Author Topic: Stan Meyer Patent search....U.S. Ser. No. 302,807  (Read 5921 times)
    • https://www.youtube.com/channel/UCp7oJf9m5gRPBi5PFhtsK_w
Re: Stan Meyer Patent search....U.S. Ser. No. 302,807
« Reply #32 on: February 17, 2023, 02:47:11 am »
Well, as I stated in the other post, the voltage in the cell is directly proportional to the current passing thru it. No matter how many turns your bifilar has, if it does not have the capability to feed many amps to your cell, you wont have high voltages at your cell, unless the resistance of your cell is huge (with the cell beign small). My cell has 100 Ohms resistance, I need 10 amps peak to have 1kV in it. In my case, if I had 1000t bifilar with awg35 wire, I would never reach kV in my cell, I can achieve with kV with 200t, awg23, but is pure electrolysis. If 100V is applied to a 100Ohm load, you'll always have 1amp, you'll never get to restrict the current without lowering the voltage, this is ohms law. You cannot apply 100V to a 100ohms load and have only miliamps, and it does not have anything to do with the frequency, you can sweep you cell from DC to 1Ghz, the frequency response is flat.
Make the cell resistance 200 Mega Ohms!
And when a voltage of 2 Kilo Volts is applied, you will have 2000 divided by 200000000 equal to 0.00001 amperes
« Reply #33 on: February 17, 2023, 08:04:58 am »
you also will have zero volts across the water in that way
How to increase resistance of the Meyer cell
« Reply #34 on: February 17, 2023, 11:22:37 am »
I just want to jump in here...
The most convient way of raising resistance is to create first the milkey water filled with hho.
That means that you have a 2 step proces.
1. create with electrolysis a milkey waterbath.
2. after that, raise the voltage up. The amps stay low.
Thats what Meyer did, i think.
His brother called it the cell with little explosions.
Which i can understand as i also did a test with low voltage and high voltage in a 50 50 arrangement.
The high voltage thru a cell with a milkey hho cloud is actually very DANGEROUS.
My cell exploded......
Water filled with hho is actually very conductive...
just something to think about...
« Reply #35 on: February 18, 2023, 16:36:21 pm »
Equivalent circuit of a capacitor - fuel cell.
Make the resistance Re = 200 Mega ohms and you can supply 2 kilo volts.
Where Re is the insulation resistance
Circled in blue in the picture
« Reply #36 on: February 21, 2023, 19:40:49 pm »
Yes i know that the wfc is a very leaky capacitor.
I just wanted to point out that the hho gas is HIGLY CONDUCTIVE.....
Goodluck with putting kilovolts on a running hho cell.
I hope that you have a life insureance.
ITS DANGEROUS
