Author Topic: My new approach  (Read 379092 times)
0 Members and 76 Guests are viewing this topic.
Re: My new approach
« Reply #528 on: June 16, 2024, 09:50:26 am »
The rolled idea has one more idea
Triboelectric effect
Runing water against dissimilar plastics generated positive and negative charge this act as a kind of deionization
So having this sandwich of plastics could be interesting with water being forced thru it
Water purity has to do with the velocity the particles can reach
Is obvious that the higher the voltage we can apply to water the higher will be the velocity of the ions In it!
If there few of this ions they are spaced apart and has a lower force of attraction to its counter ion
So if we have few ions we can apply a higher voltage for a lower current flow
Why is this important?
Because the laws of induction and Lorentz force depend on the velocity of the particles in cutting the fields
So basically the cell is a small particle accelerator
The greatest is the voltage the higher is the speed of the particles than and the greater is the force they experience or better the more their path will be deflected by the field
So in short cern makes a huge particle accelerator seem the only way to accelerate particles but actually everything is moving, even heat is a kind of chaotic movement of particles at very high speed
Aligning this already contained energy of vibration to one singular dimension instead of 3 may be the cause of why it should be a could process
Hope you have a great weekend because here is only work
Just back to the tribo idea to make clear when you charge by friction you easily get thousands of volts because you are stealing the charge from the plastic is  becomes static  and of course can be discharged but you get the idea
In Italy I made Lots of test it’s Mylar a kind of plastic for capacitors I got from RS components at time
It was from 3m
Had like 0.000025m thickness this is the one I rolled years ago
« Last Edit: June 16, 2024, 10:27:59 am by sebosfato »
Re: My new approach
« Reply #529 on: June 16, 2024, 10:48:13 am »
If water is placed on a magnetic field the particles will tend to move in the direction of the field because they experience force in the other directions
Now what if we place magnetic particles in water like neodymium etc well if they are ions they can be accelerated
That’s where the epg goes
The epg is certainly a resonant primary coil or a Tesla coil like primary
It should resonate at high power with capacitors like an induction coil
The material inside will have this voltage as acceleration force and probably as ionization source
The coils on the outside makes the molecules flip the magnetic fields and the more they flip more they will generate electricity supposedly
You get two magnetic fields going one vertical and another from the coil in the perpendicular tangent direction to the other
Magnetic of the coils is needed to make it work so it act as a generator but need a power supply to start operation
Re: My new approach
« Reply #530 on: June 16, 2024, 11:02:51 am »
I believe manganese iron and  nickel gadolinium could be ideas
Mixed with water and forced thru the epg by the gas was what meyer seem to be doing
Perhaps some other possibilities is that it was gas filled with co2 for example exibis supercritical behavior
And is a great solvent
Can be pumped
And is easy to obtain
Or maybe other gases…
Magnetic fields has to do with unpaired electrons
Water has 2 paired electrons nickel has 2 unpaired
Oxygen however in its gaseous form indeed is magnetic so water in its formation somehow loose this magnetic field when the hydrogen pair up with the oxygen losing its electrons to oxygen orbitals
Re: My new approach
« Reply #531 on: June 16, 2024, 22:40:18 pm »
First step done
Feedback working as I predicted
With a loop of wire you can show where phase inversion works walking with it in the core
When unload automatically switch to zero phase
Check YouTube I will put a live in few minutes showing it!
I’m just trying t get rid of the noise that unconnected coils are causing by oscillating
Is incredibly nice when things work as predicted
The only thing I noticed is that water is leaking a little in the screw
I’m wiring one thing at a time to test each part individually
What’s interesting about this is that the coils are connected in series with fields adding and it gives a 180degrees phase
All because of the leakage inductance that as I explained act as a high inductance in series with this secondary having low coupling because of the position on the core so this secondary actually act as a primary coil to the feedback coil and it win the battle when it’s heavy loaded because the load lower its voltage to a minimum so the other secondary in series win and make it reverse phase while if the load become high impedance the current flow is low and the voltage drop is low so it start summing voltage with the other secondary
I may have be luck to get the exact range that I wanted
Or is really that simple
Resistive wire would probably do a better job not showing this ringing that I mentioned
The thing is that it need some load to invert the phase I tested with 120ohms rapidly and it already inverts
Above some kohm it don’t revert only clean the signal
Re: My new approach
« Reply #532 on: June 16, 2024, 22:44:59 pm »
Another problem I see is the feedback amplifier was set for the piezo sensor and is not very stable with a single turn
I may need more turns to stabilize it or maybe try another topology
Re: My new approach
« Reply #533 on: June 16, 2024, 22:56:49 pm »
So I’m sorry if you think different or disagree
Is just there in the face of who has clear mind to understand and actually see it working
So the pll feedback and scanning circuit  and vic together is a system to tune based on load condition! Period!
Now the load is the dc current that can flow on water and the required fields the only one that will lower is the dc
So is obvious now?
Re: My new approach
« Reply #534 on: June 17, 2024, 00:52:56 am »
The pll is locking in upper harmonics probably the self resonance of the coils when I open circuit
It’s locking to 151khz
When the of set is much off it won’t lock
The transformer sounds like an old Fm radio trying to find tune
Seems like I’m trying contact with the aliens actually
The sounds that come out from it and the frequencies it’s showing are really not consistent
The scanning ckt stops seeking when lock of course and it than stay locked
Re: My new approach
« Reply #535 on: June 17, 2024, 10:03:45 am »
Here it goes
This is how the coils were secretly connected
The resistive magnetic wire was a manner to lower the coupling of a coil in a ee core transformer
And also reduce ringing noises
The cc core the coupling can be controles easier
There are also other ways to control coupling
For me he was trying to find a fancy way to hide the feedback in a manner that would be very hard to understand it’s working without having it open and inspected but would be impossible because it would be encapsulated
Anyone would think it was tuning to the Lc circuit and not to the phase reversal
I hope you enjoy my where is Waldo drawing style
« Last Edit: June 17, 2024, 15:52:06 pm by sebosfato »
