Author Topic: S1R9A9M9 18HP Briggs riding mower engine ran on water( 2008)  (Read 20408 times)
Re: S1R9A9M9 18HP Briggs riding mower engine ran on water( 2008)
« Reply #24 on: November 23, 2023, 05:37:13 am »
More new data accumulated over time regarding the 2008 S1R9A9M9 (2) videos on Briggs 18HP mower engine that ran on water in carb. Several things have to be in place get the required water vapor pressure and hydrogen fired at spark plug for self running using the battery and under flywheel alternator supplied current. The Magnetron ignition volts 6-15kv, has to be raised up to minimum 24000volts. First the coil has to be changed so as to get the final POSITIVE high voltage. The twin cables type Briggs autotransformer Magnetron will do this. Next, this now positive high volts has to be increased so as more usable. A pulse step up type autotransformer will do this. The plastic deli tub as used, hanging on the Briggs back in 2008 was small, so as the enclosed parts had to suffice. My original ideas of inductor back EMF high volts and the capacitor charge and discharge parts would not fit in that tub. The pulse autotransformer would! We were shown a triple wires assembly that was associated with that engine and did several things at the same time, ..... except increasing the voltage . I propose a 2nd hand wound autotransformer was in the tub along with other parts , such as the hand wound S1R coils, accessory spark gap,Dayton inductor 1.5MH in the ignition line, resistor, and diodes. They will all fit. There was an outside cable capable and connected to original engine ground as could be used for the transformer primary. The use of positive high volts ALLOWS the side wire to ground to operate, and still fire plug. The #14 gauge wire joint on S1R coils had been cut off and had enclosed a stub wire. This was then probable as being the ground wire for the electromagnet magnetic field wire to resistor and ground, so as always on all the time. The firing of spark plug with same current 10amps was for about 34% of the time of flywheel rotation. You will have to learn the difference between a regular 4 terminal transformer, and a 3 terminal hand wound autotransformer. -- Uses 4" long 10:28 steel screw for magnetic core, with wire wrappings over 3/16" ID vinyl hose for voltage increase. This refers to the data from the old web forum regarding "the 60turns coil test". The 60 refers to the secondary turns. The primary is only part of that in ratio. The S1R coils of 13 turns + 7 turns = 20T for original electromagnet, is similar copied for the step up autotransformer 13T + 47T = 60 turns. I used 18 gauge white thermostat wire .05" diam from 2 wires loose in package- not twin connected wire.The RATIO BECOMES 1: 4.6, SO AS THE ACCESSORY SPARK GAP OF 13T PRIMARY FIRES TO GROUND ABOUT 2MM FOR 6kv IN AIR. This should result in step up to about 25KV THAT THEN ENTERS THE S1R coils to get the impressed magnetic field. The field extends the spark time to about .03second and 34 degrees late timing ATDC. Power draw from 12v battery would be 6-10 amp constant on through the resistor, and then 6-10 amps for spark plug only 34% of the time. The spark is off 66% time of flywheel going around. The cross reference for spark plug to Champion is needed so as can remove resistor from the top. and substitute copper piece. The now racing spark plug is zero ohms and can pass the amperage for electrolysis at spark plug tips. I use NGK B2LM .for short reach spark plug already zero ohms. Nathren had said the system used about 15 amps.To be able to get lower 6 amps worth of magnetic field instead of 10a, I changed the electromagnet wiring from 13 turns to 22 turns as in same ratio as current change. After battery ran the starter and engine was idling, the original battery was removed, so as the magnets powered alternator ran the system in the summer 2008 You tube videos. See the videos again . The 2 power wires and Hi V cable come down from the upper metal engine cowl and are wrapped in spiral black tape and enter the plastic holder tub. The ground wire is on the right, the lower white wire goes to spark plug with high V and 10 amps. His 2008 set up did not have battery acid protection using diode bank, from the ignition voltage going in reverse.
