Author Topic: Geet project of Steve  (Read 64845 times)
« on: August 05, 2009, 20:18:27 pm »
As you have seen, i made a new section on the forum for the Geet technology.
Here is my voyage on that. Here are the first pictures.
They are of my new power generator. It seems to have the good old honda engine as you see on all those cheap gen.sets....
I am very positive surprised how smooth this engine runs.
It also consumes not much petrol too.
Its a 2.2kW generator max.
Single phase 230v.
GOALS of Geet project
« Reply #1 on: August 05, 2009, 21:02:48 pm »
My projectgoals are:
1. MAKE A WORKING GEET THAT SAVES AT LEAST 50% PETROL.
2. MAKE A WORKING GEET RUNNING ON 5 TILL 10% USED OIL AND WATER
3. MAKE A WORKING GEET RUNNING ON HYDROGEN / OXYGEN FROM MY WFC
4. PROVE THE MAGNETIC FIELD AND SEE IF IT IS A PULSING FIELD
5. CREATE ELECTRICITY FROM THE GEET REACTOR
6. MAKE A WORKING CLOSED LOOP FROM EXHAUST TO INTAKE (PETROL OR HHO)
7. MAKE A SELFSUSTAINING SETUP WITH WHATEVER MEANS OR FUEL. (PROB.WATER AND HHO)
    (and leave some extra energy for example lightbulbs)
8. PROVE THAT IT MAKES SINGLE ATOMS OR IONS OF THE GASSES. IN CASE OF HHO, IT SHOULD BE H + H + O
If any of you have suggestions, please let me know...
« Last Edit: August 05, 2009, 21:43:59 pm by Steve »
Re: Geet project of Steve
« Reply #2 on: August 05, 2009, 21:25:16 pm »
Where to start?
Well, i think i need to start with the schematic given by Paul Pantone himself or the Naresh plans.
I also gonna use the magnetic schematic and rod details of Naresh.
Keys for succes:
1. Use the right metals/materials, like Steel or soft iron. The key is to get a magnetic field.
1a. The inner side of the tubes MUST be seamless. They must be smooth like a baby skin.Like the rod.
2. Magnetic poles must be set right from the tubes and rod. All tubes/rods we buy already have a north and south pole.
3. The vacuum must be right. No leaking there allowed.
4. Right size and shape of rod / reactor  vs choice of fuel. Rods function= venturi
4a. Rodsize for Hydrogen propane etc: like 1 till 2 inches long.
4b. Reaction chamber lenght: 0.5 inch till 1 inch longer then the length of the rod.
5. Cold fuel in stead of warm fuel
6. Hot reactor tube. Insulation to keep heat inside.
7. Keep the rod dry. No wet fuel.Just dry vapour.
« Last Edit: August 09, 2009, 23:32:00 pm by Steve »
« Reply #3 on: August 06, 2009, 07:05:33 am »
I say it will not work. Plenty of time to Prove me wrong.. Meanwhile.. Hoax.
Perhaps this will motivate you to hurry and get it working, I sure hope so, because i want the results as bad as you...
; ' ; One Google of
Paul Pantone Will Pop up the fact it is a Hoax. It is labeled a Hoax all over the internet which is why i say, It probably is. However, This could be the way Technology is controlled. WHICH, is why I also want your results, I'm curiose Who the LIAR here is...
Paul Pantone, Or The Internet...
« Reply #4 on: August 06, 2009, 07:07:47 am »
Ofc it will work .
Ive seen normal people make it work .
If you cant make it work , you officially suck .
« Reply #5 on: August 06, 2009, 07:11:20 am »
Ofc it will work .
I'll Hold you to that...
Btw,, If stevie can not get it to work, I seriously doubt anybody can! The dude is Bright!
« Last Edit: August 06, 2009, 07:26:26 am by Warp »
« Reply #6 on: August 06, 2009, 09:43:04 am »
HOax or not a Hoax. Thats the question....
At least i see lots of builds on the net.
In how far it really works..........
Just lets find out.
« Reply #7 on: August 06, 2009, 10:24:55 am »
Or just maybe he is a bad mannered business man and tricked some people which gave him a "hoax" reputation...
That does not have anything to do with his technology which always seemed interesting and logical to me.
So Internet is probably right in one sense  and for a fact there are hundreds if not thousnads of people out there who have gotten it working. Even lots of farmers in France and JL Naudin is no blockhead.... He even ran on 95% water.
It does work and we should all integrate this tech(modified I suggest) into a 100% water engine. I have four key techs that I will use in my trials later(HHO, dry steam, GEET(Umila), Laser). Combination is always key.
; ' ; One Google of
