Author Topic: My new approach  (Read 379093 times)
0 Members and 76 Guests are viewing this topic.
Re: My new approach
« Reply #400 on: April 29, 2024, 16:07:14 pm »
Let me give you the patent numbers
https://patents.google.com/patent/US20060180473A1/en
https://patents.google.com/patent/US20030197093A1/en
According to him he talked to aliens and it’s in the patent!
Seems science fiction but look at the circuit!
I tried to contact him years ago no success
Today there are videos on YouTube about his inventions
But what it seem to me is that is some kind of same effect
After all we are driving crazy electro magnetic and acoustic fields on the cell
As I explained the polarization coming from the cell itself we simply can’t put current into it leaving only to easy the voltage to get in.
Resonance is used to max out a laminar flow oscillation of particles that are forced into and out of the cell from and to the cavity
In the case of the injector probably is not needed all needed is high pressure plus the vacuum of the engine to achieve enough speed to convert the molecules by the fields instantly
On that case a permanent magnet can be implemented to make the field because it’s unidirectional Flow assuming 1200bar of pressure is enough  and that resonance is dispensable
As I mentioned before the stainless steel wire is a great way of doing high voltage electromagnets but it can be done with copper too
Just need higher current
The magnetic material contributes to the magnetic field of the current
Re: My new approach
« Reply #401 on: April 29, 2024, 16:43:24 pm »
I would say the Vic’s worked in a sequence of pulses for the injector each one giving a pulse to it
Re: My new approach
« Reply #402 on: April 29, 2024, 23:33:19 pm »
John Quincy describes exactly this but saying that he uses vacuum only and that when under such bucking fields the water bonds ceases to exist because it spin down the electrons to the speed of hyperspace
Well for me is all that alien story is coded info!
 I described a totally plausible physics explanation behind the amp restriction and how is related to the polarization process…
John talk about the curvature of space time that is created with all this and at the end the dynamics come from the relative movement of water in relation to the fields
Re: My new approach
« Reply #403 on: April 30, 2024, 01:21:44 am »
Lesson of the day
R2/R1 = R4/R3
Differential amplifier Finally rejecting common mode signal correctly  working
Somewhat is still unstable … now I think could be that it’s driving a led
I used 750ohm and 100kohm as resistors
« Last Edit: April 30, 2024, 03:31:31 am by sebosfato »
Re: My new approach
« Reply #404 on: April 30, 2024, 05:09:27 am »
Now it works perfectly
I added a 100k resistor I parallel with the sensor to discharge its natural polarization first
Second I added a 4,7k resistor from 5v to the negative input
The led and bnc is connected directly without resistor to ground
I could add a low before led and bnc a resistor to get the wave at the bnc more clean but didn’t
It worked like perfection I could even say that it misteriously is the same circuit of Stan patent
The led lights up only under strong feed back
It pick up zero noise!
With this differential technic it simply make it silent as it amplify only the difference between the two signals and not reference to ground.. bringing to 5v thru the resistor seem to null the common mode noise that is everywhere in the ckt power lines
The 5v connection was game changing it made it ignore the noise caused by the pll and power line and whatever oxidation all together
I tested with the ultrasonic umidifier and now is much better than the original circuit
The original was not inverting so I had to unsolder all the resistors and capacitors that came in the board and soldered big components
The diodes are 1n4148 they are there only for helping protection and also to give a small capacitance to the sensor signal
Whatever feedback sensor we may want to use it seem compatible
Such a coincidence that it worked perfectly for the piezo
Re: My new approach
« Reply #405 on: April 30, 2024, 06:10:59 am »
Better than this only a instrumentation Amplifier because it would allow to add a potentiometer to control gain
The down side is that it would include some minimal delay
With the single differential amplifier
The way to change the gain without loosing the noise rejection is to use a very well balanced dual potentiometer on the input
Using high speed chips the delay will be small however from tests I did on the past the minimum delay on the feedback won’t allow the tuning to reach the maximum
This is why I started investigating high slew rate and Bandwidth opamp and work with 5v pll and logic that is much higher speed…
The feedback as I explained could be other types like a coil with a permanent magnet
Or even a resistor with a pulse transformer to get the current
Now the important is that current will be in phase with the voltage on a series resonant circuit
That means that if one coil is resonating with a capacitor in parallel and this is in series with the water
The current would drop to zero when it start getting a signal from cavity
So if current is the feedback it would not be useful other than an indication of lock condition
Another possible feedback would be to simply add the feedback coil or transformer in series but it need to be very small inductance (maybes current sensor like)
Seems like this second inductance could resonate with water capacitance
I’m sleepy
Re: My new approach
« Reply #406 on: April 30, 2024, 08:53:39 am »
He experienced a full body hyperspace teleportation.....   ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Thats what is written in the patent....
OMG
What did he smoked?
Content wise, it is interesting to read.
Re: My new approach
« Reply #407 on: April 30, 2024, 08:56:09 am »
How in Gods name did he get that patent? He mmust have shown a working model, is it?
He writes that he meet grey aliens in the Patent!!!
Which patent office believed him?
This is so wierd.
