Author Topic: My new approach  (Read 294629 times)
0 Members and 186 Guests are viewing this topic.
Re: My new approach
« Reply #392 on: April 26, 2024, 18:36:42 pm »
I really like the capacitors siting at the flex cable around the laser tube that discharges with the lowest inductance possible
Also the pre ionization I never saw it before
I’m trying to work on the simulation but is very hard to do
Watching some videos of turorial to get some ideia how to proceed
Re: My new approach
« Reply #393 on: April 26, 2024, 22:59:47 pm »
With this program we can even simulate the effect of the magnetic wire on the coil…
I just don’t know yet how to do it if you want to help me let me know ! We can use it sharing screeen etc
Re: My new approach
« Reply #394 on: April 27, 2024, 06:13:27 am »
Is sad to see how few remained
As I’m telling my friends down here
Some times humanity lose its goodness.
Is up to the few get it going.
Re: My new approach
« Reply #395 on: April 27, 2024, 18:05:52 pm »
youtu.be/BjaLvwcfYTk?si=GXyk6zVVeCOB4NMe
youtu.be/pCnXftuJ9Zo?si=mK0lL19Q5znpRhwI
Me and Steve were talkin abou this videos
You remember that nanopulse patent with the scrs? In this video it seem to me that it’s exactly that circuit
Re: My new approach
« Reply #396 on: April 28, 2024, 12:09:52 pm »
I did simulate the magnetic field and I confirmed my theory
In the center it will be weaker than on the gap
I would like to spend more time on it
It helps
Re: My new approach
« Reply #397 on: April 28, 2024, 12:57:06 pm »
Synchronous resonant Alternator
If we apply this same idea to an alternator making its field coil resonate with a capacitor at the phase controlled by the frequency output of the alternator
It will output a doubled frequency unipolar output without any diodes on each phase
This is a way to generate dc without diodes if you want to get the maximum efficiency
Of course it need fixed speed in this
Obs not all kind of alternator
« Last Edit: April 28, 2024, 18:39:36 pm by sebosfato »
Re: My new approach
« Reply #398 on: April 28, 2024, 18:33:11 pm »
Stanley meyer was really a genius
John Quincy saint Clair patents or wormhole and hydrogen generator are totally releated to Stan tech
At the end we are indeed creating a kind of space time curvature that is literally step by step increasing the polarization inside the molecules
Talking to another friend I ask if you have  dc motor spinning and you feed 100v and it has 100ohs resistance
What is the current? It’s much much smaller than 1 amp only a few ma
That because the effective voltage in the circuit must be reduced by the back emf of the motor
So if the back emf is 98v you get only 2v producing current
With that said the technology of the injector may be simply inject high pressurized water into the bucking fields with correct shape geometry
In that situation water would spliti instantly during the intake just need the correct pressure and fields
Re: My new approach
« Reply #399 on: April 29, 2024, 09:58:41 am »
Ok, Fabio, i try to followe you here, but i am not getting it.
Is there a patent on wormholes?
