Author Topic: sebosfato projects  (Read 20979 times)
sebosfato projects
« on: October 14, 2009, 19:58:37 pm »
Hi Sebosfato,
Here is your own projectsection. Here you have moderator rights and that way you can create, remove, move posts and topics.
Here you are in control of all written messages.
Re: sebosfato projects
« Reply #1 on: October 15, 2009, 00:44:34 am »
Hello guys, Thank you for this space and i hope to help you understand what was really stanley meyer doing.
1° of all however you may think what i'm talking about doesn't relate to stanley meyer technology the reason of this is that Stanley didn't leave to us precise information on how the thing really works. He created a some concepts to confuse everyone.
I'm going to point the real good clues he left.
1n1198 diode
This is a high amperage diode. Was non sense to have a transformer where you have 40kv 1ma using this diode so it may be used for different thing that was my 1° thought.
40kv 1ma
40 watts
This gives to us very important information that is the load have 40Mohms of impedance.
10khz at this frequency the values for inductance and impedance are very practical values.
Voltage intensifier circuit Very similar to Resonant tank circuit Which also at the resonant frequency become a very high impedance because of the reactances of the capacitor and inductor and minimize to a minimum input amperage and maximize voltage.
A resonant tank is what is it called like. Is like a AC battery At the resonant frequency the inputed current flows from the inductor to the capacitor and vice versa and for every cycle it becomes bigger until it reach the limit of power the transformer can input.
It Recirculates many Kwatts of power. For example you can have 1amp recirculating for say and depending on the inductance to capacitance ratio you have more voltage per amp recirculating. For example if you maintain the capacitor the same and change inductance to a bigger value you will have more voltage to amp current. And here it is the amp restriction meyer was talking about.
The input transformer Or Vic :
This is a transformer designed to drive your tank. For example if you want to drive a 40Mohm load or our resonant tank. You need to have the impedance transformation of the transformer to match load as to have maximum power transfer. Hopefully i already designed a sheet of calculations on exel that give al the values you need very easy to understand.
Just choose Inductance, Capacitance, Input voltage from the battery,series resistance of the components in the tank. And you just observe the values.
I also designed a pll circuit that is quite replicable and you can see clearly.
Ocean water, river water, tap water, snow water, however he stated that any water can work.
Thats why i think he used the water in series with the tank because is impossible to have a high Q tank with the water in parallel. So it is in series.  The switching diodes (here is high current diodes used) allow the current to flow only in one direction so i use two and two cells that are connected in antiparallel configuration between an inductor and a capacitor connected in parallel. Just as simple as this is impossible.
Stanley talked about solderable coating on the wire. This mean that he was making Litz wire for his resonant inductor.
All his calculations showed on his memo are on the exel sheet.
I already have simulated this theory in a software called multisim and the values of the calculations are right everything also confirmed in practical tests.  So it works.
Now i'm getting better components litz wire high Q toroids and constructing a big cell for start measuring the production.
I discovered that hot water would work a little better because the voltage needed for electrolysis goes down for a bit and i something makes think that pressure will influence in it too. So in the electrolysis process you can absorb energy from the environment.
Oh i forgot to say the water don't get hot during this electrolysis so the heat must be provided by the motor, sun or the like.
If you think about stan used a water heater too.
end of 1° post start of a new way of thinking.
« Reply #2 on: October 15, 2009, 06:59:55 am »
You can believe whatever you want thats your choice. However i'm asking for donation and that is not a scam i just need money to finish my research i lost my job and just can't stop now as you see i'm too close. I released an information that you and all the others even working for years with this technology always had under your nose and never checked it or never could understand it. However how much did you spent on your research? I already spent in the last almost 4 years about 15.000 euros on material not counting house rent food and bills because i passed almost all my time in this years working on this. So do you really think is insulting? I think that is just a possibility to have a kind of help to make me finish before i normally could with only my situation of money now. So good that you remembered me this. If any of you are interested in help in any way you can do a donation or buy from me pll units constructed by me. Or transformer, resonant inductors ... just to help my project. I know all of you have spent a lot of money and you know as i that 90% of that was completely useless, stainless steel wire and the like 300$... tomorrow i'm going to spent 200 euro only for an inductor and some wire to further tests... You see, why money is needed? do you understand now?
