Author Topic: Who is right discusion  (Read 20859 times)
Re: Who is right discusion
« Reply #32 on: January 08, 2016, 19:14:16 pm »
8XA IS NOT RESONANT CIRCUIT!
This was the first patents from Stanley Meyer before the resonant system.
Dont try to achieve resonance with this because you will get frustrated.
« Reply #33 on: January 08, 2016, 23:54:02 pm »
This shows the true difference from all of you and me as I learned something for I got resonance with the 8xa circuit but more than that I made sense of the words by way of experimentation using the scientific method which is something none of you ever try and make use of.
Like any tool it is only as good as the person making use of it and since it is clear to me that most if not all of you never bothered to even pick up the tool known as the scientific method you've been totally stuck in trying to figure out this technology. You all get mad at me for showing an understanding of this technology but never take the time to attempt to understand anything that I say. I can't even count just how many times I have pointed everyone in the right direction to only be told to go away as we don't want what it is you are showing us. I have spoken of the New Zealand video many times in the past and even took the time to post the video for you all to look over.
The 8xa circuit is of Meyer's early work and from there one can gain an understanding of this technology. Did you know that you can re-wire it to be just like a VIC transformer? Nope because you are too busy running your mouths and typing away on your keyboards to ever get to performing any real world experiments. Your all so afraid of failing that you never start doing anything. Or you are so strapped for cash that you can't afford to build anything. Either way if you don't get some experiments under your belt you will never learn anything. This is the primary reason why when I speak of how this technology actually works you have no idea what I am talking about for you have no practical experience with this technology as you are just working with theories in the mind.
The voltage intensifier circuit was the hardest part of this technology to figure out and I went through more than 20 transformers before I got the hang of it and was able to start seeing just what it is actually doing. I have a lot of experience in building these transformers now having made and tested all types of different cores. I made VIC's with I, C, E, and the donut cores, wired these things up all types of ways. But I took notes as using the scientific method requires the use of a laboratory note book. I learned by doing as sitting on one's behind doesn't give any real world experiences with this technology only hands on boots on the ground work does.
Example, in the photo I just posted of the 8xa circuit you will see the words, "Increased coil length equally increases applied voltage level/amp restriction since induction/capacitance increases proportionally." Did any of you give these words a try and observe the results? More than likely the answer is no, right? as you are too cheap to build more than one coil size and test it in a manor that would give you a chance to see what these words are talking about. So to all of you these are just words that have no real meaning but for me I learned the meaning behind the words as there was a lesson to be learn here. The 8xa circuit is an easy circuit to make but it's old Meyer tech and since it has no dollar value you can make right now you don't waste your time with it. I took the time to learn this technology from the ground up through the foot steps of Meyer as he learned this technology. Sure I had to spend some money on something I could never sell but the lessons that needed to be learned from this sure was worth it. I think I made and tested at least 10 different size choke coils and from this I learned. When I felt I was ready to move back to the voltage intensifier circuits I did so and made all the progress I have shown you in figuring out how to get the high voltage to the load and not have it be trapped at the secondary coil. So when you see me post waveform shots like this know it took a long time to figure out how to get the high voltage to the load.
(http://i1025.photobucket.com/albums/y320/h2opower/personalpics009_zpscf31888c.jpg)
As these results didn't come easy as it took a lot of hard work dealing with older Meyer technology to be able to get this far. But the Nay Sayers told you these results are a dime a dozen but I have yet to see a single person show results like this. Then I get the question, "where is the gas production?" and when I answer it to the best of my abilities to do so the answer I give is rejected. But now it seems common knowledge that you need 1kv or more per resonant cavity to get this technology up and running correctly, hum... I wonder where that came from?
I have come to the conclusion that what you all really want is for someone to help you start a business with this technology. I just observe all of the competition going on and came to this conclusion. You aren't wiling to work for it and some have even rejected it when it was freely given to them.
This year is going to prove interesting as I have a lot planned for this year and if all works as planned it will be a year to remember.
« Reply #34 on: January 09, 2016, 10:53:00 am »
Sorrry....not sorry to burst your bubble but these guys only beat you to it by 16 years.
http://www.wasserauto.de/html/stanley_meyer.html
« Reply #35 on: January 09, 2016, 18:45:07 pm »
And you would be yet another enemy of the technology to add to the list? Where to you people come from? What True Green Solutions is doing right now is trying to bring this technology to the people that need it most. The technology was not easy to gain enough understanding of to be able to duplicate it as you are well aware of. But since you like to go back 16 years let me see a single product that they have on the market for the people to buy. Just one company that is doing right by the people at trying to bring this technology to the market so that they can have access to it, can you show me one? I know of one but only one that is attempting to step up to the plate and build this technology for the many that simply can not build it for themselves even with a complete set up plans in their hands.
