Author Topic: why Stanley used Higher Voltage....  (Read 13375 times)
Re: why Stanley used Higher Voltage....
« Reply #24 on: September 07, 2024, 17:29:56 pm »
If you have low current at the cell, the voltage at the cell will be Current (I) x Cell resistance (R).
For an 100Ohms cell, you need 1 amp to give you 100V.
Someone need to demonstrate how to violate ohms law first to assure that he had high voltage at the cell.
It is impossible to reach kV ratings in an 80Ohms cell using miliamps... And there is no phase shift between current and voltage at the cell...
You are thinking correctly.
Watch Ravi's channel where he shows the white coating on the pipes. This plaque, or rather its resistance, increases the voltage at low current.
There are about 5 methods to reduce the current to 0.001 ampere, but they must be used all together and synchronize their work with each other
You are right, I already saw that at Ravi's channel, but all of Stans tubes have no white coating on it, so he must be using another technique...
Another point is that we cant use anything between the tubes and the water as insulator. A capacitor polarization occurs at the dieletric. Our aim here is to have displacement charges at the water, which should be our "dielectric". Anything in between will be charged instead of charging the water.
Water cannot be a dielectric all the time. Since it is saturated with ions. And therefore becomes a conductor.
In other words, water changes its physical properties 'dielectric-conductor'.
Stan Meyer said in one of the videos that the longer a fuel cell runs, the better it works.
It can only be one thing, calcium oxide buildup on the electrodes
« Reply #25 on: September 09, 2024, 15:20:35 pm »
Thats another question:
Will the water capacitor resonate since it behaves like a resistor and does not have any phase shift between voltage and current?
Resistors can resonate if the frequency if high enough to use the leads parasitic inductance and body capacitance, but it should be a very high frequency (MHz range probably)..., not a few kHz.
« Reply #26 on: September 15, 2024, 02:56:33 am »
Meyer probably tested various waters for resonance cell. , Tap water, rain water, distilled water+ double distilled water, and de ionized purified water. The higher resistance was made higher with tubes coating applied for certain tube cell assemblies. The secondary wiring on ferrite step up transformer was also resistance type wire on some assemblies. (not copper). The L coils and C of the water was resonant to the power supply frequency applied. Water level had to be kept at level, or an automatic electronic adjusting circuit applied for the changing frequency with water level change. He had said that de ionized water was best. It can be purchased in small quantity for bench tests. See also used home water filter system and change the cartridges for de ionized water SOURCE from tap water input. The final voltrolysis water cell should show only extremely fine bubbles rising up in concentric tubes to fast foam generation of ionized hydrogen and ionized oxygen, at extremely low watts input.  (not h2 +o2) No electrolysis at all, - small current IN PRIMARY and through inductor coils to cell,for repeated polarization alignments of water molecules , before the high volts from FLYBACK effect was applied.This is called burst mode , with on + off time of high frequencies pulse train. Something like 3 seconds on and 7 seconds off. Gaseous fuel developed during P.S. off time. The Patented term wording is- Thermo Explosive Energy. and over unity.This bench set up is a more important project to do than others you have in mind, or on going. Stan Meyer U S Patents time has run out and are in public domain. His brother and his own Patents only have to do with selling you hydrogen gas at a gas station. Don't forget the Meyer 2 manuals. Water Fuel Cell Company Manual + Birth Of New Technology- for purchase or read on line............. Go!
« Last Edit: September 15, 2024, 03:43:55 am by russrHHO »