« Reply #25 on: November 24, 2023, 17:42:59 pm »
The Briggs Magnetron only fires a spark gap as maximum 16,000 volts. I tested this recently as  (3kv per millimeter gap.)  As 5 1/2 mm gap max  in open air .  No more. The system is lacking the higher volts for the proper plasma path for amps to pass through spark plug. The back EMF of a coil parts and parts for a capacitor charge and discharge would not fit into the deli tub as used originally in the 2008 you tube videos of 18HP running on water in carb. Therefore, what was used in 2008, was a pulse step up transformer somewhat similar to the S1R9A9M9 magnetic coils would fit along side it, along with a few other small parts. I even had added narrow Neodymium magnets glued on over top of my own  flywheel magnet on 12HP to get greater field strength.  Of course, a car ignition coil could substitute , but not wanted, since the free energy spinning magnet runs the ignition coil (original type) Magnetron autotransformer. Armature gap was about .012" to flywheel. A higher field in theory, would generate higher volts in primary, which generates higher than -130 volts back EMF to run the secondary of auto transformer, but of course would slightly adjust the timing. That did not work for > 16kv. I just built the step up type unit  recently.
« Reply #26 on: December 02, 2023, 19:39:30 pm »
Dec 1, 2023, I just built the step up type transformer recently. It is not an autotransformer. This one is a small pulse type with 4 terminals. It uses the Amazon ferrite set with bobbin called E I 40 with hand wound wires 15 turns and 60 turns for 1:4 ratio, and needs to be tested , so as proper 24kv plasma path would be available for the following 6 amps through spark plug. The Primary would spark to ground with 2mm 6kv spark gap . By the way, this would also fit inside the plastic deli tub like Nathren used in 2008 with the S1R coils assembly and relay, spark gap, diodes, etc.
« Reply #27 on: January 18, 2024, 21:11:48 pm »
Updates - notes not given before, - for those following this project. The S1R9A9M9 triple wires assembly was an ELECTROMAGNET serving 2 purposes. The field over the spark plug wire causes the required extension of spark time from TDC to about -late 34 degrees timing. (Mower engines have no timing adjustments) This also provides the needed magnetic field at the plug tips in the combustion chamber. Spark AND CURRENT is on from power supply for about 34% duty cycle. Flywheel goes around until the next firing of 1-cylinder engine 66% off time. The electromagnet is 100% on at about 4.5 draw amps from battery, hooked through it to ground adjust resistor. The original 2008 demonstration used 10 amps through plug. The Georgia technicians that converted several cars and tractor, all used 6-7 amps. Therefore, the circuit now uses adjust 100W resistor for setting of 6 amps. Total battery draw from isolated power supply, including electromagnet and fans, is about a conservative 15 -20 amp fuse. The 2008 demonstration of 18HP Briggs was started with battery, battery disconnected, and engine ran on the under flywheel alternator. Alternator was maximum 15 amps with bridge rectifier, no v regulator. W = E X I. E /R =I. The 2 analog meters were replaced with single, dual digital E + I meter which registers faster than analog with needle, and much cheaper. Diode string protection of power supply done with 2 parallel FR607 fast diodes. 15 diodes is about 2 ohms loss and 10.5V drop loss. The diodes assembly is mounted vertical on top of horizontal .3A fan facing upward in plastic chute. (Heat removal). 