Author Topic: My new approach  (Read 287955 times)
Re: My new approach
« Reply #360 on: April 15, 2024, 16:13:03 pm »
When I mean the voltage on the cell is dependent on the current timed resistance is because the resistance of the cell will increase and this current is actually coming from the higher voltage that charges the resonant coil the high impedance that makes the cell rise voltage if the resistance rise (at same time when the water resistance rises it will reduce the voltage on the resonant coil because it now have a resistance for charging it…
Understanding that try to understand the rest of the lines…most were suppositions
Did some tests today but could not prove the pumping effect… because magnetic field is too small now
It did pump however seem to be more because of the Bubbles forcing
I was considering the problem of increasing the magnetic field and realized something is really confusing me
If you consider a coil inside the hollow inside electrode with same directions it would have a north pointing up like the outer. For example
Initially I thought this would impede the magnetic field lines from the outer coil to pass thru the inner electrode however
When we look the fields on the gap it seem to subtract
The magnetic field on the channel however would be cancelling so actually the coils would need to be wound and or connected subtracting fields to maximize the magnetic field on the channel apparently… I’m not being able to logically determine what would give the highest field
The inner coil I’m doing over a 5mm screw for a small hollow electrode I have  that I want to test to check this
What I notice is that if the outer and inner coil are subtracting all induction on the electrodes will be cut out and we should be left with the least possible inductance in series and also the greatest magnetic field in the channel
I’m confuse? Did you see what is my confusion?
What is the way would give the most magnetic field in your opinion?
I think now is time to understand the power of this bucking fields like John Quincy st Clair was talking about
Re: My new approach
« Reply #361 on: April 15, 2024, 20:38:58 pm »
I tested the piezo I took out from the sr04 on the humidifier to see if it could detect ultrasonics
I added a stainless steel ground ring around the sensor that way I could get the reading  clearer
It shows 3MHz oscillation but only when it’s very well aligned to the center
Otherwise it show the gate frequency of the umidifier I guess is 40khz
The power knob  make this frequency go lower as it goes up
I believe it’s tuned above the resonance or something…
The signal out was around 100mv or so when very in the middle focus
I think to connect this piezo to those amplifier boards gor last year to make it 5v square to use with the pll
Hope I can make the water sing
I’m winding a new coil over a 5mm screw you see in the photo
I took the screw part grinding it and wound two  kapton isolator layers to wind 24awg around…
It will fit inside a hollow electrode I have here
This coil will be in opposite direction of the other on the outside but they connected in series
Hopefully this will cause a tremendous magnetic field compression hahaha in the channel
That way I hope to get it at least have double magnetic field
Also the inductance will be smaller and if the tuns are equivalent supose to not cause zero induction on the electrodes or the least possible…
That because their magnetic field would be canceling each other however there may still remain a little
« Last Edit: April 15, 2024, 22:39:41 pm by sebosfato »
Re: My new approach
« Reply #362 on: April 16, 2024, 09:16:14 am »
First tests with the new coil was a little deception however may still be useful
It end up with 6 layers of 80 turns
The magnetic field was 1mt near the ends and 0,5mT around
Although very small I I’ll test now if it will help avoid the field lines of the other coil in its region that would help the field to concentrate on the gap only
Now I’m just hooking the piezo to the tlv 3501 to see if can give a good square out of it
Re: My new approach
« Reply #363 on: April 16, 2024, 15:11:32 pm »
[youtube] https://youtu.be/U6SoBAs1ixE?si=OTjztQF9805EABoy[/youtube]https://youtu.be/U6SoBAs1ixE?si=OTjztQF9805EABoy
Re: My new approach
« Reply #364 on: April 17, 2024, 04:00:18 am »
Worked all day on the pll circuit… preparing it to pulse hard
One thing that occurred to me is that now I need to put some pure water in the cell for testing
Actually I think that the interaction of the electric fields will be important and having contaminants will reduce too much the voltage
Having higher voltage mean the particles need more speed to reach the other side…
I almost have the impression that the current makes very small effect on water for some reason
At 240v apliedit boils directly
My best guess is that when there are fewer ions the current will be less on the surface of the electrode only
« Last Edit: April 17, 2024, 05:20:58 am by sebosfato »
Re: My new approach
« Reply #365 on: April 17, 2024, 14:21:47 pm »
Why magnetic wire?
Copper has a conductivity 58 times greater than iron
Iron has 200 times more magnetic permeability than copper
The magnetic field of a coils is zero on its avarage radius
That’s the reason the coils need to be bucking fields subtracting to get a region in between them
This is dark side of physics somehow because is where people are not looking into
Every second it pass Im more certain that Meyer was indeed using coils around and inside the electrodes
Hope to be able to at least prove the amp being restricted
For that I’m going to have a current and voltage probe at the cell so I can see their interaction
I also added the sensor to detect the vibration if is going without it I’m not sure it will restrict anything
I hooked the sensor to the pin 14 of the pll as feedback and hope to sustain the oscillation
Than I can change the cell tube by turning the bolt increasing or reducing the cavity
Re: My new approach
« Reply #366 on: April 17, 2024, 19:12:58 pm »
The tLv 3501 is self oscillating at 140Mhz
It does even without the sensor connected
Maybe too high the input impedance
Trying to figure a way to make it work
Any ideas ?
Re: My new approach
« Reply #367 on: April 17, 2024, 21:30:46 pm »
https://www.ti.com/product/TLV3501
I couldn’t find a way to stop the oscillation… I added a capacite to the output and reduced a little but not stoped
If any of you could help I appreciate
I’m working with 5v
I believe this will be one of the most important parts of this technology