I think might not be a problem to put also here a link for the donations for those who can and want to help me: https://www.paypal.com/cgi-bin/webscr?cmd=_donations&business=ERQSHHBGWC5P2&lc=GB&item_name=Bring%20power%20to%20the%20people&currency_code=EUR&bn=PP%2dDonationsBF%3abtn_donateCC_LG_global%2egif%3aNonHosted
and i will leave here the link of the thread on energetic forum for those who want now to know everything i'm talking about before i can write it all again here. http://www.energeticforum.com/renewable-energy/4617-stanley-meyer-true.html Take the time to read everything and please don't tell me without understanding that what i'm talking about is wrong or non related to meyers technology or high voltage no amps and the like because this is a signal that you have not read what i wrote, on the other thread i had this problem even on the 1° page.
Of course i'm releasing more information here too. But is important for you if you want to understand you might read read and read i took many time to understand and i'm giving it to you already very digestible information but at least you must read as many times as you can. Like how i did all over my research to reach this point.
« Reply #3 on: October 19, 2009, 02:18:48 am »
Got to say... made more tests yesterday and not good results with the new toroidal core i tried. I'm going to try other core materials and types to see witch one is better. The best effect i had until now was using 10 ferrite rod pieces 1 cm diameter together with a kind of litz wire i made with ,8mm wire about 10 strands. Ferrite heat up a lot and about 450 volts at 20 amps obtained using only about 80W. So i'm going to make a big one with 10 entire rods and see if its better than anything i did before. If any of you know anything about please any input would be nice.
Hi steve, thanks for the advice but i'm going to leave these posts there for now... if i think is too confuse i'll clean it.
I'm going to make a video this days to show it to you. i'm waiting to reach a better effect than i already had have on previous experiments, to make it.
« Reply #4 on: October 19, 2009, 10:51:11 am »
Donald the only thing is that you have a power factor of almost zero because voltage and current are out of phase. That is called the recirculating power.
« Reply #5 on: October 19, 2009, 12:25:44 pm »
Hello warp i believe that this tank circuit is very interesting because it can develop very high power recirculating or many energy recirculating and perhaps energy can attracts energy in somehow or can have the intelligence of multiplying it self in a certain condition.
We know that inside the water and air we have many bounds being created and changing all the time to do this they need energy and release energy, nature sun whatever provides the energy needed. I think over unity way is to create a very high recirculating power density with elements witch interact with the air or water that is able to absorb energy and direct it to a desired load showing a gain in work done. In the case of the electrolysis we have a limit witch equal 100% energy input = 100% energy output so if we can do it 1000 times better we have over unity right.
« Reply #6 on: October 19, 2009, 12:26:17 pm »
Well even if they are out of  phase , if you had a battery it would still be drained by this , even tho dissipated heat would be low . But If those VA are producing huge amounts of gas than that is still better than a rotary pulsing that wastes 2000 watts to excite 10 watts of gas .
« Last Edit: October 19, 2009, 13:04:33 pm by Dankie »
« Reply #7 on: October 20, 2009, 02:39:48 am »
with the same power.
Like stan said 40kv 1ma = 40w but
4000 amps at 10mv = 40W too.
Allow voltage to take over in a dead short condition.
40kv 1ma, Large electric Fields small electromagnetic fields. Small amount if any heat due to current, *~*~*~*~*~*~*~
4000 10mv,Small Electric fields, Large Electromagnetic Fields. Large amounts of HEAT due to current, Larger gas
1. Wiresize requirements Small.
2. Wiresize requirements Big.
Keep This for an extra Bullet.
