Author Topic: Back to Basics  (Read 81478 times)
0 Members and 34 Guests are viewing this topic.
Re: Back to Basics
« Reply #160 on: November 17, 2024, 16:30:36 pm »
by using a spark bridge?
Re: Back to Basics
« Reply #161 on: November 17, 2024, 20:02:43 pm »
Who said anything about blocking current.
None other than Stan Meyers himself. He said many times ".... yada yada, Blocking diode..." and the diode is in every "circuit" diagram on the net.
This thread is titled "Back to Basics"
Did Stan Meyer show a circuit to anyone?    The answer is no, he did not
V=IR
If you want to measure 20kV across water, which has a low resistance to electric current before electrolysis occurs, what do you suppose the amp level needs to be?
Obviously it can't be zero, can it?  Otherwise voltage would be zero.
But it can't be high current either or you will have electrolysis instead of water splitting.
So how do you get high voltage with low resistance without getting high current?
KISS
As I mentioned earlier, the VIC is a DC circuit due to the diode, but it contains a pseudo-AC circuit formed by the chokes and water capacitor. In this part of the circuit, the relationship follows V=IZ, where Z is the reactive impedance, which limits current.
The VIC leverages reactive impedance through inductors and the water capacitor, rather than relying purely on resistance. The inductive chokes resist rapid changes in current dynamically, and their opposing mutual inductance further suppresses current flow. Meanwhile, resonance between the chokes and the water capacitor allows energy to oscillate efficiently, recycling energy within the circuit to build up voltage across the capacitor over time without requiring continuous high current input. This ensures the voltage rises high enough to induce breakdown without significant energy losses through conduction or electrolysis.
The bottom line is, the resistance value of the chokes and secondary aren't as important as the reactance and impedance values being matched to the WFC at resonance because it is the reactive impedance that solves the equation of high voltage with low current.  So the WFC and chokes need to be designed with high reactive impedance within specific frequency ranges in mind based on the variable range of the capacitance of the WFC.
« Last Edit: November 19, 2024, 06:29:34 am by timeshell »
Re: Back to Basics
« Reply #162 on: November 18, 2024, 07:43:42 am »
do you have it working?
Re: Back to Basics
« Reply #163 on: November 18, 2024, 09:24:00 am »
I used to log in and keep an eye on Tektrical / electrotek. I guess people didn't pay much attention to him. He was investigating HV experiments, spark gaps, plasma etc. He was in his 70s, I guess he is no longer here. last log in Nov 2022. maybe Covid, maybe just time caught up.
I wouldn't be interested in HV across water. Theoretically, H atom is 1 proton and 1 electron. Electrons are the same thing out of a battery.
X and Z is based on freq. R is constant; V and I vary. The sawtooth output is max HV and then decays to zero. The primary circuit has switched off, so cannot be damaged by the secondary.
I experiment with HV FBT and my interest is short circuits, which is V/R = I, the R stays constant. This is why I was interested in elecktrotek's experiments with neon light transformer etc. V moves electrons, remembering there is a HV diode. FBT don't need to be "resonant", it is one pulse at any time and Idle time in between.
I never thought to ask electrotek what he thought of Stan Meyers. I don't think he was following SM
Re: Back to Basics
« Reply #164 on: November 19, 2024, 00:26:27 am »
« Last Edit: November 19, 2024, 06:29:12 am by timeshell »
Re: Back to Basics
« Reply #165 on: November 19, 2024, 05:30:36 am »
I remember reading his posts about it
My impression is that Meyer hid so well his ideas behind citation of other patents
Like the tay he Han and the ultrasonic one…
Reading that and seeing other parents that cited it as well I started to think Meyer was far more intelligent than he wanted to seem
I mean he had that thing but would not show not even talk about what really make it work but did in such a manner that show so many things and parts that keep people right off from it…
In Hollywood films this is how they explore the ideas they show you one thing to get you amazed so they can literally talk shit and you are still thinking on the shiny thing you saw before
Meyer used this to hide the essentials while he could show lots of details
In my research on the ultrasonic patent he cited I came across the phenomenon of anti resonance in ultrasonic piezo
That is welding piezo are driven this way to keep it feed with high voltage and low current so when you apply pressure and change the resonance it than suck power in and weld plastics
The thing is that applying it to water become clear that the cell is simply a resonant cavity but also possibly a transducer
So if driven to certain condition it will acumulate energy and this energy work back generating a back emf that cuts current flow
The Vic is simply a transformer to push power to the cell but it will only work if the cell have the correct fields configuration “magnetic” and frequency
Without it is just a piece of metal that will never have any other result than electrolysis
This lead to another idea that I started on the past ten years that was the water coil
Where I tried to induce the high voltage by electromagnetic
However I used a long water line and a transformer instead of a resonant atestem so although I could get some voltage the water ends when connected to each other would result in zero current
So I designed other ways of doing it
All that because if we get te energy from inside out the voltage drop should be less of a problem for efficiency since it’s reversed so we would be using the electricity and the gas
Re: Back to Basics
« Reply #166 on: November 19, 2024, 06:14:51 am »
Induction cooktop is perhaps the easier way to show
You need a two cells connected to each othe with two diodes Basicaly shorting the anode of one to the cathode of the other
Than connect this two cell with a tube and fill with water and place on the cooktop
It will show voltage on the ends
Now if we maybe match the frequency of the cooktop tank with the length perhaps we get a surprise
The tubes can be made with pvc connection for example a c shape over the cocktop and some curves to make the cells vertical and farther than the field so it won’t heat up the cells metals
If the electrodes are catalytic probably is better but than it need a membrane to separate the gases to impeded from recombining
Each cell this way should generate hydrogen and oxygen at their respective electrodes where the current flow
The potential however come from induction captured and propagated by the dielectric and cocnductive properties of water
Re: Back to Basics
« Reply #167 on: November 19, 2024, 06:37:44 am »
When Meyer says he used voltage as potential energy and water as source of electrons it become evident that the cells together with this structure and fields can propagate potential thru the water tube but capture” current at the tips by using water as source of electrons
Another way of view it is you have two baths connected by a wire that goes to a grown inside each bath
Than each bath have a cell and they are connected like before in tandem with diodes shorting the cells
If we place this wire over the cooktop it will give the baths a voltage ac but the cells will use this ac potencial and drive current thru the diodes
In this case the propagation happen thru this grounds fluctuating by the wire
So the ground is receiving ac giving to each cell half reaction
If the ground is a catalyst it may help reducing the loss of potential there and it will probably heat up on this reaction
Heat is another form of energy that can cause voltage
Well the point is without this wire and grounds the induction is propagated thru water itself
