Author Topic: Circuits I've built based on Stan's 8XA patent  (Read 7816 times)
« on: July 01, 2010, 01:22:05 am »
(http://www.globalkast.com/images/tonywoodside/Digital_PWM-7.jpg)
This is the Pulsing Circuit fully adjustable from 1Hz - 10kHz. The duty cycle from the 555 chip is 95% and is then inverted by the 7404 to 5% duty cycle. All pulses from 7490 chips are 50% duty cycle.
(http://www.globalkast.com/images/tonywoodside/+5v_+12v_PowerSupply-5.jpg)
This is the Power Supply that provides +5v and +12v to the pulsing circuit. I have this power supply limited to 1A. I'm only using the +5v.
Re: Circuits I've built based on Stan's 8XA patent
« Reply #1 on: July 04, 2010, 21:36:25 pm »
The only problem is, the circuits do not show up in your posting as both of them never appear when the page with your post loads.
Regards,
mina
« Reply #2 on: July 04, 2010, 21:50:36 pm »
It looks like that the website on which the pics are placed is not available.....
« Reply #3 on: July 05, 2010, 00:50:31 am »
Ok I have them back up and going now, my server was down. Thanks for letting me know guys.
-Tony Woodside-
« Reply #4 on: December 03, 2010, 12:20:54 pm »
hey tony,
i cannot find the 8XA circuit online! are you able to post it?
that circuit might exist in a scarce version of MEMO 420 (might be called MEMO 420 DA) that is called 'RE: Electrical Polarization Process' which i cannot find also (the well known 420 is about the 'fracturing process')... so thanks in advance for posting...
Charlie.
« Last Edit: December 05, 2010, 03:23:29 am by charlieb000 »
« Reply #5 on: December 06, 2010, 09:11:04 am »
you can find the circuit with components here http://www.ionizationx.com/index.php/topic,844.msg13442.html#msg13442
« Reply #6 on: December 06, 2010, 09:36:19 am »
« Reply #7 on: November 30, 2012, 00:21:18 am »
the dutty cycle is 5% from the 555 because it has 110kohm(100k pot+two 4.7k resistors) resistance between pin 7 and vcc