Who are these people that simply could not build this technology for themselves? Your mother, grandmother & grandfather, sisters, brothers, aunts and uncles, cousins, friends, and billions of people whom you don't know. How are they to be able to get access to this technology unless someone steps up to the plate and builds it for them in a manor that the technology is completely safe for use? The arrogance of you people is simply astounding at times along with your stupidity but I guess they come hand in hand. Why are you so adamant at preventing this technology from coming out? Just who's payroll are you on, the oil companies, the coal companies, you tell me? As one thing is clear and that is you are not willing to support True Green Solutions mission to bring this technology out to this world so that automatically puts you on the side of those that don't want this technology to see the light of day as there are only two sides from which to be on. True Green Solutions with it's mission of "Ushering in the science of freedom" has many enemies and you are just one more to add to the list as a true supporter of the current system of energy enslavement. You see there are only two sides from which to be on and by default you have sided on the side of the energy sellers but are too ignorant to know it. You wish for the company to fold or will do anything in your power to make the company go belly up which is exactly what the energy sellers need on their side which is a free non-paid worker for them to keep the status quo.
But you don't see this larger picture as you are not so bright in the mind as to be able to see things like this. As here you are talking crap to a business owner who's primary mission is to bring this technology out to the masses. A mission to provide to the people a quality product that is safe for use that will give them energy independence and you are dead set against the company and it's mission to the point of taking action to prevent the company from completing it's mission. So, again, just who's payroll are you actually on?
http://www.truegreensolutions.net/ Doing what it can to bring this technology to the people.
« Reply #36 on: January 09, 2016, 18:55:31 pm »
Dude i havent read that post yet but im not spoon feeding you the waveform they posted you claim to be the only one who has ever produced but its there...16 years ago.
As far as you trying to bring something to the market to help people that need it ???, All you are trying to do is help YOURSELF.... its all you buddy ... your attitude is piss poor broke and most of all NIEVE !!!Not the kind of person i can see desearves ANYTHING !!!
You are so far behind its not even funny and to come here and spew the ignorance you possess as if no one can see what you truely is ....for every greater than thou post you make i get even more disgusted with YOU.
In all fairness its help you seek in the end that even a tattoo on your forehead wont fix...you need to wake up and smack that dude in the mirror as hard as those pion hands can smack.
« Last Edit: January 09, 2016, 20:28:03 pm by KWS »
« Reply #37 on: January 09, 2016, 20:35:43 pm »
TGS because you got this waveform dont mean you achieved that.
« Reply #38 on: January 09, 2016, 22:34:58 pm »
This guy (TGS) Come here always with arrogance and disrespect to everyone here in the forum.
When we post some of our work he says "You come here more to get tap in the back" and maybe is what he is doing too!
People like him dont deserve any attention or respect because he dont respect others and their opinion.
« Reply #39 on: January 10, 2016, 00:09:21 am »
This post doesn't make any sense. Are you saying I posted a lie? All I did was share the results I am getting you all are the ones that took offense to it. I have plenty of eye witnesses of me putting a high voltage to the load at points D&E to include Moray King, Russ Gries, and a whole lot more. Sorry I didn't reach the ionization threshold back then but I still needed to figure a few things out in order to achieve the needed voltage to bring about the ionization of the atoms that make up the water molecules.
Just to be honest with you all that waveform has problems that I had to figure out and figure them out I did. Now it looks nice and smooth right from the start. Will I post such results? Not at a site that is totally hostile towards TGS attempting to bring the technology to the market place. Practically all of you here on this site are enemies to me and my company and could truly care less if the company swims or sinks. Most of you simply can't see the big picture as your minds are only about your own self interest. Take the KWS guy for example he makes post to show what exactly? From my standpoint I have no idea as he simply doesn't make any sense to me.
KWS makes a post as if there is a panel of judges out there that will determine who out there is worthy of this technology or not. To this individual it matters not all of the hard work I put into figuring out this technology as in his view I simply didn't earn it. Now when look up examples of people that do things by putting in the work required to get the job done they deserve it, but not to this enemy of the technology as he is stuck in La la land.
https://www.youtube.com/watch?v=2GSvHwVy4P4
But more importantly what does it matter when it comes to just who will attempt to bring this technology to the market place? Do you want the world to have this technology or not!? Like I said there are only two sides to be on one is on the side of those that sell us energy enslavement and the other is those that sell us stuff so we can gain our energy independence. Sorry it had to be me but know that I put it in the work required to figure this technology out and trust me I failed many times along the way. But I wasn't afraid to fail and kept spending my money to improve upon the results I was getting. Like Russ I too have quite a large bone yard of failures but that is what it takes to get this technology up and working and yes I earned it the hard way by putting in the work by way of trial and error making use of the scientific and engineering methods. As it truly is just as Meyer said, the inventor has to be a loner and somewhat thick skinned as no one is willing to help but all so ready to hinder ones efforts to bring about a technology such as this as not many of you will show support of any kind just as Meyer said you would be doing. The responses I have gotten on this and many other sites is total proof that Meyer's words were words of wisdom and truth. The examples of his words being true are all around me just take an honest look in the mirror and look at all of your actions towards someone doing his best to bring this technology to the market place with nothing but ill wishes of failure and saying that I don't deserve it as it shouldn't be a person like me when you have no idea what type of a person I am other than the fact that I am a black Hebrew Israelite. That bible quote Meyer used comes from a book of the history of my people, yeah that's right my people are direct bloodline descendants of Abraham, Issac, and Jacob and from where I stand many of you have a big problem with that.
