Author Topic: Start here your topics on the water injector & ambient airgasprocessor system  (Read 47468 times)
The main problem is create perfect contact from inner electrode with dielectric.. I have solved that after few tests using an "liquid electrode", inside quartz tube I have put electrolyte solution formed from distilled water and koh. Inside tube centrally an SS316L electrode for HV energy propagation.. see diagram attached.. with this last information all of you are able to create an working cell for produce brown gas. About micronic gas.. Im sorry but for that system I can't sent you additional informations.. I hope you understand.. Regards Alessandro
Hi Tut
Thanks for your cooperation!
What is the thickness of the quartz tube you are using ?
thickness of quartz tube is 1,6-2mm
From 1 november 2011 I'm able to sent you all materials (including plan) for build that cell at popular price, in that way you save more time for find these on internet. Complete plan for Electron Cascade Cell is also available for personal usage at 50 euro with payment trough paypal. If you are interested sent me email to alnenc@libero.it. Regards Alessandro
P.S. Also Iontruster can buy these.. no problems
« Last Edit: October 19, 2011, 09:18:29 am by tutanka »
FOR COMPANIES ..
Plans for commercial usage are selled to different price with license.
Guys,
I've seen some noticeable increase in gas production by using a negative titanium outer tube with a stainless lead wire pressed against it.  The inner positive epoxy filled tube is stainless 304.  I think that the titanium makes a strong oxide coating that increases over time and builds an oxide layer that acts as a dielectric barrier.
The water stays crystal clear in this arrangement, however, when I switch polarity the iron flows out of the stainless and clouds the water quickly with red oxide.
This may be a way to build a dielectric barrier in a natural way and it works well enough for me to pursue this more.
kb
If you use pure quartz tube and SS316L as perforated tube and outer tube you don't have problems. Water remain clear during the process. Work of outer tube is simple, only attraction/repulsion of free electrons for increase speed of these.
http://www.youtube.com/watch?v=CRxaHMDSIBI
Brown gas =water capacitor gas
