Author Topic: Variable Voltage Amplitude Control  (Read 17350 times)
« on: April 14, 2009, 17:57:24 pm »
variable voltage amplitude control.
it works perfectly!
(http://i2.photobucket.com/albums/y2/kinesisfilms/the-setup.jpg)
the variable voltage amplitude control creates DC voltage anywhere from 0-140 volts dc and replaces the standard 12 volt battery and my function generator's limit of 5 volts amplitude.
Re: Variable Voltage Amplitude Control
« Reply #1 on: April 14, 2009, 18:07:28 pm »
it works perfectly!
it actually works? you are generating gas?
nice!
« Reply #2 on: April 14, 2009, 18:25:57 pm »
no i ahve been taking a break today.....i blew through 3 mosfets trying to figure out how to make the voltage amplitude control thing......I MEAN THE VARIABLE VOLTAGE AMPLITUDE CONTROL WORKS PERFECTLY!...i get all the waveforms up until the cell becuase i have not yet connected it to a cell......BUT TODAY IS THE DAY!
hopefully hopefully hopefully.
i have to get everything else right before i jump into gas production.
« Reply #3 on: April 14, 2009, 18:32:50 pm »
good luck man, i hope the watercap won't destroy all your waveforms and high voltage like it normally does.
hope to read here later.
« Reply #4 on: April 14, 2009, 18:37:18 pm »
yeah that is why i had to increaes voltage amplitude.....becuase regardless of tubes or not the waters resistance ruins the waveform......this might be why a minimum amplitude of 13 volts is needed.....and with my scope probes connected it adds all the more resistance.
so here we go....going to set everything up.
« Reply #5 on: April 14, 2009, 18:51:30 pm »
damnit...ran out of alligator clips......
brb.
« Reply #6 on: April 14, 2009, 18:57:47 pm »
brb.
Want some of me?
« Reply #7 on: April 14, 2009, 19:28:10 pm »
i just got a bunch more......ok here is the thing.....i get a signal to finally go through!.....but i blew my mosfet!
so i need a very strong mosfet.
i will check today after class......and if not then i will order one off line.
but i can now get the signal to show up in the water!
