Author Topic: Understanding And Creating  (Read 21013 times)
hydro
Re: Understanding And Creating
« Reply #24 on: January 13, 2008, 00:51:10 am »
im not sure what you mean with the link? i am on 56k and don't have time to watch the video right now.
3 phase harmonics is 3 frequencys, at the time of this thread we was still learning what was going on.
it turns out 3 phase harmonics is where you get the best hydrogen. if you pulse that, you will get a square wave from a sine wave with 3 phase harmonics on top of the square waves.
it sounds like to me you may have been reading from the internet? i can only assume you have the vic mixed with the fuel cell? however the 2 should not be mixed, there is nothing hard about what stanley did with his fuel cell in his video.
the water fuel cell had nothing to do with high volts low amps, it never did, this is where alot of people get lost.
    • WaterfuelForAll
« Reply #25 on: January 17, 2008, 10:25:28 am »
Hydro
How does your approach differ from Alaskastar's approach as described at
www.oupower.com/phpBB2/viewtopic.php?t=1781&start=0
I quote Alskastar:
"I have Wiring Schematics that can cure this question of EXACTLY how to re-wire an alternator, to not have a regulator, run the rotor at full field, AND NOT burn up the rotor, and comply with the laws of thermodynamics"
Alskastar's schematics are available at
http://oupower.com/index.php?dir=_Other_Peoples_Projects/AlaskaStar/Wiring%20Schematics
What can we learn & use from his schematics?
Wouter
« Last Edit: January 17, 2008, 10:30:56 am by passion1 »
« Reply #26 on: January 17, 2008, 14:08:10 pm »
I let you know very soon. Just got my 12 diodes....
steve
hydro
« Reply #27 on: January 17, 2008, 17:32:35 pm »
Hydro
I quote Alskastar:
Wouter
yawns, just woke up. in my setup you use no battery, you know when the alternator is tuned by watching your hydrogen output, when it turns so white you cant see threw it you have hit 3 phase harmonics. the field coil never gets hot nor uses an external battery. the field coil only uses 1 amp.
my new 12 cell is untested with the alternator at this moment.
« Last Edit: January 17, 2008, 17:34:28 pm by hydrocars »
    • WaterfuelForAll
« Reply #28 on: January 17, 2008, 20:44:20 pm »
Hydro
That's indeed impressive!!  :o
Is the schematic posted at
http://ionizationx.com/index.php?topic=140.0 the complete setup that doesn't need a battery?
hydro
« Reply #29 on: January 17, 2008, 22:05:57 pm »
yes, thats the beta version that works without external battery power.
« Reply #30 on: January 17, 2008, 23:03:06 pm »
Wouter, Hydro,
The 12 diode setup is NOT good.
I get more amps in the old 6 pack setup.
Voltage is the same.
Case closed.
steve
hydro
« Reply #31 on: January 18, 2008, 00:43:11 am »
no comment
