Author Topic: Start here your topics on the water injector & ambient airgasprocessor system  (Read 47495 times)
The Alex Petty design in fact is the same of Meyer..
The WFC is an DBD reactor how INNER tube is coated (dielectric) outer tube not.
The circuit connection is OPEN and diode have function of half rectifier only.
Puharich use only RF , Meyer use voltage with heterodyne (two different pulsed frequencies inside cell).
Nothing is magic but all have an sense. You have to understand that ONLY water is grounded not INNER ELECTRODE. WFC is an open cell because electrons stripped have important function inside.
If you change an little design and material of WFC you increase a lot gas production using electron cascade process. Patrick Flanagan is an better example, him charge an "dielectric from two plates, all is covered from dielectric".   In fact "covered dielectric" is our water and is the ground at the same time. Jean Naudin have covered inner electrode using an dielectric .. Extracted from Naudin web site:
"The center electrode of the WFC v1.0 has been covered with a thin adhesive plastic sheet so has to get a fully insulated cathod"
Naudin circuit isn't good because cathode is connected to ground and in that way dielectric absorption don't work!!
INNER ELECTRODE MUST BE AC!!
Hi Tut,
Thank you for your patience and your explanations. I really do.
Still i dont have the full picture, i think.
So, i made a drawing...Please your comments on it.
more links:
http://en.wikipedia.org/wiki/Dielectric_barrier_discharge
HI Steve,
Connections are wrong. You can use one (same diagram of Alex) or two different HV power supply, on flyback with diode, one flyback without diode  and only one common ground connected inside water. Important is that INNER ELECTRODE must be powered with AC variable HV source
« Last Edit: October 17, 2011, 00:39:27 am by tutanka »
STEP-UP TRANSFORMER..
NOW YOU UNDERSTAND?
NOW YOU UNDERSTAND?
Thanks, Tut.
Now i understand. ;) ;) ;)
Thanks Tutanka,
What do you suggest as to earthing the waterbath. Can we use a mesh tube in between the electrodes like shown in the pic attached?
And what material do you suggest as for insulating the center electode?
HM
Hello,
Not waterbath but only water.. Mesh tube can be an interested solution but is suggested from?? as dielectric you can use ceramic, glass, plexiglass, etc..
HI HydrogenMask,
If you want use mesh tube you need to change an little internal design of WFC or you obtain some discharges from positive to mesh tube (grounded). Regards Alessandro
Do you think that earthing the water inlet of the cell (i.e. the water entering the cell) does the job ? the less complicated is better ;D
HM
