Electrolysis > HV and hydroxy
New theory about Stanley High voltage Water dissociation
<< < (3/3)
sebosfato:
I'm still thinking about this vibration transformer and i just found a good way for doing it..
A plexiglass tube (maybe 3 cm diameter 10 cm long) with a coil outside, in the inside a cylindrical or ball permanent magnet (some oil could be added to reduce friction and also this tube could be under vacuum to reduce air drag too) and at the top and bottom fixed springs or permanent magnets with reverse polarity to the face of the in magnet...
The coil should have a very big inductance in my opinion as to have a frequency not too high to allow big vibration. However this inductor should have a big Q factor. Than a capacitor hand rolled should be added in parallel. All this could be driven with a vic coil...
The load could be implemented in parallel to the circuit or in series However in my imagination in parallel would be better and using an igbt with a control circuit witch would allow to conduct fpr some ms when the tank is full to not totally discharge the tank during operation...
There is a need to design it well to know the weight for calculating the spring constants of the magnets to find the frequency witch they will vibrate.
This way is possible to roll the capacitor for the right R frequency.
Amps should be kept small i think and voltage big...
The spring constant will depend on the weight and is similar to the resonant frequency calculation of a tank circuit = 1/( 2PIsqrt(mass/K))
The tank should operate at 2kv maybe 10 or 20 amps... (recirculating)
The input power should be around 2kv 100ma or less
Maybe a spark gap will be needed too for limiting the voltage
(it seems to me in my mind like donald L smith devices...) don't know why
Regards
sebosfato:
Aways good to remember, if you try to do this to be extremely careful. if you touch the inductor terminations during operation you could really burn 2kv 20 amps are = to 40kwatts discharge into you. You will die if touch. so please too much careful!!!!!!
sebosfato:
I've researching about the mechanical resonance involved in this project i'm proposing and I found to be amazingly complicated to achieve and maintain the mechanical oscillation. 1° because will depend on the weight of the internal magnet and the forces of the other two related magnets and also will depend on the power applied. So a mean for controlling the voltage applied will be needed.
I though this,
Construct the tube with the magnets than discover its mechanical resonant frequency, than construct a well designed coil that coincides in electrical resonance with the resonant capacitor but also its magnetic field strength for the desired power operation, to allow the magnets to resonate...
I don't know if you understand my point...
something like this:
Dankie:
Quote from Puharich patent
he Anatomy of the Barrier  Effect     Region A: Shows active and  efficient  hydrolysis
Region B: The barrier region  effect  can be initiated with taps of the finger, or it can spontaneously occur  as a function of time.
Phase a: The current rose from  1  mA to 30 mA. The voltage fell from 22 volts to 2.5 V.
Phase b: If component II is  tapped  mechanically during Phase a supra --- it can be reversed as follows:  The  current dropped from 30 Ma to 10 Ma. The voltage shot up from 5 volts  to  over 250 volts (off scale).
Throughout Phase a and Phase b,  all  hydrolysis has ceased. It was observed under the microscope that the  inner  surface of the outer electrode was thickly covered with hydrogen gas  bubbles.  It was reasoned that the hydrogen gas bubbles had become trapped in the  electrostricted layer, because the water molecule tetrahedrons had  flipped  so that the S+ hydrogen apices had entered the Helmholtz layer and were  absorbed to the electronegative charge of the electrode. This left the  S- lone pair apices facing the electrostricted layer. This process  bound  the newly forming H.sup.+ ions which blocked the reaction
H+  + H+   + 2e ==> H2 (gas)
STAGE F
Region C: It was found that the  barrier  effect could be unblocked by some relatively simple procedures:
(a) Reversing the output  electrodes  from Component I to Component II, and/or:
(b) Mechanically tapping the  Component  III cell at a frequency T/2 = 1.5 seconds per tap.
These effects are shown in FIG.  12  and induce the drop in barrier potential from
(http://www.rexresearch.com/puharich/3eq4.jpg)
Upon unblocking of the barrier  effect,  electrolysis of water resumed with renewed bubble formation of hydrogen  gas.
The barrier potential problem  has  been solved for practical application by lowering the high dielectric  constant  of pure water, by adding salts (NaCl, KOH, etc.) to the pure water  thereby  increasing its conductivity characteristics. For optimum efficiency the  salt concentration need not exceed that of sea water (0.9% salinity) in  Section 3, "Thermodynamics of the Invention", it is to be understood  that  all water solutions described are not "pure" water as in Section B, but  refer only to salinized water.
Cool video
http://www.youtube.com/watch?v=g3BmVFs3-jo&feature=related
sebosfato:
Hi dankie
thanks for the contribution is of very good value =) thanks really!
This absorption he talks about i believe is the same the palladium have with hydrogen. Switch off covalent bound by catalytic modification in the molecular shape... But only the right material can absorb the right amount. Palladium is 5 times better than barium and manganese oxide read somewhere.
Regards
Navigation
[0] Message Index
[*] Previous page
Go to full version
