Author Topic: My new approach  (Read 368284 times)
0 Members and 45 Guests are viewing this topic.
Re: My new approach
« Reply #584 on: August 16, 2024, 22:48:58 pm »
The main component of Stainless steel is Iron = https://en.wikipedia.org/wiki/Iron
Re: My new approach
« Reply #585 on: August 17, 2024, 17:09:15 pm »
Yes they have, but they are not ferritic types of SS. They are austenitic. They can withstand corrosion better then 410 or 430 SS (which are attracted to magnets due their ferritic or martensitic structure).
Re: My new approach
« Reply #586 on: November 26, 2024, 05:59:26 am »
Im looking for some piezo disks and plates for use as sensor and electrode
I found that they sell batio3 with silver electrodes and also
This is interesting
There was this patent that used pzt as dielectric hydrogen energy generation
There are Teflon coated disks
Hopefully I can buy some different types for testing
The objective is to have two piezo one for detecting and one for driving the resonant cavity
The modes possible are radial and thickness
I found that to raise the displacement we can stack the disks and the frequency can be tuned adding weight
For example you decide to buy a 200w 20khz transducer to make it have 10 kHz you need twice the length of the horn or something
The tube must have the double helical separator to allow the lateral movement to convert to linear
This should be a ceramic like material to allow high quality factor on the cavity
The length to be considered is actually the length of the gap forming the spiral
And so a cavity below and above must compensate for the rest of the wave crest
The Chanel on the electrodes must have the size smaller than the wave to catch only the point where the displacement is maximum to be able to develop the highest possible voltage
Placing a magnetic static field and applying ac to the cell must give a current peak at the resonant frequency
Knowing the frequency than is possible to tune the coil to that and apply pulsed dc to the water
When the thing is tuned a second pulse will appear with same polarity and amplitude as the applied pulse
This is the restoring force of the cavity in action
The pulses will only look good when in perfect sync otherwise the second pulse may look like a piece of ac
As you see the important is just to interact the fields and make it become movement of particles and pressure oscillation
Even applying full wave bridge rectified dc it does not really matter
The important is the flip of the magnetic field be in sync with the cavity tune
Simple as that
Hahahahahaha
Re: My new approach
« Reply #587 on: November 26, 2024, 06:00:49 am »
Im sorry if your first impression is that this is complicated
But I’m sure if you take a small time to check what I’m saying you are going to be amazed
This is not for lazy people it will take a time to understand if you don’t have knowledge on all this areas I’m talking about
But if I could get here and I’m a musician autodidact for the most part on science and live in a 3rd word country (ok I studied some physics too)
Well than you certainly can understand
Perhaps all you need to take out is the shame and ego out of the way
There is no shame recognizing someone work
Is a shame not being able to read and discuss something just because you don’t believe!
Or to not believe just because someone in a 3rd word country found something you didn’t
The graph on attachments show the current look when we apply dc to the cell and match the Magnetic field frequency with the cavity
If the dc had the same voltage as the bemf the current would result zero
And if only their voltage are different the waveform will be like the bemf
As you can see the frequency double!
« Last Edit: November 26, 2024, 06:55:04 am by sebosfato »
Re: My new approach
« Reply #588 on: November 26, 2024, 15:41:26 pm »
In this graph the b field is the resonant current flowing in the chokes
The bemf is being generated by the movement of the particles started by the dc voltage and deflected by the flipping magnetic field
And the magnetic field flips in sync with cavity resonance of the particles the current maynever change direction it only increase and reduce depending on the voltage difference between the applied voltage and the bemf divided by the water resistance
So just as Stan explain he need a resonant cavity to make it work
I think there is even more to it but it will only come out as the first part works for example the electron extraction!
There is so much more to do that we need to get this restriction to work as soon as possible…
Re: My new approach
« Reply #589 on: November 29, 2024, 06:55:39 am »
Did you know that a multilayer coil will accumulate charge only at its outer layer surface ?
That because faraday cage effect caused by this outer layer of conductor
So when designing for electrostatics things like where the coil start and where it ends with a determined polarity play a big role
Meyer put the formula for the voltage potential in a dielectric where medium is r
I have this old idea that maybe the electric fields could themselves restrict the current but only today I found a way to combine it in a way that may be testable
The idea is to have two cells connected by a tube in form of u shape for example
Very pure water and  now a set of coils placing a very high voltage between the inner electrodes of the two cells
Than each cell has a isolated coil that feed it thru a diode half wave dc
This coil must have the polarity in such way to have the outer end of the coil connected to the inner electrodes
So the idea is that the inner electrode will act as a field zone creating a electric field that is dependent on the radius and voltage and radius
This electric field is sustained by the first coil mentioned that charges one cell in reference to the water thru the u shape tube
The current will be very small since water is pure and so they are pretty much at infinity from perspective of capacitance in relation to each other cell
So the field will be positive and negative if no diode is used and we could even add a ground in the middle of the u shape and apply positive only to both inner voltage zones
So perhaps this field can hold to the electrons impeding the outer electrodes that are positive  to make current flow
Indeed the charge should go to the outer electrode right but if the coil that feeds the cell has the outer wire connected to the inner electrode the charge won’t be able to go thru the coil
Here is a simple drawing
A changing electric field is equivalent to a changing magnetic field that is changing current or some times called displacement current
