
Re: I NEED YOUR HELP….
« Reply #1 on: February 17, 2024, 23:11:11 pm »
maybe you can share a paypal donation adress?
cheers!
Re: I NEED YOUR HELP…. Looking to Replicate Aaron Salter Jr water car
« Reply #2 on: February 26, 2024, 15:38:37 pm »
My PayPal is @FastImports3
Thank you Steve for the suggestion. Ii was afraid to ask or accept money before because I don’t want to disappoint anyone that has shelled out $ with certain expectations. While I haven’t  built a working system I have seen the reactions of small experiments looking for the larger picture. I have a small stock pile of SS tubes and plates of various sizes for sale as well or trade. I picked up a surplus of it relatively low price so let me know if you’re looking for something.
I can post some of the info that leads me to believe Aaron had a working water powered vehicle.
In the pic I attached you can see the working pressure of his system on his guage. 40psi
The system doesn’t use HHO for the fuel the system use the liquid water after it turns cloudy from the fuel cell being on.
The other part is in a few of his videos and a couple of mine. I wish I knew how to cut and paste the videos the way I want them so I could post them easily. I’ll try to record the sections off another screen and post a new video with links to the full videos used in a post.
