Stanley Meyer > Stan Meyers demo cell system
ALTERNATOR
sebosfato:
We are the peace!
I just really solved the problem behind meyer principle. In the end is the same principle on all the devices related. Be open minded to understand what is being said.
I understood why meyer used 9 transformers and 9 pairs of tubes and how he used them...
I understood also how to use the electron extraction circuit and why it is the base of the working principle.
For you to understand well keep in mind the following translation for Meyer's words.
Electron extraction circuit = short circuit = discharge electrons from oh- ions into h+ ions, allowing the ions to be discharged generating than h2 and o2 molecules. This discharge must be made wisely to not loose the energy applied on the polarization process. It thus must be discharged into a capacitor
sebosfato:
Keeping the series of this mind blowing information:
The electrical polarization process = Charge up the water dielectric to create coulomb force witch will make each ion to go toward it's attracting electrode.
Steve do you remember what you called back emf of water after a pulse?
Is the ions electricity!!!!!!!
So you need to discharge the electrodes with reversed polarity into a capacitor!
Meyer was doing exactly what i was going to do with the theory that i got. But he instead of using permanent magnets and a pump to separate the charge, he used the vic coils.. Meyer also used the cells in series for the discharge so he could use rectifiers 10 times less rated in amperage than i would need with my design. However because of this the gas will need to be generated together witch is the price to pay...
I'm really exited, i feel like beavis and butthead when beavis eat a lot of sugar and coffee. hahahaha
Hope you are understanding what i'm saying....
Dankie:
Ok Sebos ...
Just dont ask us to send you another 100$ for cigarettes Sebos ...
sebosfato:
HAHAHAHAHAHA
100$ would be very nice =) Actually if you could send me a nice igbt module maybe 300 amps 1200 volts would be nice too =)
I already have a toroidal vic and i just need to get the 18 tubes and solder it...
I will make a drawing for you:
sebosfato:
i will try to do the test tomorrow. i will work all the night to put the circuit to work and so i will check if it will work.. I just don't have oscilloscope so is bit difficult but i will do it.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
