Author Topic: My new approach  (Read 386129 times)
0 Members and 109 Guests are viewing this topic.
Re: My new approach
« Reply #464 on: May 21, 2024, 22:58:04 pm »
Spend the whole day thinking how to put more power out without burning the igbts
Coming to the conclusion that the core has a too much mass
I would like to be able to transfer up to maybe 200w at least for the resonance
So I may give a shot direct pulsing the 150v to the bifilar coil and try to get some power on it
The coils in series give a total of 160ohm plus the cell resistance should be limiting the power some
However all the power will be into it
« Last Edit: May 21, 2024, 23:19:54 pm by sebosfato »
Re: My new approach
« Reply #465 on: May 22, 2024, 08:49:15 am »
Hmmm... resonance in the upper coil cap and bemf from the whole...
Re: My new approach
« Reply #466 on: May 22, 2024, 11:43:03 am »
You mean the feedback being pickup ?
Did you notice the pulse length only change where I’m within a certain range of resonance?
I felt the capacitor was sucking up the energy and I think that maybe it cause a input source impedance to be much much low 20uf at 10khz is 0,8ohm
I believe that improving the coil leakage inductance will reduce the kickback of energy
That can be done packing the coils together interleaved
Having coils on independent coil formers is not a great idea on higher frequencies I guess
Specially if not giving square wave but pulse
Re: My new approach
« Reply #467 on: May 22, 2024, 12:44:21 pm »
I just did some tests with the lrc meter to find the leakage inductance and basically it seem the position in the core has a great effect on it
Also the turn ratio have an effect on coupling and leakage inductance
With that in mind now I’m making a new design using the cooling machine to make it really fast hopefully
The secondary may be wound first with 150 turns and than the primary with 50 turn
At full volts in this should give 450v to the coil
Having the chokes wound over the primary with another 50 turns may help
Re: My new approach
« Reply #468 on: May 23, 2024, 01:43:47 am »
I just finished the coil machine it’s already with wire in ready to go
I just don’t have much of a clue how to do it
The fluidnc seems to have many configurations
I need to make some kind of comanda to use it
Re: My new approach
« Reply #469 on: May 23, 2024, 22:34:14 pm »
Im  able to make coils with very nice precision now
I created some macros to wind to the right or left
And wind ten coils to the right or left
Or unwind to the right or t the left
Very simple very easy to use
The step I made according with the wire diameter
In the case of the video is ,56 mm step
I kind of reduced the acceleration enough to get a nice fluid movente
I’m happy that worked at least for now
It may be very helpful
Re: My new approach
« Reply #470 on: May 24, 2024, 15:56:54 pm »
Work perfectly! Is very very useful to get the coil done fast and perfect!
I’m doing a secondary coil having 240 turns of 24awg
With 45 turns of 18awg on top of it as primary coil
Than another 45 turn coil over it to work as the clamp coil on the regenerative snubber part
It will have maybe 4 taps so I can select the level of collapsing voltage
On top of the primaries goes anothe portion of secondary coil to maximize the coupling being connected on series or paralllel with the one wound below the primary
On top of that goes a single layer forming the charging choke
I will be pushing 150v volts in so with the two secondaries 5:1 I may be able to get 1500v at maybe 500w
Hope to be able to at least fry the bifilar coil
Re: My new approach
« Reply #471 on: May 25, 2024, 06:09:14 am »
What’s is most important from all this is that
Meyer transformer that was found was not the real deal
It could have being done by someone trying to replicate his work already if not him self to mislead we all
I say this because that transformer was not capable of putnot even 5watts out making an educated guess
I can say that with some confidence after so many years testing and specially from my recent tests where simply the energy was not being capable of pass thru the core of the coils are not very close together
So the Vic with all those coils That was only conceptual not real !
Something else is the switching
Where he didn’t actually show any good way to have the high voltage on the switch
So basically we shouldn’t believe 50% of what was found after 1998
I was discussing last night my theory with a friend here for the first time and for him was very plausible that meyer hidden the key concepts for him self
In my opinion meyer didn’t make it out to the world because it was too dangerous to use and so he wanted to perfect the injector idea and this is the biggest mistake a businessman can do that is to mind how your tech will be used!
Of course he wouldn’t like seeing people bombing each other with the technology so he seem to wanted to make it punctual by his injector minification
Investors may have disliked
Anyway the real point when you do what a real device need to work you will come to this
A transformer need to work
It need to adapt the voltage in to the desired output .
I will post a new video pushing the bifilar to its limit now with the new transformer
Let’s see how much it takes for it to fey
« Last Edit: May 25, 2024, 07:00:31 am by sebosfato »