500W Inverter used with single metal diode on heatsink for half wave rectification and about 35 volts pulsing DC. The differing ohms resistances in series with water cell spark plug needs to be configured for 6 amps. There was question about the low 6-15KV output of mower engine coil to satisfy the requirement of plasma path needed. The car engines has HEI much higher voltage which allowed the extra amps to pass through the spark plug. The earlier car conversions and Briggs 18HP all had included special relay per cylinder use. Took about 3 months to determine and build replacement in sealed vacuum box ACCESSORY spark gap with N+S magnets, inductor 1.5mh diode inductor 1.5mh and diode. The entrance of the high voltage is exactly at the cathode of the center ON diode. Diode shuts off, High v presses, returns back and onward to spark plug. This releases Tesla's radiant Energy from the diode that passes on down to spark plug, aided by vacuum. This notion is probably what was used causing a successful 2008 You tube S1R9A9M9 demonstration. They had converted a 4 cyl tractor to water in carb also which used the relays , Inverter , and existing ignition coil that was the same 15kv as the Briggs engine!!!!!! Therefore an extra plasma path source was not needed. The radiant energy expulsion takes the place of extra plasma path. I had recently made an assembly for a separate plasma path if needed with a 15KV coil , to allow 6 amps to pass.150W 220v dc converter charging 47uf 400v low esr capacitor through 60 ohm resistor to form time constant discharge with 120ohm resistor. T = R X C as 63% charge and discharge as plasma path with the 15KV. Main power supply also hooks in. The extra spark gap insures the final spark gap fires.The original Chevy V8 converted , had ignition coil in distributor cap changed primary wires around so that only positive high voltage was used. I am using a DUAL CABLES Briggs Magnetron- the modern type with universal epoxied trigger, - not a Briggs trigger. This one is not an autotransformer. The secondary wiring is not connected to the primary side. One cable goes to ground so that other cable is FULL POSITIVE high volts as used for the project. There is a one amp diode string 15kv for postive ignition coil. The 2 adjustable 100w power Ohmite brand resistors are mounted vertical. The Electromagnet is mounted vertical. The modified electromagnet has steel long screw with plastic pull head and inside vinyl tube so as can be pulled upward for timing adjustment of engine. Nathren only said to adjust the number of lower turns. 7 turns 90 degree wind upper, with lower 13 turns 14 gauge wire .The upper has no core on 7t. Pulling upward removes the core so as less magnetic field over HiV wire. Now you see how it's done. See Internet photo of S1R9A9M9 coils as (4) wire ends. Back then, mineral water from a property spring was used on all engine carburetors. Hydrogen gas is generated as spark plug electrolysis, fired and forming water vapor pressure along with the hydrogen. This was their invention back in 2005-2012. Website shut down but you can see again Nathren's 2008 2 Youtube videos of Mower engine running on water in carburetor. Questions??
« Reply #28 on: January 21, 2024, 02:10:36 am »
In Georgia 2005-20012,  three technicians ran car engines on MINERAL water in carbs 6-7 amps electrolysis from half-wave DC of 400W inverter and inductor coils, diodes, etc. The zero ohms spark plug passes electrolysis 6 amps using higher voltage inductive ignition.  4 cylinder  tractor, (2) V8 Chevy engines, 4 cylinder  pinto, and On YouTube video for 2008 a Briggs 18HP engine running idle on water only. There was an electromagnet forming field 4.5A over plug wire, and the necessary field carries on to the combustion chamber. The lawn mower battery was disconnected after starting. The under flywheel magnets powered the Briggs at 15 amps max with bridge rectifier. See S1R9A9M9 mower engine running on water. The generation of Hydrogen and firing, and production of water vapor pressure both ran the engines. This was their discovery. All have accessory spark gap and insures final gap fires.  E.G.R has to be applied to get the added Nitrogen embedded in the expelled water from compression.  Working on bench set up to duplicate. 1978 El Camino 18MPG at much lowered power. Mower engine easier to work with. (The increased efficiency may have to do with Radiant Energy expelled from series line diode when POSITIVE High V enters exactly after cathode. The ON diode shuts off, the High V presses there, then reverses to fire the spark plug. R E follows to spark plug tips as the inductors and diode were IN VACUUM CHAMBER) So now you know!
« Reply #29 on: January 22, 2024, 09:11:56 am »
"The generation of Hydrogen and firing, and production of water vapor pressure both ran the engines.""
