Author Topic: The power of water.  (Read 4697 times)
The power of water.
« on: January 09, 2016, 03:18:39 am »
The power of water is deadly and brutal, the explosion is so brutal its power is ungrasp to the century. Raise your pressure on your water tanks, this will raise the waters boilong point. Raise the pressure to 125 psi. Do not under estimate this system as it will kill you. If handled incorrectly. Do not worry about hydroxy production because it is not even used. At such high pressure it is impossible for the water to reach a boiling point on earth. Feed the superheated pressurized water to a injector that can handle high heat. Inject the pressurized superheated water into a aluminum cylinder if you dare. Once the synthetic reaches its aluminum chamber it will violently explode. If there is a leak in the system run! Run fast and prey! Do not look back. Do not use plastic containers, retrofit ceramic spacers to handle high heat. Use a cell to heat the water. Use your, or your friends mechanicle mind to inject the fuel when needed. Become a team, do not try to perfect this system alone, as it has already been done.  I am only a human with a spiratual direction. I was put here by my heavenly father God. Thank you Gabriel the sweet Angel. It is to my belief the Giant came from a empty place in the earth, he was told not to leave that place as he was under Gods instructions not to, but he was clever and did leave but he split hiself in half and he also stayed in the empty place. He was under instructions but became curiouse of his surroundings. He could deroot trees single handedly and he was told to stay away from the water, which he did not do. He is still at the empty place now, and he was also found dead on earth. I do not know why i post this, it is not facts, it is only my text on your computer screen. We are human now, but we are spirats later in our afterlifes and the road to heaven is narrow. Brian Coats 1/8/16
Re: The power of water.
« Reply #1 on: January 10, 2016, 22:06:11 pm »
Hi mr. Coats,
Still alive? Nice songs you make  ;)
Listen, you suggest to a common rail injection system from a diesel engine?
Use water in there and try to run it?
cheers
« Reply #2 on: January 12, 2016, 04:32:38 am »
Water is a fuel that only exist at a certain temperature several times greater than its boiling point and at a pressure greater than that of a cylinder engine but not because of the cylinder it is a fuel because its onlyba fuel under suchbabhigh pressure. Water will not act as a fuel under a low pressure. You can super heat water on xemand like stan did but the presure must be high. The higher the pressure and the hitter the water the more power it will produce when the pressure drops. A pressure drop and temperature change will cause the fuel to convert into a type of exposion.
« Reply #3 on: January 13, 2016, 16:37:19 pm »
Do you not understand water several hundred times greater in temperature than its boiling point is possible only because a higher pressure was applied. do you not understand what bringing this water at that form to an ambient pressure will do? the water can be stored at a temperature when there is no Sun hurry up china is waiting. coal not the answer when their windmills and solar cells are not working. The great time of trouble is now!
« Reply #4 on: January 13, 2016, 16:48:46 pm »
Stans sila was destroyed, man you people, why do you think stan had designed glass sunligh to heatvlenses for? Why do you think he kept melting the metel in that silo? Look no further, it is not the hydrogen you want from water, look here, it is the power that comes from the water contaminated or not. Set your fuel cells to the side for just a moment, what do you have to loose? Go heat a hot water heater at a high pressure then shoot it with a gun, then would you see? Go take the radiator cap of of your uncles old ford when its dangerously hot, then would u understand? The water wants to move! You all have been blinded by that cell stan used to heat the water. Go back and look at the boiler plate, dont be fools.
« Reply #5 on: January 13, 2016, 20:36:46 pm »
stan meyer isnt he only person with a Hydrogen cell , he wasnt the first and he wont be the last
what applies to stan Meyer also has to apply to Herman Anderson , Andre Puharich and Stephen Horvath
OR there needs to be convincing evidence to show that their technique was lacking in any way
According to science the Hydrogen atom is 1 proton and 1 electron , if this is true then this is what these 4 men were dealing with EQUALLY , on that fundamental basis it would be hard to exclude any one of these inventors (minimum 3 inventors)
a hot water cylinder sealed and then peirced is going to rupture under presure = this takes energy .
Ive seen first hand a hot water cylinder that has been closed and the water run out of it and the copper cylinder sucked into itself under vacuum and then sent to scrap metal
It wouldve been easy to take it to a petrol station to blow it up with air and reuse it but it wasnt my call , not my cylinder
« Reply #6 on: January 13, 2016, 22:42:15 pm »
Mr hydrocar
i had in italy two plate cell that i connected to a full wave bridge rectifier and straight to the wall 50hz 220v
what i see is 3 amps 220v evaporating more than 1 liter every 15 minutes.. some small gas also was being produced... 3 amps dc
to boil 1 liter of water you need over 2kw isn't it right?
« Reply #7 on: January 14, 2016, 16:59:17 pm »
you should have put a capacitor across the bridge of good value and then when the water reaches a certain temperature the amperage would drop to a minimum and you could lower the voltage and idle. it takes a tremendous amount of electricity to heat the water but after it is heated to a certain degree this electronic system it's an idol because the water keeps its heat it does not cost much to keep the water thermal it is just getting it to that point is when you pay this is what people fail to understand. to answer your question I provided a website the goes into detail but 1 BTU is equal to 3. 412 watts i think. it depends on the temperature your going to raise the water to and it also depends on what you're going to be doing with a water rather it just sitting there are you using a small amount at a time those formulas have to be calculated, which I do not look at formulas and I do not look at it scientifically. I look at what's happening the big picture is electricity goes in the water gets hot pressure is applied the water cannot exist at that temperature in an ambient pressure and it explodes. Stevie any injector that will open a good amount and its end will do the job since the behavior of the water does not like a ambient pressure. Stevie when the water is injected at that temperature and that pressure the piston moves down so there is a pressure drop immediately when the water is it a very high temperature. it is like the fuel was moved from the injector to the cylinder before the piston starts its way down, once the piston starts his way down the pressure drops rapidly then the water that was transferred from the injector to the cylinder explodes.
