Author Topic: Generation of electricity by usage of moving magnetic fields  (Read 32384 times)
« on: January 29, 2010, 23:04:28 pm »
I suggest to change this topic name to Generation of electricity by usage of moving magnetic fields.
I'm going to post something that you all have overlooked. Its a patent called Energy conversion system and Stanley meyer cited this on his patent called Gas electrical hydrogen generator. It basically shows and clearly explain how stan run his buggy.
Ok i'm saying this just to make you read it!!!
It explain well how the epg principle works!
So now you have an energy source.
Just need to figure out constructing the device and testing.
Steve check it out is only pressure that can do this.
Regards
Sebosfacts
« Last Edit: January 30, 2010, 00:16:54 am by Steve »
Re: Generation of electricity by usage of moving magnetic fields
« Reply #1 on: January 29, 2010, 23:24:51 pm »
Regards
Sebosfacts
Very very nice!
« Last Edit: January 30, 2010, 00:17:20 am by Steve »
« Reply #2 on: January 30, 2010, 03:00:56 am »
seb,
are u suggesting the method which stan uses positive charges gasses (electron deficient) to draw current of electrons to gasses from earth ground?? i know stan explains this method in one of his videos..
« Reply #3 on: January 30, 2010, 03:32:02 am »
The ionized gas have to do with it the rest no its not related to this
He uses the pressure developed from the cell to generate electricity (or doing work)
He magnetizes the gas and harvest energy from the movement of the continuos expanding gas. (basic principle of dc generation) Generating electrical energy that is used in closed loop (resonance) with the cell, generating more gas and consequentially generating more electricity and so on.
The multiplication factor will depends on how efficient will be the generation of electricity from the expansion. If you can have 80% efficiency you will have a over unity factor of 5. if you have 99% efficiency you will have over unity 99.
To calculate this you need to remember the Q factor calculation in electrical resonance.
Lets take the first example
if you input 1000 watts  you have
80%= 800 watts that will generate more  gas than
80% from 800= 640 that will generate more gas
and so on...
Than you have 1000+800+640+...= 5000watts output in h2 02
in the second example
99% = 990 watts that will generate more  gas than
99% from 990= 980 that will generate more gas
and so on.
Than you have 1000+990+980+...= 99.000 watts  output in h2 02
« Last Edit: January 30, 2010, 04:32:05 am by sebosfato »
« Reply #4 on: January 30, 2010, 04:02:14 am »
can u post the sited document u speak of so i can read it?   i understand that there are some perspectives to  overunity that deals with linking the expansion of the gas to drive the generation of electric power... one must make the vic work to make the magnetic gas.. if u are saying stan uses the fuel gasses as the magnetic field can u post some documentation explain this.. that perspective i have not come across if thats what your refering to i would like some reference..
little off topic.. stan says that the vic is used to encourage particle oscillation.. particle oscillation means that they themselves are oscillating and i see it as the orbital electrons being the oscillating particle while the denser proton matter is also being effect but are more or less just being stablized during the lighter more mobile electrons oscillation... in order to make a electron move in a orbit this means you not only have to encourage it to go towards the positive but u must also encourage it to go the opposite direction of the positive plate toward the negative... this doesnt mean the negative needs to become positive to pull the oscillating electrons back toward the negative.. it just need to drop in potential back toward the positive direction (0v)... water it self will want to naturally balance and will encourage its own movement in that direction as the neggative pressure drops back toward 0.. and the postive having a fall time as well  will weaking its attration force that is pulling on the electron... at the same time the positive choke being isolated from the return of electrons from the secondary can step up each oscillation as it does so the negatives potential in the negative choke due to the bifilar mutiual magnetic attraction will gain and appear as 0..  so lets say it oscillates up to 1000 volts.. then u stop pulsing  you then have a high positive plate that isnt oscillating to rip electrons  its ionizing them without the need of oscillation until electrons make it back into the positive choke.. like a leaky cap..
« Reply #6 on: January 30, 2010, 05:53:31 am »
nice find seb.. i now see what you are speaking of... so do u think that stan uses the non combustables as his neutral gas? i need to wrap my mind around this more.. thanks for sharing
« Reply #7 on: January 30, 2010, 07:14:05 am »
I don't know if the nitrogen is involved that much, in this principle. Nitrogen is important only as flame retardant to reduce the combustion speed second my thoughts.
I believe that he had constant pressure from his cell so he just mixed the gas switching with a butterfly valve between air and exhaust to control acceleration. Air for maximum acceleration and exhaust for idling. Obviously he might have limited also the resonant action to a certain degree in somehow as to have a increase in gas production in relation to rpm. I'm still working on that to find some more answers.
I'm happy that you enjoyed!
Stevie I was reading this http://en.wikipedia.org/wiki/Magnetic_field and found that charged particles have a magnetic field. Ions... Ionized gas...
Probably we need to ionize the gas before it pass thru the tube. Or maybe only the magnets will do the job. I'm happy to say that I don't know yet.
Lets find out!
