Author Topic: Different kind of VIC Circuit  (Read 34858 times)
« on: June 08, 2011, 02:29:55 am »
Wanted to share this new VIC Idea with you all.  Working on building.
Re: Different kind of VIC Circuit
« Reply #1 on: June 08, 2011, 09:24:09 am »
I like the idea!
Looking forward to read some details of your tests.
« Reply #2 on: June 08, 2011, 23:38:51 pm »
Planning on just 2 chokes, or split secondary on the first attempts.   I will call the secondary as choke A and choke B for reference.
Each Segment consists of 80 turns of 24 awg wire.  4 segments per choke coil.
Choke A: 320 turns total, inductance 44.5 mH
Choke B: 320 turns total, inductance 46.4 mH
Give or take some for the cheap meter I use.
I am planning on using a 1600 v 0.1 uF  capacitor on the secondary side.
Blocking diodes are 600 volt, 15 amp rating.
(Edit: Voltage rating should be plenty as the water will conduct with anything above 1.2 volts)
( In theory the only voltage reading at the cell is the voltage drop of the water itself, the rest is recycled)
Target AC frequency is 1668 hz.
Anything off this frequency will result in XL killing the voltage, very low Q, and or, loss of efficiency in cycling.
I may cut the secondary capacitor in half to target a higher frequency of 2359 hz.
I still need to complete the primary winding (tune to primary cap for above freq. aka tank circuit)  and complete the tube in tube cell - lots of machining on this still.
warj1990
« Reply #3 on: June 11, 2011, 23:53:14 pm »
Not really any testing or updates as of yet.  Just wanted to bring some photos of the last few days here.
I am not going to try and match resonance between the primary and secondary tanks yet.  My meter keeps bouncing around with the L figures.
I did find out a DRSSTC  (dual resonant solid state tesla coil) has the same type of pulse train Meyer used - worth a trip to google if you are interested.
Primary ended up being 20 turns on each half.  Secondary 80 x 8 = 640 turns.  / 20 primary = 32:1 step up X former.
Min. voltage to operate is 15 volts input.
Primary in resonance drives the voltage up by PIE.  Input min now 15 * PIE = 47.12 volts  * 32 (step up) = 1508 volts on secondary cap.
Allow for 20 percent losses = about 1200 volts on the secondary cap ends.
« Reply #4 on: June 11, 2011, 23:59:00 pm »
Sorry guys,
I am now the winner of the largest picture contest.  I will resize any further photos.
« Reply #5 on: June 12, 2011, 00:15:35 am »
Looking great! :)
« Reply #6 on: June 12, 2011, 03:55:44 am »
Well I have some test results, not looking good.
Production remained "a bubble here and there"  nothing great.
I replaced the secondary cap with 2 nf  to generate high voltage on across the secondary.
I "shorted out" one of the cells, disconnected from the tubes and tied the wires together.  Thinking there was cross conduction in the cell.
Total input was 2 amps (I think around 60 volts - did not check that).
I have some photos I will attempt to explain in order:
1:  Bubble production very poor.  Look at the right tube only one connected.
2: Frequency of circuit: 38.16 khz
3: 2 meters shown:  Left voltage at secondary capacitor, Right voltage at primary tank capacitor.
4: 2 meters shown:  Left max voltage of meter secondary capacitor, Right voltage at primary tank capacitor.
5: 2 meters shown: Left input current for driver, Right Voltage at primary tank capacitor (note same as photo 4)
I also measured the voltage at the cell terminals, 2 volts DC.  With salt added 0.8 volts DC.
Production was slightly higher with salt added, again not much for the power going into the system.
I am open to any ideas at this point - planning on a smaller secondary winding ratio and looking over Meyers info again.
« Reply #7 on: June 12, 2011, 04:15:49 am »
I wanted to add, my limits on the driver circuit are as follows:
 200 volts across the capacitor, due to Gate  Drain junction on Mosfets.
 4 amps total input into the driver, bridge rectifier limit.
I noticed with 2 amps the circuit is getting hot after a moments run.  So the run times were short.
I had another idea.  The primary has 40 turns and a tank cap of 0.1uf  I can put 40 turns on the secondary and a 0.1 uf cap.
This will resonate the primary and secondary - since conduction started in the cell at 2 volts and my driving voltage is well above that.
Stay tuned...
« Last Edit: June 12, 2011, 13:24:05 pm by warj1990 »
