Author Topic: is it this simpel?  (Read 11938 times)
is it this simpel?
« on: January 12, 2024, 13:59:12 pm »
How about just applying 300v to the LC and then get like 600V?
Or apply 600v and get 1200v?
Is that the secret?
See Stanleys text in the attachment...
Re: is it this simpel?
« Reply #1 on: January 12, 2024, 14:13:30 pm »
https://www.falstad.com/circuit/
5v in and then 12v on the lc?
$ 1 0.000005 0.14549914146182014 60 5 50 5e-11
R 224 208 160 208 0 2 4000 5 0 0 0.5
d 224 208 304 208 2 default
c 384 208 384 272 0 1e-8 12.94743904804715 0.001
l 336 208 336 272 0 0.1 0.004471363575513091 0
w 304 208 336 208 0
w 336 208 384 208 0
w 384 272 336 272 0
g 336 272 336 320 0 0
o 2 1 0 4098 20 0.1 0 2 2 3
o 3 1 0 4098 20 0.1 1 2 3 3
« Reply #2 on: January 12, 2024, 14:27:20 pm »
How about this one? Added a resistor for preventing the leaky cell to leak to ground.
Input is 24v and LC is doing almost 30V...
R 224 208 160 208 0 2 4000 24 0 0 0.5
c 384 208 384 272 0 1e-9 -5.3304916036722716e-11 0.001
l 336 208 336 272 0 0.01 0.015731775123604987 0
w 304 208 336 208 0
w 336 208 384 208 0
w 384 272 336 272 0
r 336 272 336 320 0 1488
g 336 320 336 352 0 0
o 2 1 0 12290 29.851620783001223 0.0001 0 2 2 3
o 3 4 0 12290 29.879374367328996 0.0001 1 2 3 3
« Reply #3 on: January 12, 2024, 14:36:00 pm »
or at 50khz
$ 1 6.25e-7 0.14549914146182014 60 5 50 5e-11
R 224 208 160 208 0 2 50000 600 0 0 0.5
c 384 208 384 272 0 1e-9 586.9033082256366 0.001
l 336 208 336 272 0 0.01 -0.14125218975098347 0
w 304 208 336 208 0
w 336 208 384 208 0
w 384 272 336 272 0
r 336 272 336 320 0 1800
o 2 1 0 12290 766.5923081657502 0.0001 0 2 2 3
o 3 4 0 12290 770.6036791260528 0.0001 1 2 3 3
« Reply #4 on: January 20, 2024, 06:41:33 am »
Is that the secret?
In this words I guess he is saying that at resonance the current on the components will cause the voltage to be greater than applied voltage... the voltage will depend on q factor...
He seem to say with that the resonance will allow a higher or different electric field 🤔
« Reply #5 on: January 22, 2024, 09:06:09 am »
Is that the secret?
a different? What does that mean?
« Reply #6 on: January 23, 2024, 00:15:07 am »
When I did some tests feeding the cell with dc current thru a coil i was expecting that when I applied ac on the cell thru a capacitor  would have mixed the electric fields in the cell however kind of it just worked in parallel being the cell connection just the point where the two circuits meet.
I was expecting that when I modulated the cell positive the choke would reinforce it and if negative the choke would absorb it.. it did it but not as much as I wanted.
When a coil find a higher resistance it need to develop a higher voltage to keep its current flowing so my idea was perhaps that maybe one coil modulating each other could give rise to a high voltage or field when they interfere with each other
« Reply #7 on: March 13, 2024, 11:03:44 am »
Please run this simulation:
$ 1 1.0416666666666667e-7 0.8031194996067259 34 5 50 5e-11
T 64 176 128 208 0 0.02 1 2.220446049250313e-16 -0.008815245999079346 0.999
c 352 128 352 224 0 3e-11 517.2170237049435 0.001
w 304 128 352 128 0
w 128 176 192 176 0
w 192 176 192 128 0
w 224 128 304 128 0
w 304 128 304 176 0
w 128 208 192 208 0
w 32 208 64 208 0
w 352 224 224 208 0
v -80 208 -80 176 4 5 50 12 0 0 0.159154943092
s -80 176 32 176 0 1 false
T 192 208 224 176 8 0.02 1 -0.00881524599907968 0.008809936181268463 0.999
d 192 128 224 128 2 default
g 352 224 352 256 0 0
w 32 176 64 176 0
w -80 208 32 208 0
181 224 176 304 176 0 300.03343262931946 100 120 0.4 0.4
o 1 64 0 12291 5559.406192123504 2.10693571926386 0 2 1 3
o 10 64 0 4097 0.0000762939453125 0.8 1 1
o 13 64 0 4099 640 0.00625 2 2 13 3
https://falstad.com/circuit/circuitjs.html?ctz=CQAgjOB0AMAsYDYnJUg7AUwLRpAZkgFYBOYvPMADkr0IQCYbiERDpXX3DswwAoACogEscGhZhGIetEoh20GPXAgshSHnrFoaaISoyd+noVUFi4hBfqwbsyWFyLSxPgGN8hZZLm1l9G3l8HghmBGhFMFs8anpCWnkYaH4Ad3w4cCk-TLloPjSfMQlib3F5fPASosrvKTy0gNFCvAzC+vSmrNay9sKZOTAq-vK0zWlZYVFh9uzG6UDpvgA3VUp2Yaw16tFTNkyghUgwEmPYYlgWkr4AZ1X2RxYxh6CIADMAQwAba4xBGvG5HNnrklCosOZLNZbLBZDILvhIMwSNAAjZUXFKKJnKQ+AATf59QJ9EC4jAfACunwALnwAOaefyBWZ0A4VJ5lETVdqbdYTMaLKgQIFlFpNHrpMCQNAUPAIRCYmRSMARTKHLGQWB8AD2Kk59wCxAgUTQAUUCHihDo50cu0gVgQaENsEIazQlHNEHWKjw2vA7D1IBhFkSEQi4i0eHO8UkpgQGpU3nYPqAA