I agree on that this might work  :) :) :) :) 8)
« Reply #30 on: January 23, 2024, 22:21:01 pm »
Now looking into part numbers for stainless steel (marine) spark plugs for small engines. The Champion Brand sometimes has a removable top, so as the resistor or wire coil suppressor can be removed, and replaced with copper segment wire. A zero ohms spark plug is needed, that does not rust and add ohms resistance to the series current passing through it. The normal steel type tips corrode and reduce efficiency with mineral water added. The negative ground tip extension is preventing current flow on the meter. Baking soda water with eye dropper will be bench tested for use with SS plug. Nathren from Georgia, (S1R9A9M9) used mineral water gathered from stream on the property and was used on all previous engine conversions 2005-2012.
« Reply #31 on: January 27, 2024, 01:48:16 am »
 The gasoline vapor carb effect, as from a LAWN MOWER carb change on car engine referenced, has nothing to do with 2005-2012 S1R9A9M9 and the 2 technicians in Georgia who successfully converted the Briggs lawnmower engine to run on water. (water vapor pressure + hydrogen gas from spark plug electrolysis) His 1978 Chevy V8 converted was on 18MPG water only before the water in gas tank was rebuilt as steel box collecting the Nitrogen embedded water exhaust for reuse. This then went to way higher gas mileage and smoothed out the engine running. The special, rare relays they used  can't be purchased as discontinued traffic signal lights electromagnetic switching type relay in pole boxes, so as a separate Electromagnet was hand built to be used with inductors and diodes for same effect. (On cars and lawnmower) The Dayton brand inductors 1.5 Millihenry at #18gauge magnet wire on plastic insulated bobbin can be purchased from Parts Express and must be used with fast recovery diodes capable of 6 amps such as FR607. I had an Email message back + forth, years back, from a man who had duplicated Nathren's set up with inductor and special wound S1R9A9M9 electromagnet. I had asked specific questions, but he only replied carefully as - "YOU WILL BE PLEASANTLY SURPRISED"
The auto and mower engines were said to start and run as is, at lower idle speed only. If power mode is desired, the main jet in carbs have to be redrilled out 33% larger hole to get more water to pass, and get more Hydrogen + water vapor pressure generated. The cars had adjustable distributor timing. The Briggs engines require electromagnet field and / or special curved, slotted, non-magnetic aluminum plate mounted for sliding  adjustable timing of Ignition Magnetron. (too much trouble to make just for 2 YouTube videos, summer 2008.
Many times in the web forum, it said 100 volts and 6-7 amps necessary. I thought it was a misprint. 5 times?? Maybe it was a reference to the 400W inverter box for 110v ac that was changed to half-wave DC. There was no explanation. However, we do know about back EMF and flyback voltage . The reverse polarity push and current from a wire inductor has to pass THROUGH a diode ANODE. I then looked up the actual circuit used on all those car engines in Georgia. There is an outside  parallel diode across the 2 inductors. I had originally also thought that the diode was added to sabotage any future duplication of engine circuit,  (paid informer) The main power would just go through the outside diode , passing by the inductors and center diode. However, that may probably be a SECOND PULSE forward. The high volts has to go in exactly at the cathode of the center diode between the inductors.
 Maybe we can get 100 volts going forward through spark plug from inductor? That requires extreme fast turn off pulse. Formula  E  =  L  X di /dt Volts-Henry-amps-second. The spark is fast and the trigger transistor inside magnetron is fast.
There were also several statements regarding The S1R9A9M9 triple coils assy that in operation with ignition, there is a leakage inductance voltage transfer from high volts side to low volts side of about 140 volts. Could this have been utilized? The high line side was bare copper #12 wire. The low V side over steel core electromagnet from 12v battery was #14 insulated hook up wire. There were also 2 fools who had grabbed a hold of their #14 wires and shocked themselves. A pre-designed in Superimposed higher volts over lower volts????
The full wattage is not drawn from the Inverter because the flywheel going around mower engine only fires spark-plug as aboiut 34 % duty cycle with electromagnet.
Something was going on back then. Nathren was hassled by thugs on the road with guns, harassed, and property oil tank had bullet holes, He had legal problems also, and was jailed for a time. Neighbors moved away, wife divorced him and address in Georgia  no good any more.  (water for fuel????)
« Last Edit: January 27, 2024, 04:35:34 am by russrHHO »
