Author Topic: Back to Basics  (Read 122439 times)
Re: Back to Basics
« Reply #136 on: November 08, 2024, 21:53:33 pm »
That's rather vague.
Re: Back to Basics
« Reply #137 on: November 09, 2024, 00:43:04 am »
the oxygen atom wants free electrons, and they have to come from some where
You've mentioned this a couple times.  But you don't really elaborate.  Hydrogen and oxygen don't combine into water just because they are mixed together.  Once separated whether by electrolysis or some other means it would take an ignition source to recombine them.  So please elaborate.
Re: Back to Basics
« Reply #138 on: November 09, 2024, 20:05:15 pm »
Oxygen wants free electrons. simple. Oxygen will bond to H atoms by the free electron or turn steel to rust. It's the free electrons in both cases.
nothing new there. we all know this, but Stan Meyer told everyone to block current. He did not show his circuit diagram.
a FBT in discontinuous mode, discharges stored energy. a normal transformer is based on winding ratios and can't do that.
Re: Back to Basics
« Reply #139 on: November 09, 2024, 21:56:54 pm »
Again, what you're saying doesn't really make sense.  Hydrogen will only bind to oxygen in gas form after it is ignited to start the reaction, which then creates the water molecule.  Otherwise, once separated, they stay separated.
The VIC's chokes are not a FBT.  The secondary attempts to energize both chokes simultaneously.  If anything the primary and secondary could be FBT.
Re: Back to Basics
« Reply #140 on: November 10, 2024, 21:16:01 pm »
The sec is open circuit, when the pri is active
The pri is switched off (open) and then the sec is active, and the diode is switched on
Re: Back to Basics
« Reply #141 on: November 11, 2024, 02:48:31 am »
Whatever dude.
Re: Back to Basics
« Reply #142 on: November 11, 2024, 20:08:49 pm »
The FBT discontinuous function is available to anyone online
Re: Back to Basics
« Reply #143 on: November 11, 2024, 20:24:08 pm »
Any yet nobody else has solved Meyer's riddle yet.  Hmmmm....
