Author Topic: Electrojolt's Stable PWM Step By Step Assembling Instructions  (Read 18970 times)
Re: Electrojolt's Stable PWM Step By Step Assembling Instructions
« Reply #32 on: August 04, 2009, 22:44:28 pm »
Did anyone build this PWM or assembled after purchasing the PCB from Jolt? I still wish the component locations were marked/printed on the PCB for easy solder/placement.
« Reply #33 on: August 15, 2009, 06:15:27 am »
Where are the 3 resistors on the PCB? Can you please point/label them with arrows?
R9 = 10k
R8 = 1k
R6 = 2.2k
Next I Solder 10Kohm R9, this will feed the signal from the next to be assembled voltage divider.
Next I assemble the Voltage divider by starting with the Resistor that goes to ground R8, here you can use between 1k and 4.7K
Since I don't have anymore 1ks, I do have several 4.7K. Since I'm using 4.7k to ground, I will have to use a higher resistor also to positive R6. and I'm usin 5.1Kohm.
but you can use the ones on the schematic
R9 = 10k
R8 = 1k
R6 = 2.2k
« Reply #34 on: June 09, 2015, 14:53:15 pm »
Today, i repaired the links to the pictures of this project.
I am building one myself now, as this PWM does NOT shift in frequency as soon as you tune the gating.
Its really a fine tool for everybody who wants to discover Meyer secrets.
I will use the 2n3055 transistor in stead off the FET's.
« Last Edit: June 09, 2015, 15:55:42 pm by Steve »
