Quote from: Login to see usernames on February 03, 2017, 18:57:01 pmWhere did it crack at ?What are your goals with the cell?It a tiny crack at the bottum, close by one seal and i didnt use enough liquid gasket on one electrode....Goals? I want to see, or measure effects of the radiation of emf waves and magneticfields.I will take gas samples and ignite them in front of cam etc etcAnd i have a small genset to operate.....If the gas is trully deuterium, i should not have any problem operating it.I had the genset running on HHO once. So i can compare.cheers
Quote from: Login to see usernames on February 03, 2017, 19:47:04 pmQuote from: Login to see usernames on February 03, 2017, 18:57:01 pmWhere did it crack at ?What are your goals with the cell?It a tiny crack at the bottum, close by one seal and i didnt use enough liquid gasket on one electrode....Goals? I want to see, or measure effects of the radiation of emf waves and magneticfields.I will take gas samples and ignite them in front of cam etc etcAnd i have a small genset to operate.....If the gas is trully deuterium, i should not have any problem operating it.I had the genset running on HHO once. So i can compare.cheersTen 4 on the genset .....how many HP is it? I'll get a similar engine
(I have trouble some times posting)https://en.wikipedia.org/wiki/PHpH is Hydrogen scale
Well, it seems that nobody joins in here, except for Kevin and Fabio...I repaired the cell for a second time, as it was still leaky.Hope that it is now fine.In the meanwhile i am playing with the electronics and High Voltage coils.Today i seen violet colored sparks.......I think those a key.The following days i will try again sparks, dc pulses, coils and what ever i come up with.cheers
