Author Topic: The VIC with resonant cavity project by Steve..  (Read 209284 times)
0 Members and 69 Guests are viewing this topic.
« Reply #240 on: February 29, 2016, 03:14:27 am »
what frequencies you are able to hit it Steve?
in my vics it resonates around 100khz depends on the core and wire lengh aparently
when i connect the secondary to ground it brings the potential of the cell up and down..
i was considering having two isolated cells with two separeted water sources
« Last Edit: February 29, 2016, 05:15:36 am by sebosfato »
« Reply #241 on: February 29, 2016, 15:48:04 pm »
will check for that tonight...
« Reply #242 on: March 01, 2016, 03:16:45 am »
its increadible how shiny the electrodes can get, realy its like mirrors now... i will take a picture... for you... it took me hours to get this point but i will still go further with a finer sandpaper
regarding that idea basically what i mean is that when we give a reference point to the circuit is possible to understand where things are going and be sure what is going on.
how your tests came out?
« Reply #243 on: March 14, 2016, 15:25:51 pm »
update:
After days and evenings, i started to cry very hard. I asked by email and PM people who clamed to have a working VIC , like GPSSONAR aka Ronny Walker, for help.
Not even a reply, which i think is very rude.
Now, i have removed my primary and secondairy coil and went for finding resonance of my 2 choke coils.
I found it! I created a perfect sinewave acros my cell at 30V and 10mA from my powersupply.
It created some gas.
Now call me stupid......If i modify my primary and secondairy in sucg a way that they are tuned for the same frequency, i can use for feeding my chokes. That way i should be able to feed them with higher volts.
Aming for at least 500V.....
Hope that works..
cheers
« Reply #244 on: March 14, 2016, 16:39:03 pm »
At least you are working and getting some progress wich is definately better than armchair warriors :) good for you !!!! Ill have an inductance meter tomorrow to continue on....have you ever measured i nductance of your cell ?
« Reply #245 on: March 14, 2016, 23:52:19 pm »
On special demand:
my cell has dem.water in there during measurement
1 tubeset inductance 0.38mH on the 20mH setting, 0.288 on the 2mH setting
4 tubesets in parallel is inductance 0.11mH at 20mH setting and 0.84mH at 2mH setting
So, these numbers are strange to me, KS.....
What does they say to you?
« Reply #246 on: March 15, 2016, 00:33:46 am »
Steve, Capacitors have no inductance. Only capacitance (nf, uF, pF, etc).
Only coils have inductance (and capacitance too).
The tubes on water can be very difficult to measure.
« Reply #247 on: March 15, 2016, 05:46:12 am »
Thanks Steve, i was currious how large an inductance ut would measure...im currious if its alltho measuring capacitance as well if it actually performs as a capacitor in the circuit...Stans bro said more like a transistor.Im hoping to learn those things as well....amplitude modulation is something else im trying to learn and master:)There is an analyzer meter for capacitors to tell if they "pass" as an actual compent as well.
